Old 10-24-2000, 03:34 PM   #1
wrxman555
Member#: 2677
2001 Lexus IS300
Post Anyone have problems with their abs brakes on rs. need input!
Has anyone else had a problem with their ABS on there RS? I recently started my car and the ABS warning light came on. I drove to my friends house and when I got back out to my car, turned on the engine, Light DIDN'T come on! What the heck is going on?? This has happend two other times since so I plan on making a trip to my Subie dealer for service. Just wanted to know if anyone had this same problem??
wrxman555 is offline
Old 10-24-2000, 04:24 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Lightbulb
check to make sure your abs fuse is good and properly in place...
just an idea...
whenever i pull mine to rallyx.. the light comes on...
j.
Subie Gal is offline
Old 10-24-2000, 05:15 PM   #3
deadbolt
Member#: 990
96 Brighton and...
many
Post
The car might have detected a "low voltage" condition which could cause the light to come on, that might also explain why it didn't come back on after you drove it a bit and the alternator had juiced the battery up a little.
I recently had my ABS fail at an Auto-X. Brakes locked, I slid through the stop-box and then they wouldn't unlock. I put it on the computer the next day at work and the computer showed the wierdest thing. The front speed sensor showed the car was traveling at 34 MPH and the rear at 24 MPH, this apparently blew the computer's mind and caused the failure. The odd thing... No ABS light when it happened.
deadbolt is offline
HTML code is On
Anyone have problems with their Helix up-pipe? Lee Chun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-30-2008 07:53 PM
Anyone have problems with seal/abs when using DOT 4/5.1 brake fluid? Dizmal Brakes, Steering & Suspension 6 03-19-2007 07:56 PM
Anyone have problems with Abs in the rain? SubaruImpreza_power Newbies & FAQs 14 11-30-2003 10:40 AM
('93-'01) Anyone have a problem with their ignition coil on MY99 IMPREZIV Impreza Forum 2 04-18-2001 01:37 PM
Does anyone have problems with their RS brakes??? wrxman555 General Forum Archive 0 10-23-2000 06:12 AM
