Old 03-25-2004, 03:26 PM   #1
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Impreza WRX STi Pre motor swap mods?
my girl friend is planning on swapping the motor in her 2.5rs in about a year. so to keep the cost down, we are trying to do things to the car now that will aid the motor swap. we would also like the RS to sound better right now, and maybe pick up a few hp. we are thinking about having a local shop weld up a cat back exhaust (whats a fair price?). the problem is we dont want to change the exhaust again later on. so what size piping would you guys recomend. im leaning twords 3in, yes i know 2.5 rs' dont really like piping bigger than 2.5in, but that might be on the small side if she puts in a jdm motor at a later date.
were planning on buying the muffler and resonator ( should even we put a resonator on?) online, and taking them into a shop to be welded in. any recomendations on mufflers or places to get them... and if you think we should put in a resonator. were looking for better/ deeper "boxer" sound, but we dont want rasp.
also any other mods that we could do now that a turbo motor could use? thanks for reading the long post.
RS_to_WRX_swap is offline   Reply With Quote
Old 03-25-2004, 05:39 PM   #2
ratt_finkel
Member#: 46218
06 EVO 9
So you're planning on swaping the JDM WRX motor in?
If so, then yes. A 3" cat-back. A fuel pump, and stand-alone engine mangement. That's all you can really prepare for.
And save your money for a bigger turbo
ratt_finkel is offline   Reply With Quote
Old 03-26-2004, 12:09 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Someone correct me if I am wrong, but I was under the impression that the WRX downpipe does not end up in the same place as an RS cat-back, and as such you would not be able to use any catback on the car after the swap. You will be able to use the axle-back muffler, but you will need to adjust the length of the mid-pipe to mate to the DP...
Old 03-26-2004, 12:16 AM   #4
obyone
Member#: 16523
Ding ding ding!!! We have a winnAR!
The axle back fits with no issues at all, it's everything else you'll have to swap out. So, not cat-back for you my friend. If youwant a better sound right now, you can ONLY swap out the muffler...seeing as how you don't want to do it over again later.
obyone is offline   Reply With Quote
Old 03-26-2004, 01:31 AM   #5
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
ahh, ok thanks guys. so does this exclude the resonator too?
any opinions on a muffler that will be ok now, and great for the swap? from where?
Old 03-26-2004, 09:04 PM   #6
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Does anyone have pics of the under body of a 2.5RS vs wrx/sti. Does it run on different sides of the car? im wondering if this is going to be custum why cant i make a cat back work for when we get the motor swap. if its only a flange that has to be redone, its no big deal.
Old 03-26-2004, 10:07 PM   #7
obyone
Member#: 16523
RS
WRX...or STI...dunno
But then again, neither of these two cars have a stock exhaust (the WRX has a stock Turbo back, but aftermarket cat-back) so I don't know how much this helps.
Old 03-27-2004, 03:15 AM   #8
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
so if i go custom or after market then i can do a cat back and keep it.
ps what type of RS header is that? looks sweet. is it yours? sound clip or vid? drool
Old 03-27-2004, 05:05 AM   #9
joefocker20
Member#: 13745
2015 STI
Just trade it in on a 02 WRX, you're going to lose money doing a swap.. If it were a RX-7 and you were going to put in a 20B, then I would say go ahead, but its not feasible to put in a WRX engine in a nearly new RS..
joefocker20 is offline   Reply With Quote
Old 03-27-2004, 09:26 AM   #10
obyone
Member#: 16523
No. The only exhaust component that's shared between N/A Subaru's and Turbo ones is the muffler...that's it. Everything else: the header, the up-pipe N Downpipe (turbo only), Cat, and Mid-pipe are different.
If you don't want to waste as little money as possible, just swap out the muffler. Once you have the turbo engine, you will have to swap out the rest of the exhaust anyhow.
BTW...that's an MRT header, high flow cat, and unresonated mid-pipe. it's doesn't look like that anymore becuase it's dirty now and I installed a resonator in my mid-pipe.
I have a vid but it makes it sound worse than it really is because I'm following 4 sweet sweet sounding modded WRX's.
I'll post it later.
Old 03-27-2004, 02:58 PM   #11
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
what are you talking about, you must not have done your research. first im doing the swap my self. and second im going jdm, so it will blow wrx' outta the water. and as for insurance for a 21 year old makes a huge diff. so please do not go off topic, especially when your completly wrong.
Old 03-27-2004, 11:19 PM   #12
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
do suspension. coilovers, struts bars, sway bars, links, u cant go wrong with suspension.
ommmjido is offline   Reply With Quote
Old 03-27-2004, 11:28 PM   #13
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
weird how my blitz nur catback and downpipe mate to my turbo
must be cause it doesnt fit
Old 03-29-2004, 05:00 AM   #14
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
how much is it off by?
Old 03-29-2004, 01:47 PM   #15
ommmjido
Member#: 35746
08 White GRB
do u have RS-T or a whole EJ20 motor swap?
Old 03-30-2004, 12:00 AM   #16
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
its not im not sure if my blitz was form a wagon but it fits like a standard wrx, the uppipe is a nother story because i knew i was going to have to get one made
ps rst baby no pussay 2.0s for me
jk gotta love the 2.0 but i put in an ej257
Old 03-30-2004, 12:05 PM   #17
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Suspension, guages and electronics would be all I would do if I knew I was doing a swap.
All power mods you try to make for an NA car will not transfer to a turbo car or will not be optimal once turbo. 3" exhaust on a NA car is not worth it at all, it will kill low end torque and only pick 1-3 hp up at the very end of the rev range. Borla and TWE headers can be used with RS turbo kits but not swaps, and these headers aren't optimal for turbo anyway. You might think about picking up a Cobb intake, use it for a year and then sell it, you will lose some cash on the deal, but not too much because the Cobbs will always be in demand and sell for good money.
Compressed is offline   Reply With Quote
Old 03-30-2004, 12:20 PM   #18
ommmjido
Member#: 35746
08 White GRB
well maybe thats why ur exhaust fit on ur car coz u still have an EJ25 in there. if ur talking abt an EJ20 swap the pipings r different arent they?
Old 03-30-2004, 01:10 PM   #19
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
i think were ganna do a rear sway bar, P1 springs, and kyg struts soon. as for intake we already have a ganzs flow replica i made, works great. i think its major rice having a boost gauge and not having a turbo "yet" but this might happen.
Need more info for sti motor swap - hvac, motor and so on. hybrid gti 2 Subaru Conversions 4 09-29-2008 11:41 PM
fs:1997 honda civic coupe,gsr motor swap,good mods,Virginia. I WANT AN STI Private Vehicle 'For Sale' Classifieds 55 07-28-2007 10:34 AM
dash swap and motor swap questions aka_tur Subaru Conversions 6 02-27-2007 06:21 PM
Hypothetical...swapping cams when doing motor swap kaisersouse Normally Aspirated Powertrain 0 04-14-2006 08:54 AM
ECUTek'd JDM ECU into a USDM WRX question, pre-engine swap jpmarotta Engine Management & Tuning 1 03-10-2005 09:21 AM
