Old 03-28-2004, 08:12 PM   #1
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
TMIC FAQ
The primary purpose of a top mount intercooler is to reduce post turbo air temperature prior to entering the combustion chamber via the throttle body.
HP gain is around 15HP. This figure can vary as many TMICs replace the restrictive OEM piping and results can be further enhanced with post installation tuning. This is one modification that is extremely difficult to put a traditional HP figure on as results truly vary from car to car based on tuning and turbo output in terms of CFM.
How much HP can my stock TMIC hold? 300WHP on the WRX and 400WHP on the STi are attainable. That does not mean those power levels are 100% efficient, but that those power levels are attainable with their OEM TMICs. As discussed below though, TMICs are not meant to be HP rated, but rather CFM related, but this is an FAQ so the HP figures are given as a good "bad" answer.
Which manufacturer is best? This topic is highly debated. There have been no reported consistent "bad" TMICs on the market. Obviously, there may have been bad TMICs sold, but not enough to report as "bad" overall.
I have a 2008/2009 model, any differences? Yes. Your engine bay has an entirely new layout vs. the 2002-2007 models. Most of the models listed below are for the older models, so you will have to refer to the manufacturer/retailer for fitment, or use this link as a general guide.
Which TMIC construction method is best? TMICs have two main construction methods:
1. tube and fin
2. bar and plate
There is much debate as to which construction method is best. There are many pros and cons with each design type, but no real hard data. Bar and plate designs are consistently reported as more damage resistant which gives them the edge with regard to appearance longevity. In the end, you are best advised to chose a TMIC based on other qualities rather than concentrate on construction design.
What about the STI or JDM STI intercoolers? The JDM Version 7 intercoolers are 15% larger than the USDM STI intercooler. The Spec C/S202 intercoolers are the same size as the JDM Version 8 units, but have different end tank designs. All JDM versions, save the Version 7 are the same size as the USDM STI intercooler. All are tube and fin design. This is comparative information of the STI intercooler types only and not meant to sway or disuade anyone from purchasing these units.
Which TMIC has the best gains? There is no irrefutable evidence that any TMIC has better gains than another. The consensus, if there is one, is they are all within 5HP or less, gain wise, of each other.
What is the best size TMIC to buy for my turbo? This topic is highly debated. The two general trains of thought are:
a. Bigger is better
b. A TMIC should be purchased based on need
For those willing to do their homework on what particular size would show the most benefit with the least amount of drawbacks, this article outlines the steps necessary to calculate the "best" size.
Are there any downsides to TMICs? There have not been significant amounts of problems with TMICs. Care should be taken by the end users to ensure through the Vendor that any special fitment requirements are discussed and understood prior to purchasing. Even "bolt on" intercoolers maybe have slight issues that you need to be aware of prior to purchasing. STi owners need to specifically ask about fitment as the majority of TMICs on the market were designed for the WRX. Some TMICs also have fitment issues with aftermarket BOVs or the hoodscoop splitter on the STi. There is also the general consensus that TMICs are prone to heat soak when used in situations of stop and go traffic.
How can I combat heat soak? Heat protections options for TMICs fall under two categories:
1. Heat shielding. The primary purpose of heat shielding is to decrease heat soaking of the TMIC and other engine components. Examples of heat shielding are the stock/modified heat shield, Speedmonkee Performance Chimney Heat Shield, Cobb Tuning Heat Shield, Gruppe-S Heat Shield, MadDad Heat Shield, and the Cusco Heat Shield.
2. Turbo insulation. The primary purpose of turbo insulation is to keep the heat trapped inside the turbo for better turbo efficiency. The side effect of this is to decrease heat soaking of the TMIC and other engine components. Examples of turbo insulation are ceramic coating, Thermo Tec's wrap, or DEI's wrap.
These may be used in conjunction to provide the ultimate level of thermal protection.
What are the hidden costs with TMICs? When switching to a larger TMIC, ensure you understand whether it comes with the intercooler piping or not. Some TMICs come bundled with it, some do not.
