#1 |
Member#: 51771
Vehicle:2000 Impreza GC6 SRP 1980 G2 Celica Rally Taxi |
I am buying a turbo kit and this is what it has in it:
-AiResearch T3-T28 turbo -Vortech RRFPR -Fuel Injectors (according to subaruparts.com they are STI injectors) -Intake piping -Uppipe -Cone filter -Oil catch can w/breather -Numerous hoses and clamps -Power Inc. Fuel Pump What else will I need? From what I understand I will need a downpipe, some sort of stand alone ecu (I have a 2000 RS), some intercooler piping, an oil pan with an oil return tapped into it, and a tmic with blow off valve. Is there anything else you can see me needing?
#2 |
Member#: 6271
Vehicle:2001 2.5RSTi 2007 Legacy Spec B |
Yea, you'll need a turboback (dp (das pooper?
) , midpipe, axle-back). If you go for standalone, you won't need the rrfpr, but you should replace the factory fuel pressure regulator if you'll be upgrading the fuel pump. I believe akcel might be selling a tapped oil pan. I also have a stainless steel braided oil return line and the oil gallery plug for the oil feed line. If you need a tmic, I have a wrx tmic I want to get rid of also ![]() |
#3 |
Member#: 10039
if u need a rrfpr i have a bell eng. one for sale
Jeff |
#4 |
Member#: 51771
So can I get away with not getting a stand alone ecu or do I need one?
So I need: - Turboback - Fuel pressure regulator - Tapped oil pan - tmic Anything else to have everything I need for the swap? |
#5 |
Member#: 10039
for the oil return to save some money u can do what FAT does with there kits and have it return to the rocker cover (valve cover)
JEff PS i did it this way also with no problems edit forgot to add i have a modified wrx intercooler made into side feed i got pics if needed i'll sell everything for pretty cheap too because i don't have the car anymore, traded it in on a xt |
#6 |
Member#: 51771
Well the guy I am buying the kit from I am actually going to make payments on because I dont have much money right now (going through some hard times). But if down the road when I get some payments under my belt and have some extra money I will definately talk to you first.
#7 |
Member#: 6271
i have no experience with rrfpr's but they've worked for other guys here.
#8 | |
Member#: 51771
#9 |
Member#: 6271
tec2, 550 cc injectors, SVX fpr, walbro fuel pump
#10 |
Member#: 10272
South East
Vehicle:1999 EJ257 RS Aspen White |
What STI injectors are those? Only year that the STI injectors fit in is the 99??
-Josh |
#11 |
Member#: 51771
So then I do have to use something like the tec2 or I dont?
#12 |
Member#: 6271
it's recommended, not needed
#13 |
Member#: 51771
Ok, so I can get away with the Fuel Pressure Regulator until I can afford a tec2 or something?
I am sorry for all the questions but I am coming from carburated big blocks and things of that nature, turbos and imports are completely foreign to me. |
#14 |
Member#: 6271
from my understanding, a fuel pressure regulator is different from a rising rate fuel pressure reglator.
But what people will say is might as well do it right the first time, ya know? Why spend the extra $ for an rrfpr as a temporary band aid if you're gonna get an ecu anyway? |
#15 |
Member#: 51771
Well I am getting the Vortech RRFPR with the kit so I am hoping to use that until I can save up for the ecu.
#16 | |
Member#: 32955
SCIC
Vehicle:'03 WRX Wagon '89 3S-GTE Alltrac Camry |
-Charlie PS. Why are you turboing your car if you don't even have enough money to pay for the kit outright? ?? Its going to cost a lot of money to get it working and a lot more money to keep it working at 100%... |
#17 | |
Member#: 51771
And to answer your question on turbocharging my car, because I want to. I am a speed whore and I have a back up car incase I **** up my Suby, not to mention it is always broken anyways so I am getting used to not actually driving it. |
#18 | |
Member#: 32955
SCIC
If you run a rrfpr, you might want to consider a fuel pressure gauge (electronic inside the car). Oil pressure/oil temp/water temp are also options. You might also consider a wideband O2 sensor/gauge if you are going to tune your car, but those are pretty expensive... -Charlie |
#19 |
Member#: 51771
So then for now I should go with the boost, egt, and fuel pressure? What is the purpose of the egt gauge?
#20 |
Member#: 6271
EGT - exhaust gas temperature. If the exhaust gas gets too hot, you'll end up melting parts in your motor. Some people target a certain EGT value when tuning their cars.
IMO you should get a gauge for a part/component of the car you'll be modifying: boost oil pressure fuel pressure air fuel ratio gauge ( wideband ) EGT |
#21 |
Member#: 51771
Damn, I dont know if I have enough space to mount all those
![]() Will I really need all of them for 5-7psi? |
#22 |
Member#: 6271
Many of the things mentioned here are more like recommended than needed
![]() It'll just make it easier to monitor what's goin on if things don't go smoothly ( and they never do ). |
#23 |
Member#: 51771
I got ya
#24 | |
Member#: 10268
SCIC
Vehicle:gc8 I ride ride 24s with the top down low. |
#25 |
Member#: 51771
Wouldnt it just be easier to go to a junk yard and buy a pan and then just have my welder friend tap it for me?
| Thread Tools | |
| Display Modes | |
| Help Pricing my Turbo Kit | maxiav | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 11-27-2006 02:13 PM |
| Suby Newbie needs help picking a Turbo-Kit | dl337j00 | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 03-26-2004 02:11 PM |
| i need help finding my turbo size. please help! | STEALTH-WRX | Factory 2.0L Turbo Powertrain | 5 | 03-27-2003 03:07 PM |
| X-Post: I can't finish my turbo kit, so it's for sale | BrysImpreza | New England Impreza Club Forum -- NESIC | 8 | 01-28-2003 09:24 PM |
| Need help finishing a body kit install | sdseagles | Interior & Exterior Modification | 6 | 08-17-2002 01:13 AM |
