Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 03-28-2004, 02:07 AM   #1
chaddeus
Member#: 56624
2004 Subaru WRX STi
Default Speed Sensor Location?
I installed my Pioneer Navigation Kit BUT the installer could not find the speed sensor to connect it.
Where is it located?
- Charles
chaddeus is offline   Reply With Quote
Old 03-28-2004, 10:02 PM   #2
chaddeus
Member#: 56624
2004 Subaru WRX STi
Anybody?
I need this information to connect to my navigation system
- Charles
Old 03-28-2004, 10:36 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
The VSS is located in the transmission. Get the wiring diagrams for your car and tap the input going into the ECU. That would probably be the easiest.
Jay
Old 03-28-2004, 10:58 PM   #4
WReX'n'Effect
Member#: 22368
2011 WRX Limited
Obsidian Black Pearl
um actually the easiest place to tap into it is the cruise control. I also have the Pioneer Navigation system and that's where pioneer says to install the tap. Sorry I'm not sure which color wire but I know it comes off the cruise control switch. If you can't find out let me know, i will go look under my dash and try to find it, or call Pioneer directly that's what my installer did.
WReX'n'Effect is offline   Reply With Quote
Old 03-28-2004, 11:08 PM   #5
netZ
Member#: 5743
2007 Kia Optima
gold brick
VSS can be found at the ECU Green/Yellow B27
netZ
netZ is offline   Reply With Quote
Old 03-29-2004, 02:01 AM   #6
chaddeus
Member#: 56624
2004 Subaru WRX STi
Thanks a lot!! I am going to fix that tomorrow with some other stuff also
- Charles
Old 04-07-2004, 04:05 AM   #7
WS6toWRX
Member#: 25087
2004 WRX sedan
WR Blue
NETZ, B27 is that the same on the wrx04?
WS6toWRX is offline   Reply With Quote
Old 04-07-2004, 11:34 AM   #8
brunetmj
Member#: 8023
2004 2.5 RS
Here is one place that a speed sensor can be found on the 04
http://forums.nasioc.com/forums/show...hreadid=472333
brunetmj is offline   Reply With Quote
Old 04-07-2004, 02:49 PM   #9
netZ
Member#: 5743
2007 Kia Optima
gold brick
2004 WRX A1 Green/Yellow B134 connector off ECM.
netZ
Old 04-07-2004, 07:22 PM   #10
WS6toWRX
Member#: 25087
2004 WRX sedan
WR Blue
ECM??? Netz I think you mean ECU, i wish i had an Electronically Controlled Missle ....
Old 04-07-2004, 07:42 PM   #11
netZ
Member#: 5743
2007 Kia Optima
gold brick
ecm = engine control module (subaru's naming convention)
netZ
Old 04-07-2004, 09:15 PM   #12
WS6toWRX
Member#: 25087
2004 WRX sedan
WR Blue
you are the man! My subaru has missles
Old 04-08-2004, 10:56 PM   #13
WS6toWRX
Member#: 25087
2004 WRX sedan
WR Blue
NETZ, is the tach on the 04 found at B136 - C9??? green?
thx
chris
Old 04-08-2004, 11:45 PM   #14
netZ
Member#: 5743
2007 Kia Optima
gold brick
http://forum.dreamspeedonline.com/topic.asp?TOPIC_ID=10
netZ
thx
chris
Old 10-28-2005, 03:10 PM   #15
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Rally Stuff Need help with an 2005 WRX
Hello,
I am trying to help someone with a 2005 WRX Sedan 5MT. We are hooking up a rally computer and we need the +5V signal from the VSS ( vehical speed sensor ) at the ECU. I have looked at all the schematics that are available on the ravensblade site and can't seem to find the right one. I tapped the one that I thought was for the 05 (which seemed to be exactly the same GY wire in the in the 1 slot of the front most plug of the ECU / ECM that I used on my 03 when I installed a rally computer on mine. )
Can anyone help with diagram of the 2005 ECU/ ECM pin out, harness guide, color code, ect. so that I can get this install done.
Thanks in advance,
RR
Rapid_Roo is offline   Reply With Quote
Old 10-28-2005, 04:26 PM   #16
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
I am looking at this ECU Diagram, are the diagrams on page 1 referring to the harness end or the socket end (on the ECU/ECM).
RR
speed sensor/location 1990 legacy jim747 Legacy Forum 1 06-20-2006 09:38 AM
Location of sti speed sensor ? bugeyes Electrical & Lighting 4 08-10-2005 04:47 AM
new Q: where the speed sensor location on the ECU? pbnj9786 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-06-2001 10:21 PM
Location of Speed Sensor Wire tsdrally North West Impreza Club Forum -- NWIC 1 04-29-2001 10:46 PM
Speed Sensor wire location diff. from 99-00? Camaroman Normally Aspirated Powertrain 1 11-15-2000 06:12 PM
