#1 |
Member#: 38400
Vehicle:2004 WRX Wagon DRZ400SM |
I've got a DOHC EJ25 with just over 90,000 miles. I need to get my timing belt changed and I understand that this is a good time to install more agressive cams. how many further labor hours is it beyond changing a timing belt to swapping cams?
I'm also interested in whether it is worth it to cam a 90,000 mile engine. I'm looking at the TWE stage I cams for $690. What do you think?
#2 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
it's about 7 hours labor a side and then you have to re-shim them once you are done
#3 | |
Member#: 16523
Vehicle:JDM Maxxpro |
#4 | |
Member#: 38400
Is the timing belt change really not a good time? It's got to cut some hours off labor, right? |
#5 |
Member#: 6395
NESIC
Vehicle:2006 WRX STI Steel Grey Metallic |
whylegacy,
Installing the cams requires all the disassembly needed for the timing belt change and then the following: * Remove the valve covers * Remove the cam retaining caps * Swap the cams * Perform valve adjustment * Reassembly In my opinion this is a perfect time to install the cams. You're near the 109,000 mark for a valve adjustment anyway. Most shops charge a flat rate for the valve adjustment. They'd probably just charge an hour or two of labor for the cam install. Best Regards, Chris |
| Thread Tools | |
| Display Modes | |
| sti cams in hybrid build? is it worth it? | ki11switch | Built Motor Discussion | 26 | 03-27-2011 11:00 PM |
| Royal purple engine oil is it worth it? | wrxkid157 | Factory 2.0L Turbo Powertrain | 14 | 03-03-2009 07:54 PM |
| Project Engine, is it worth it? | profall | Built Motor Discussion | 10 | 11-20-2008 04:29 PM |
| is it worth removing my intercooler piping and heatwrapping it? | bradze | Water/Methanol Injection, Nitrous & Intercooler Cooling | 2 | 11-15-2008 04:15 PM |
| Is it worth upgrading my stock Morette bulbs? | Orson | Electrical & Lighting | 43 | 05-17-2003 09:13 AM |
