Welcome to the North American Subaru Impreza Owners Club Tuesday September 23, 2014
Old 03-25-2004, 10:56 PM   #1
Pedestrian
Member#: 52410
05 LGT
Default Defi boost gauge help
I just installed my defi boost gauge, and everything went pretty smooth, except for when I get on it, the boost doesn't read past 7 or 8 psi. I attatched the vacum hose to where the stock boost gauge's hose was. It wasn't the tightest snug fit, but it wasn't loose either. Does anyone know what my problem may be? Could the hose be leaking boost due to the hose being too big for the little brass connecter coupler thingy?
Thanks,
Ben
Pedestrian is offline   Reply With Quote
Old 03-26-2004, 09:18 AM   #2
sneeky
Member#: 44639
STi
the 35 awaits you...
you can try to zip tie the bastard, don't know if it'll make a difference but maybe you're leakin a little... just my .02 cents. also, most people are running the t-connector in the vacuum line behind the bov, or if you still have he stock bpv. that's where i put mine and it reads fine. where is the stock hose located anyway?? i didn't get one with my sti, by choice.
chris
sneeky is offline   Reply With Quote
Old 03-26-2004, 11:22 AM   #3
CalcVictim
Member#: 57056
2006 Miata
Copper Red
I second the leak opinion, or possibly shyty guage.
CalcVictim is offline   Reply With Quote
Old 03-26-2004, 11:33 AM   #4
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
You don't want to run the brass restrictor (it is not needed for aftermarket electirc gauses). Just attach the line from the sensor directly to the stock "T".
mbiker97 is offline   Reply With Quote
Old 03-26-2004, 08:48 PM   #5
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
your defi gauge came with a brass restrictor?
i just T'd mine off the bov vacuum - the defi hose is a different size than the stock vacuum hose so i went to autozone and bought a coupler that matched the two sizes together .. to be on the safe side i put zip ties on them too ..
so it actually goes T in stock BOV vaccum line to small section of hose in same size and then coupler to smaller Defi hose size - the Subaru oem boost gauge install shows them doing something similar .. i have a PDF of that manual somewhere .. i think stock is 1/4 and the defi is 3/16?
deif link or d-gauge?
http://www.defi-shop.com/product/met...er_inst.html#4
ronaldwrx is offline   Reply With Quote
Old 03-27-2004, 02:00 AM   #6
Pedestrian
Member#: 52410
05 LGT
Thanks for the advice, I skipped the brass restrictor and attatched it strait to the t behind the bov, and it works like a charm. THanks again.
WTT? or FS: 60mm Defi Boost Gauge for Defi Oli Temp Gauge SedonaRed03WrX Interior/Dressup/Audio & Security 4 12-27-2007 06:45 PM
Help with Defi Boost Gauge Jhovany Electrical & Lighting 6 02-28-2007 04:44 PM
Problem with Defi BF Boost Gauge! Help! BlueSix Electrical & Lighting 15 10-12-2004 05:48 PM
Help with Defi Boost Gauge BlueSix Factory 2.5L Turbo Powertrain 0 10-08-2004 07:25 PM
DEFI boost gauge install help? elsanto Factory 2.0L Turbo Powertrain 2 10-07-2003 07:29 PM
