Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 03-25-2004, 09:48 PM   #1
Jgrahn555
Member#: 3224
Question What is base fuel pressure?
What is the base fuel pressure for the '99 2.5L DOHC?
Jgrahn555 is offline   Reply With Quote
Old 03-26-2004, 10:02 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
should be close to the ej22. I've got that info if you don't have it already.
I'm assuming you're trying to compare. You having any problems with the new setup?
Legacy777 is offline   Reply With Quote
Old 03-26-2004, 04:58 PM   #3
Jgrahn555
Member#: 3224
Correct. The base pressure of the 2.2L is 36.6psi. I've got enough fuel during acceleration, but there isn't enough pressure to sustain the engine at idle and cruise. it bubbles up and down for a few minutes then dies.
You have any info on the 2.5 in those manuals of yours? I suppose it's time for me to go out and buy the 99 2.5L DOHC engine service manual.
Old 03-26-2004, 05:08 PM   #4
Hawk296
Member#: 14555
1995 Impreza L
Baja
35.5 at idle, 45 at idel with fuel pressure regulator disconnected.
Hawk296 is offline   Reply With Quote
Old 03-26-2004, 05:17 PM   #5
Legacy777
Member#: 4800
what happens when at cruise......
Honestly....the problem doesn't make much sense. The fuel pump has no controller on the older cars, it's just on, and the regulator bypasses excess fuel back to the tank. If you have enough during acceleration, you should have enough during idle and cruise.
if your problem was just idle....I'd say look at the IAC valve. But since it's also under steady state cruising.....then that's a little more difficult.
You may want to take some readings from your O2 sensor to see if you're becoming extremely lean or rich during those times the engine dies. It's possible your ECU is not controlling the engine properly....
What is stock fuel pressure for 2.2 NA? reddevil Legacy Forum 5 07-14-2004 10:33 PM
What is stock fuel pressure? SPeeDSiN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-26-2003 05:52 AM
What is everyones fuel pressure at idle and what pump/FPR are you using? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 20 05-30-2002 03:32 AM
where is the fuel pressure regulator? jasona Normally Aspirated Powertrain 6 05-01-2002 10:20 PM
('93-'01) What type of Fuel Pressure Regulator on an RS? RacerinLSL Impreza Forum 1 07-03-2001 03:25 PM
