Vancouver Impreza Club
Old 03-25-2004, 09:19 PM   #1
quest
Member#: 42402
- Finder of Porn
-Bringer of tears...
Default how much to get springs installed?
ima pick up some prodrive springs soon, and was just wondering how much it is to get a set installed (roughly)? ...and if you know a place that does good work fo cheap, let me know
Thanks!
quest is offline   Reply With Quote
Old 03-25-2004, 10:09 PM   #2
Chizzow
Member#: 39451
2013 Sti hatchback
Wrb
www.mfrt.com
talk to percy and tell him the Danny- yellow subaru guy sent you there
Chizzow is offline   Reply With Quote
Old 03-25-2004, 11:13 PM   #3
quest
Member#: 42402
- Finder of Porn
cool thanks! Prodrives, here i come!
Old 03-26-2004, 12:36 AM   #4
bwco
Member#: 44137
most shops usually charge around $100-$150 on top of the price of springs.
If it's Garage 5, they charge 50 bucks on top of the spring prices for civics and hondas. Too bad yours a Subaru. Give them a try if you are on budget.
Or even rent a spring compressor and do it yourself.
bwco is offline   Reply With Quote
Old 03-26-2004, 01:07 AM   #5
quest
Member#: 42402
- Finder of Porn
ah, $100 aint too bad.
Old 03-26-2004, 02:12 AM   #6
bwco
Member#: 44137
you must be awear of the $75 alignment fee as well. Some shops may include it in installation. So, go to a shop that has alignment equipments. They usually can give you a better pricing on spring installation.
Old 03-26-2004, 02:49 AM   #7
quest
Member#: 42402
- Finder of Porn
ah, i didn't know about that....I heart Nasioc.
Old 03-26-2004, 03:13 AM   #8
fukamoto
Member#: 13339
2014 SWP WRX Wagon
$100 cash at Garage Five, no tax.
However, be prepared to wait a while for bookings.
fukamoto is offline   Reply With Quote
Old 03-26-2004, 03:46 AM   #9
quest
Member#: 42402
- Finder of Porn
Cool. I still have to order the springs, so it's no big rush.
Old 03-27-2004, 02:47 AM   #10
Rollie
Member#: 10551
2002 Impreza WRX
WRC Blue
Just got my E-baich spring done at MF Tech today, good guys.
they charged me 130 for install and 95 for 4wd alignment
Rollie is offline   Reply With Quote
Old 03-27-2004, 03:26 AM   #11
[YeS.SiR]
Member#: 56602
2012 SWP STi
Is camber something to worry about after a drop with springs?
[YeS.SiR] is offline   Reply With Quote
Old 03-27-2004, 03:29 AM   #12
Rollie
Member#: 10551
2002 Impreza WRX
WRC Blue
I have no idea, but i heard some squeeking sound from the rear driver side....
Old 03-27-2004, 03:34 AM   #13
bwco
Member#: 44137
isn't ICBC rate for 4 wheel alignment $75? or cheaper?
Old 03-27-2004, 03:46 AM   #14
tora
Member#: 5851
09 Forester XT
+ NA Miata
the change in toe is a bigger worry as it will cause premature wear on your tires. The Prodrive springs don't have a lot of drop so camber should be fine and front camber can be adjusted back into factory specs without issue.
tora is offline   Reply With Quote
Old 03-27-2004, 03:48 AM   #15
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
$100 for installing struts and springs at my friend's shop..
another $100 for laser alignment..
plus taxes if ya want a reciept..(good thing to have imo..)
KIMUTAKU is offline   Reply With Quote
Old 03-27-2004, 04:59 AM   #16
[YeS.SiR]
Member#: 56602
2012 SWP STi
I've got my car dropped closer to 2" on 17" wheels. I notice a little negative camber, but I doesn't seem like the toe is affected. Mind you, this is all by eye.
I haven't done an alignment yet, nor do I have a camber kit ... hmmm ....
Old 03-27-2004, 10:57 AM   #17
Benjamin Tang
Member#: 4496
2009 Forester
red
2" will definitely affect toe... the before/after printout from the alignment machines showed mine totally out of wack both front and rear
wow... it's $100 for laser alignment now? nooo... it was only like $80 the last time i went to advance!
Benjamin Tang is offline   Reply With Quote
Old 03-27-2004, 11:47 AM   #18
tora
Member#: 5851
09 Forester XT
+ NA Miata
As Ben said you definitely need an allignment if you want to keep your tires around for awhile. Lowering the car two inches will change toe ALOT. Even an inch of lowering changes toe enough that it will affect tire wear. Camber is easy to spot by eye and people who have been in the business for awhile could guesstimate the degrees of camber quite well, but toe is much harder to tell unless it is horrifically out.
Old 03-27-2004, 12:22 PM   #19
Blennophobic
Member#: 25886
2003 WRX Rally Blue
- sold, waiting for 2015s
How long you been driving like this? If toe is out of whack, it should be noticable in uneven tire wear fairly quickly.
I plan to install my Eibach pro kit (1" drop) myself and check and adjust toe myself using a home-made measuring jig... a 2 x 4 or something that will reach across under the car with an adjustable finger screwed on at each end. I don't anticipate the need for a professional alignment with this simple spring installation.
Steve.
Blennophobic is offline   Reply With Quote
How much to get my windshield installed? swi99 South West Impreza Club Forum -- SWIC 1 04-27-2008 01:56 PM
How much to get frt & Rear lines installed with full fluid flush? waitandbleed92 Brakes, Steering & Suspension 8 04-14-2005 10:04 PM
Lowering my Suspension where to go to get springs installed & what springs to buy asbWRX04 Brakes, Steering & Suspension 9 04-21-2004 09:12 PM
how much to get EGT probe installed? efongabonga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-01-2003 08:43 PM
how much to get gauges/TT installed DanD Newbies & FAQs 2 07-24-2002 07:29 PM
