Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-25-2004, 05:27 PM   #1
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
Post Snuglid Installation
O.k. here is my experience with the SnugLid installation for my '03 Baja. I bought the lid from 'Q' at Ideal Automotive in Tampa Florida for ~ $1000 plus tax. There is a coupon on their web site for an extra $25 off which helps out with tax. Since I am installing it my self I did not pay for installation. Installation instruction are found on another thread or here. The lid already comes painted so be sure to order the proper color for your Baja.
braveit1 is offline   Reply With Quote
Old 03-25-2004, 05:28 PM   #2
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
Packaging:
The box the lid comes in is 64" x 52".
Old 03-25-2004, 05:32 PM   #3
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
Inside the box is the lid preassebled and a baggy.
The baggy contains screws to mount the rails to the Baja, twist ties, a drain tube, instructions, washers, and warrenty. There is also a set of Keys for the lock.
Old 03-25-2004, 05:39 PM   #4
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
The first set was to unassemble the lid. The cross bar had to be removed so the rails could be. I assume you could try to do the installation without removing the rails but it would be heavy. You have to remove the front (back?, [the smaller part]) half of the lid because it has to slide between the sport bars. After disassembling the lid and removing the Baja's six screws from the upper part of the bed it was time to install the rails. This was my first problem. The screws that came in the baggy were US Standard and the Baja needed #6 metric screws. I will call/write Snuglid about this but a trip to Home Depot fixed it for me. I think I had to spend $1.22 for the six screws.
Since I did not have the screws last night I will finish the installation tonight.
Old 03-26-2004, 08:57 AM   #5
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
With the proper screws the rails mount to the same location the old screws where in. The rails lined up perfectly and were put into place. At this time only the rear two screws are installed on each side. The third set of screws will be installed after the front lid is put in place. The cross bar was installed between the two rails. Next I placed some tape along the top edges of the Baja and the corner by the tailgate.
This is an important step and should not be skipped. It is very likely you will scratch your Baja if you do not do this.
Old 03-26-2004, 09:02 AM   #6
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
Once the front lid is in place you can screw in the last bolt. I found it easier to remove the nut from the rail where the "L" bracket is located and screw the nut back on after the bolt is in place. There are three screws along the cross bar that hold the front lid in place. I had difficultity installing the front two screws into the front lid. It would help to have someone press down on top of the lid while you screw those small screws in.
Old 03-26-2004, 09:08 AM   #7
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
To install the read lid a metal plate must be guided between the tabs on the rails. I did it alone but it would be much easier if you had some help. You also need to attach the lift rods to the hinge. THey have to be slightly compressed to do this. I found that compressing them a few times before trying to attach them loosens them up from the factory/storage. With the hinges in place a bolt is attaached to secure them. This process is reversed when you want to remove the lid for larger objects to put in the bed.
Old 03-26-2004, 09:10 AM   #8
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
Before you close the lid and the tailgate check the key to make sure it unlocks the lid! The lock is located on top of the rear lid. It has a rubber cover to keep the water out of it since it faces up.
Old 03-26-2004, 09:12 AM   #9
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
Finally here is the finished product. (Well semi-finished. I still need to adjust a few bolts to level and square the lid when it is closed. I got to dark last night to do it then but you can get the picture.
Old 03-26-2004, 11:50 AM   #10
SouthShoreBaja
Member#: 50658
2006 2.5RS
Thanks alot, Braveit, for taking the time to put this together. I'm going to PM the moderator to Sticky this thread so it doesn't leave us.
SouthShoreBaja is offline   Reply With Quote
Old 03-29-2004, 09:09 AM   #11
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
After reviewing my installation I have found that another way to do the installation by yourself is to remove the two sets of bolts from the front part of the rails, attach the 'L' brackets to the front lid before attaching the front bolt to the rails. This will allow the weight of the lid to aid in the install and not require some to push down from on top. (refering to the picture with the red circle.) I did notice that the screws in the manual were suppost to be #6 45mm screws. Mine came with 4mm US Standard threads and as I said, The Home Depot sells the proper screws for under $2.00 Just make sure you get the kind that will not rust.
Old 03-29-2004, 11:16 AM   #12
Pow
Member#: 54811
03 Baja
Regatta Red
Thanks for all the info, braveit1. What is your take on the seals around the smaller portion of the lid? User solid sender commented in an earlier thread that his seals appeared to still be prototypes. Now half a year later, does it look like SnugTop has a good seal up front?
-Pow
Pow is offline   Reply With Quote
Old 03-29-2004, 09:26 PM   #13
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
I don't think the design has changed at all. The box I got said it was an '04 model top, whatever that means. For normal driving and rain the seal holds tight but if water is forced along the edge of the cab with the hose or a high pressure wash it will leak into the bed. If there was a channel rail attached to the back of the cab it could help. A more fixed solution would be to glue/seal the gasket to the cab. To fixed for me. As pointed out earlier, the seal will keep things dry 95% of the time.
Installing OEM I/C spray pointblink19 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 06-03-2010 01:19 PM
Snuglid on Ebay: Atlantic Blue pcmdude Baja Forum 3 09-28-2006 09:42 PM
Wanted: Your Thoughts on my Snuglid For Sale Road Toad Baja Forum 6 06-04-2006 03:53 PM
To the snuglid guys... oceaneer Baja Forum 8 05-02-2004 07:36 PM
Snuglid locks tailgate! & Install Tips Road Toad Baja Forum 7 04-22-2004 11:32 AM
