Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 03-27-2004, 02:45 PM   #1
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Thumbs up F-XT IC Si Y install page
Did this today:
http://www.scoobymods.com/forums/sho...1573#post11573
A couple of pics;
OEM:
Si Y:
[/list]
Peaty
Peaty is offline   Reply With Quote
Old 03-29-2004, 04:26 PM   #2
mo_boost
Member#: 42728
04 FXT
Silver Metallic
Peaty,
Did you happen to measure or look closely at the cast manifolds that bolt to the intercooler. I am curious as to how thick the walls are, in addition I am wondering how much upset there is for the the air to flow over. Since you have verified that the WRX Y hose fits, I was going to perform the install, except I was considering porting/smoothing out the transition (essentially I want to knife edge the entrance of the cast manifold so it does not disrupt the airflow).
Thanks
Perrin
mo_boost is offline   Reply With Quote
Old 03-29-2004, 04:55 PM   #3
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Had I known or thought of it I would have but sorry no I did not do any measurements. The cast is pretty thick and I could see that there would be a benefit to doing what you are describing though.
Old 03-29-2004, 07:57 PM   #4
mo_boost
Member#: 42728
04 FXT
Silver Metallic
When I get the chance to perform the swap I will try to document the porting the best I can. Thanks for taking the time and for dishing out the cash to try the wrx hose.
Perrin
Old 03-30-2004, 09:55 AM   #5
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
If thats the case, do you think a set of Samco hoses would fit? I have a friend who has a set he's going to give me when he parts out his WRX in a few months.
Thanx!
Bry.
BrysImpreza is offline   Reply With Quote
Old 03-30-2004, 10:21 AM   #6
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
That's how I got my hose (free ), from a WRX that was no longer using it. I don't see why Samco would not work too.
Old 03-30-2004, 10:39 AM   #7
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Very cool, thank you very much!
I took my stock Y pipe off the look at it a little while back and had a good laugh at the design, it looks like it was an after- thought when designing the car.
Do you know if the STi has a better flowing Y-pipe? I'm trying to make a list of all the things SOA did to the FXT to make a little less power aside from the obvious things (turbo, IC, ECU, injectors, etc.)
Old 03-30-2004, 01:36 PM   #8
Corkfish
Member#: 39503
Peaty,
Have you seen the heat chimney made by Speedmonkee? Basically bolts in place of the stock heat shield over the turbo and funnels heat directly out the hood scoop. Looks easy to install and highly functional, but I wonder if during a heavy rain storm you might be at risk of throwing cold water on a hot turbo. What do think?
Corkfish is offline   Reply With Quote
Old 03-31-2004, 11:14 PM   #9
CsabaHXT
Member#: 52521
2004 Forester XT
How much was the hose? What kind of improvements?
CsabaHXT is offline   Reply With Quote
Old 04-04-2004, 08:24 PM   #10
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Originally posted by Corkfish
Peaty,
I only know of the heat chimney I've never messed with one myself. I don't know if there could be enough rain hitting it to do damage though. do you have a link I could look at? I'm wondering how hot air could get something cold should be getting shoved into. Do they make one for the forester? The forester's scoob snoot is not the same as the WRX's because the WRX's is not as wide.
Peaty
Old 04-04-2004, 08:25 PM   #11
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
I got the hose free So I'm not sure how much they are going for at this time. The benefits are in the link to the mod page I posted above.
Old 04-05-2004, 08:39 AM   #12
Corkfish
Member#: 39503
Here's a link with information on the heat chimney. Apparently, they don't make one for the Forester XT however. At least not yet.
http://forums.nasioc.com/forums/show...t=heat+chimney
Sti 20mm bar on F-XT install page Peaty Forester Forum 42 06-17-2005 03:09 AM
Forester XT IC Screen - DIY Peaty Forester Forum 0 10-17-2003 06:10 PM
Forester XT IC removal Peaty Forester Forum 3 08-10-2003 01:11 AM
Anyone have the Boost Monkey install pages? KwanDDS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-13-2002 01:00 PM
ProECM install page Peaty General Community 3 06-25-2002 03:07 PM
