Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 05-08-2000, 11:59 AM   #1
Member#: 700
99 Impreza RS
Silverthorn Metallic
Post anyone have a linkt to installing the 18mm sway bar?
I know this site a set of pics for installing the sway bar but since only the message board is working, does anyone have another site that has it? I just got my 18mm sway bar from JC Sport. Took'em only a week!
Snoopy is online now
Old 05-08-2000, 01:12 PM   #2
Member#: 355
08' VW Touareg II
Alaska Grey
It way too easy to install to need pictures. If you feel uncomfortable doing it without directions take it to a repair shop! Look at your old bar. It a matter of 4 bolts no tricks.
DonA is offline
Old 05-08-2000, 01:15 PM   #3
Member#: 274
agreed. just crawl under there and look at it.
step 1: remove four bolts holding in current bar
step 2 remove old bar
step 3 put new bar in place
step 4 put the four bolts back in
there. you're done and your RS doesnt understeer as awfully as it did before.
FatChanceTi is offline
Old 05-08-2000, 01:24 PM   #4
Member#: 922
16 WRX (white)
04 FXT (red)
Tip: Don't lift up the car, just slide under yourself.
When you lift the car the arms move and it creates trouble getting the bolts in (I found this out the hard way).
8Complex is offline
Old 05-08-2000, 01:45 PM   #5
Member#: 1387
. 2007 STI Black
2001 S2000 Black
Can you put the new bar on w/o jacking up your car, and w/o taking the tire(s) off?
griffin is offline
Old 05-08-2000, 01:54 PM   #6
Member#: 922
16 WRX (white)
04 FXT (red)
Yup... you need a 14mm open-end wrench and a 14mm socket for the end bolts and I believe a 12mm socket for the two bushing brackets.
8Complex is offline
HTML code is On
Need advice on weather or not to install my Whiteline sway bar or wait. last lemming alive Brakes, Steering & Suspension 5 05-15-2010 09:13 AM
Does anyone have a link to install instruction for the Turboxs FMIC? MattSTi General Community 4 12-25-2005 11:21 AM
Do I need to get the upgraded sway bar mounts? kiefer Brakes, Steering & Suspension 7 08-13-2003 09:54 AM
For those who have installed the rear sway bar STi2001 Brakes, Steering & Suspension 7 03-30-2002 01:17 PM
Do I need to do any alignment after installing the rear sway bar? V6 Brakes, Steering & Suspension 7 02-02-2001 09:56 AM
