Old 03-28-2004, 11:05 AM   #1
mr_yellow
Member#: 39983
2003 WRX Wagon
Default Why is it that 02/03 Rear swaybars arn't compatible with 04+ imprezas?
I can't find the thread i read it in, but subie gal mentioned that you cannot just swap a rear sway bar from an MY02/03 into an MY04+.
is this true? if so, why?
Is the bar shaped that much differently?
Or is it not compatible with the mounts/bushings/endlinks??
What if youget the bushings that match the bar?
I'm all confused! The cars should be functionally identical right? I don't see any reason why subaru would redesign the swaybar of all things...
mr_yellow is offline   Reply With Quote
Old 03-28-2004, 11:12 AM   #2
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
They aren't compatible because the rear suspension has changed enough that they had to reroute the swaybar. Maybe next time those inconsiderate engineers will call you before doing their jobs.
nunyo is offline   Reply With Quote
Old 03-28-2004, 11:21 AM   #3
mr_yellow
Member#: 39983
2003 WRX Wagon
easy on the sarcasm there... You might actually start sounding like you know something
Thanks for the info though, my plans for a cheap 02/03 swaybar upgrade is now down the drain. =(
Old 03-28-2004, 11:34 AM   #4
poison
Member#: 37678
Get a cheap 04 WRX takeoff, what's the problem? Even new I think they are only $80 or so at the dealer. Better than $120 for some aftermarket piece of metal that will do the same thing.
poison is offline   Reply With Quote
Old 03-28-2004, 01:29 PM   #5
mr_yellow
Member#: 39983
2003 WRX Wagon
Well, this is for my 04TS. and I was hoping to just make the jump to an 02 Sedan Rearsway since it's the only 20mm bar besides the STi. I know it'll sound stupid, but i don't want to just get the 04 bar cause it's only 17mm and if I'm going to swap out this part, i might as well go as agressive as the car will allow.
I guess i should be on the lookout for a used STi rear swaybar then...
Old 03-28-2004, 01:44 PM   #6
del105
Member#: 43010
1974 2002tii
The main reasons a 02+ swaybar won't fit is the lateral links are different so the STI droplinks won't attach properly and the bend that goes over the exhaust is different.
So if you have a non stock axleback and different lateral links it will fit.
The real problem with the STI rear is if you want to run a much larger bar you are going to break your lateral links and droplinks where they attach.
I posted a picture yesterday of my car with a 26mm 02+ swaybar installed on my STI.
del105 is offline   Reply With Quote
Old 03-28-2004, 02:04 PM   #7
poison
Member#: 37678
The 04 sedan RSB should still be 19mm, like the 03 sedans? Wagon's are 17mm. Sure 20mm is better, but more expensive, probably.
Old 03-30-2004, 12:19 PM   #8
mr_yellow
Member#: 39983
2003 WRX Wagon
THe 04's RSB on the wrx is actually 17mm on both sedan and wagon.l.. This is coming straight off the FSM.
Thanks for all the info guys, really helped me figure out what i can and can't do.
Old 03-30-2004, 01:10 PM   #9
poison
Member#: 37678
Hey, good to know!
Old 03-30-2004, 04:27 PM   #10
subieworx
Member#: 47769
The ONLY differences between the 04(non STI) and 03 is the bushing shape and the size, 17mm for 04. The bar is the same identical shape as the 03. Subaru upgraded the sway bar mounts on the 04 and hence use a different bushing than the 03's. That's why you can buy a bar like progress, hotchis, or perrin that replaces the mounts and it will work with 02, 03, or 04. There are no other differences other than those.
subieworx is offline   Reply With Quote
Old 03-30-2004, 05:32 PM   #11
del105
Member#: 43010
1974 2002tii
The lateral links are also different where your droplinks connect. If you put 02+ drop links and a fat bar they will break.
02/03/V7 struts not compatible with 04/V8 hats/springs Arnie Brakes, Steering & Suspension 235 01-10-2016 08:52 PM
is it true ? 02-03 ECU better then 04-05 ? ENY169 Engine Management & Tuning 4 10-15-2006 02:35 PM
Why is it that 04 headlights are not horizontally adjustable? caterpill Electrical & Lighting 4 01-31-2005 11:48 AM
why is it that i am the only one on i-club that DOESNT have a girl that wants to use dorifto88 Off-Topic 28 12-04-2002 03:35 AM
Why is it that there is so little done on the interior ? 555wrx Interior & Exterior Modification 11 01-05-2001 07:00 PM
