Old 10-24-2000, 05:41 AM   #1
akuhner
Member#: 462
2000 Impreza 2.5 RS
SCCA Rally Cross Car
Question Check Engine Light?
While at the N-S Smackdown in Camden on Sunday my check engine light came on and won't go off. The car runs and sounds normal. My only thought is that it just passed 78,000 miles that morning so it must be a "time-for-dealer-inspection" light. Does anyone know if our cars use the check engine light to remind us of scheduled maintainance?
Thanks,
Alex
MY98 RS - no engine mods.
akuhner is offline
Old 10-24-2000, 05:51 AM   #2
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Post
I didn't have a check engine light at 78k. Probably an o2 sensor or something. If one of them dies, it throws a check engine and uses pre-coded fuel maps, so your car runs fine. Just tstop at your dealer and ask if they can read the code. If it is a o2, say thank you, order one from subaruparts.com and put it in. It'll take you 2 minutes to install.
Chuck is offline
Old 10-24-2000, 09:36 AM   #3
akuhner
Member#: 462
2000 Impreza 2.5 RS
Post
Chuck - Thanks for the info. Anybody know of a good Subaru dealer around the Philadephia area (preferably Center City or Bala Cynwyd)? I work right across from Don Rosen, but he was so bad that SOA took away his Subaru franchise. Could someone like RalliSpec read the code?
Alex
akuhner is offline
Old 10-24-2000, 09:38 AM   #4
SRI Performance
Vendor
Member#: 2448
1997 subaru
green and yellow
Exclamation
my check engine came on during a rally and i found out that my Weapon-R intake bracket snapped in half and the vibration probably kicked it on, when i put it back together then it went off, so i thought i was screwed but i guess not and it runs fine
SRI Performance is offline
Old 10-24-2000, 10:08 AM   #5
Subi Chicky
Member#: 2239
'05 Civic Si, SSM
RIP Sirkbac
Post
With no mods, I can almost bet you money that it's an 02 sensor.
Just from work experience (VW/Audi/Mazda/Suzuki) 99% of all check engine lights indicate 02 sensors on non-modded cars.
EDIT: Spelling
[This message has been edited by Subi Chick (edited October 24, 2000).]
Subi Chicky is offline
Old 10-24-2000, 02:50 PM   #6
akuhner
Member#: 462
2000 Impreza 2.5 RS
Smile
Thanks for the advice, guys. I guess I'll just skip to the point and get an O2 sensor. How do I go about ordering and installing one myself? (please remember you are talking to someone who had never taken a wrench to a car before dropping the intake silencer out of the fender ).
Thanks,
Alex
akuhner is offline
Old 10-24-2000, 03:55 PM   #7
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Post
Alex,
Why don't you just call Rallispec? They may even have an extra one on hand.
While you're waiting for your O2 sensor, try resetting your ECU and see if the CE light comes back on.
-WaC
Wayne
97 OBS
wac is offline
Old 10-24-2000, 04:20 PM   #8
KC
Member#: 442
16 SS
00 S2000
Post
Ummm did you check the obvious gas filler cap C/E light problem?
3-clicks to close the cap. Any less and it may cause a C/E light.
Reset the ECU and see if it comes on again.
--KC
KC is offline
Old 10-24-2000, 04:53 PM   #9
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
Post
It just so happens I am taking my car to the dealer on friday to get the check engine light taken care of. I have no engine mods and only 4900 miles(only change the oil once). I have heard it is probably the o2 sensor. My dads Audi did the same thing at about the same mileage. I tried resetting the ECU but it comes back on about two days afterward.
Dolphin Overton is offline
Old 10-25-2000, 05:42 AM   #10
akuhner
Member#: 462
2000 Impreza 2.5 RS
Smile
Well, I guess I'll try re-setting the ECU when I get home tonight. I'd do it now, but I'm "working." I'll post what happens.
Thanks KC and Wayne!
Later,
Alex
akuhner is offline
Old 10-25-2000, 07:09 AM   #11
AndyHidley
Member#: 1031
Post
I hear alot of talk about bad O2 sensors. Which one is USUALLY the bad one, the one in the front or the rear one?
AndyHidley is offline
Old 10-26-2000, 05:50 AM   #12
akuhner
Member#: 462
2000 Impreza 2.5 RS
Question
Well, I reset the ECU and the check engine light has gone off, but we will have to see how long that lasts.
akuhner is offline
HTML code is On
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
