Old 03-28-2004, 07:38 PM   #1
#522
Member#: 2185
Default Exhaust bolt sizes
Looks like I'll be cutting the bolts off the header to cat connection so I can install my borla headers, anyone know the the nut and bolt specs? I know the head size is 14mm, but whats the length and bolt diameter? Do I need longer bolts since the borla flange is thicker? And finally, any particular grade needed? The car is back on the ground and I don't want to jack it back up until I have all the parts in hand.
Thanks,
Ron
#522 is offline   Reply With Quote
Old 03-28-2004, 09:04 PM   #2
BlkTS02
Member#: 50142
2002 2.5TS
MBP
If you're gonna be dropping the whole header / cat why not crack the bolts loose when it's on the ground and you can get some leverage?
I think the diameter of the threaded section of the bolt is 8mm. Get a 15-20mm long bolt (not including the head) and you'll be fine.
I put in the best stuff home depot had ($.50 a bolt or so) to help prevent rusting and such.
Good luck
BlkTS02 is offline   Reply With Quote
Old 03-28-2004, 11:02 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Mine came off with out a problem at 98k miles.
You should be able to get them off without breaking them.
If you do break or cut them off, just use what ever you can find at home depot thats the same size. Its not really critical. Or you could always get them from the dealer.
Jay
Old 03-28-2004, 11:48 PM   #4
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
I spent $8 at lowes for ss nuts, bolts, and washers for my exhaust..blah
seems subaru uses nuts that can only be used once now on the exhausts...grrr
b_tapper is offline   Reply With Quote
Old 03-28-2004, 11:52 PM   #5
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
Finally some power mods Ron ?
imprezzakc is offline   Reply With Quote
Old 03-29-2004, 10:35 AM   #6
#522
Member#: 2185
Thanks guys. I now plan to drop the whole thing, but I actually had more leverage under the car. I got an open end wrench on the bolt, then other end hooked on the tranny subframe (I guess that's what that was) and a socket on the other side. then, I used my foot and got the bolt turning. It moved about 1/16 of an inch out then kept turning but stopped moving. I'm guessing it's cross threaded. That's why I decided to stop and make sure I had everything on hand I might need.
Anyway, thanks again for the advice, and yes Kris, finaly a little boost in power. Not much, but it couldn't hurt
Old 03-29-2004, 01:24 PM   #7
#522
Member#: 2185
one more thing, when dropping the whole system, where do I disconnect the rear oxygen sensor from? I found he front sensor harness plug, but didn't see the rear. pics?
Thanks again,
Ron
Old 03-29-2004, 02:46 PM   #8
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
I think if you track the rear o2 sensor wire the disconnect should be near the pass side drive axel if I am not mistaken . Plus i had to cut the bolts on my stock header to cat to get it off. I just replaced the nuts and bolts with grade 5 replacements .
Old 03-29-2004, 03:46 PM   #9
#522
Member#: 2185
thanks.
Old 03-30-2004, 11:11 AM   #10
#522
Member#: 2185
Well that was fun. I lowered everything down, cut the bolts off and got the headers on no problem. 2 hours. 1 of it cutting and wrestling those bolts. At least everything is on now and no leaks. Home Depot once again plays a role in modding my car.
Ron
Exhaust bolt size shamrock 05 General Community 4 11-19-2007 03:23 PM
Exhaust bolt size (to trans bracket) Alizarin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-11-2005 09:30 PM
Exhaust bolt sizing question f1kichigai05 Normally Aspirated Powertrain 0 04-14-2003 02:55 PM
exhaust bolt sizes BashoPoem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-29-2002 05:25 PM
Exhaust Bolt Size tsfxRS Normally Aspirated Powertrain 4 08-01-2001 09:03 AM
