Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 03-27-2004, 11:26 PM   #1
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
Blue Ridge Pearl - R.I.P.
Default Mystery sensor under dash?
This would be on an 01 5MT RS.
Just noticed this sensor dangling and have no idea whats its for as the clutch sensor is attached.
Anyone?
Geoffman72 is offline   Reply With Quote
Old 03-27-2004, 11:31 PM   #2
Spoolin16PSI
Member#: 51463
2013 Impreza
SWP Gas Sipper
When we were installing the subs in MY03 WRX 5MT we found a green wire (not sure if this is the same wire you're talking about) and hooked it up to the corresponding harness, just to see. All I know is that it threw a CEL and we disconnected it. So I am interested to see what this is too
Spoolin16PSI is offline   Reply With Quote
Old 03-27-2004, 11:42 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Doesn't look factory to me.
Is that the valet switch for the alarm, I think that's where they put them on the GCs.
Spoolin, the green connectors you found and plugged together are for a diagnostic mode and are supposed to be left disconnected. If you hook them up the CEL will flash continuously and the ECU will cycle various devices on and off, including the radiator fans.
Old 03-28-2004, 02:29 PM   #4
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
Thats what I was thinking as mine has no factory alarm. The weird thing is though, theres a plastic connector in the fuse try that goes along with it making me think at one point it was hooked up somewhere.
Old 03-29-2004, 01:13 PM   #5
kecksubaru
Member#: 58361
2002 Legacy L
Default looks like the program button for alarm/keyless entry unit
looks like the programming button for keyless entry/alarm. That does look factory to me. Basically you'd use it to add or change new remotes to the car by holding in the button.
kecksubaru is offline   Reply With Quote
Old 03-29-2004, 11:41 PM   #6
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
This would explain my suddenly iffy keyless entry remotes.
Mystery Wires Under My Hood... Ideas? 02CWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-06-2009 10:19 AM
Speed Sensor, Mystery sensor. smileyou Transmission (AT/MT) & Driveline 12 11-24-2008 06:43 PM
two green mystery plugs under dash yeos Electrical & Lighting 10 09-23-2008 10:50 PM
Mystery Plug Under the Hood...to me anyways. cloudbrk Legacy Forum 8 10-20-2003 12:23 PM
"test" wire under dash - flashing CE light b/c of speed sensor efoo Technical Forum Archive 3 07-09-2000 01:10 AM