Once I have a larger TMIC, what steps are helpful to increase it's efficiency?
1. Increase the size of your stock hoodscoop to accommodate the increased TMIC surface area. Maximum efficiency of a TMIC depends on full air flow to the core. This generally means you should obtain a STi or aftermarket larger hoodscoop.
2. Proper ducting/shrouding plays a large role as well. OEM and aftermarket options exist for intercooler ducting/shrouding. This step may require custom trimming to ensure a perfect seal or the addition of an alternate substance to make up the difference if needed. Many people have custom trimmed garage door weather stripping/sealer available from Home Depot or Lowes to fill up any gap between the ducting/shrouding and their TMIC. The end goal of ducting/shrouding is a complete seal between the TMIC and hoodscoop. This ensures that 100% of the air entering the hoodscoop passes through the TMIC core assembly.
3. Additionally, there are OEM and aftermarket options that exist for air splitters. Air splitters divide and route the air coming into your hoodscoop over the entire core of the intercooler.
This thread will help you figure out what scoop/splitter to use.
What are the advanced efficiency options?
1. Waterspray. There are aftermarket and OEM options that provide increased cooling efficiency and combat against heat soak issues with TMICs.
2. NO2 and CO2 Sprayers. There are aftermarket kits that spray CO2 or NO2 to cool TMICs down and combat against heat soak issues with TMICs.
These two articles highlight how proper airflow and waterspray can increase your efficiency:
Article
Article
Where do I buy a TMIC? Every Subaru/Import performance store sells TMICs. For purchasing, support your local economy or the NASIOC Vendors.
How hard is it to install a TMIC? Allow around one hour for install time. Professional installation, depending on your area, is around $75. This is one vehicle modification that is very simple and can be successfully accomplished by even the greenest shade tree mechanic.
How do I install a TMIC? Refer to the TMIC manufacturer's instructions. For TMICs without instructions, below are links to some of the better known installation instructions:
scoobymods.com instructions (for eBay models)
APS instructions
Perrin instructions
Perrin 08+ instructions
USDM STi TMIC installation
JDM Ver. 7 TMIC installation
JDM Ver. 7 TMIC installation on a 2006 WRX
08 STI installation on a 2002 WRX
Should I reset my ECU after this mod? It is never a bad idea to perform an ECU reset after a mod. The traditional route is to disconnect the negative battery terminal, press the brake pedal for a few seconds to bleed the system of charge, and reattach. Some use the more advanced Vishnu Reset.
What are some other good sources of TMIC information?
a. Bell Intercoolers' FAQ
b. ARE Cooling's tech article
Which is better a FMIC or a TMIC? There is no definate answer for this. Choose your upgraded intercooler based on the pros and cons of each and your personal goals. Perfect testing of intercoolers is not possible and though not specifically catered towards intercoolers, this Car and Driver magazine article will help point out the reasons why we will never know which is "better".
Comparative Data
Manufacturers of TMICs
APS
ARC
AVO
BPM
Buschur Racing
CSS
Cartech
Daddy's SCP
GP Moto
Helix
Hyperflow
M2
MRT
PWR
Perrin
Process West
Spearco
Speed Factor
TurboXS (utilizes a Hyperflow core)
Vishnu (utilizes a Spearco core)
Worx
XO2 Racing
2002-2007 WRX
2008-2009 WRX
STI
JDM STI (all versions)
Pressure Drop
Pressure drop can change based on manufacturer's testing levels. Generally speaking, the higher the turbo PSI, the higher the pressure drop. Manufacturers often quote the lowest testing levels and often times do not quote their test data. This means you cannot compare intercooler A VS. intercooler B.
APS: .3 PSI
ARC: Unknown PSI
AVO: .5 PSI
BPM: 1 PSI
Buschur Racing: Unknown PSI
CSS: less than 1 PSI at 14.5 PSI
Cartech: Unknown PSI
Daddy's SCP: Unknown PSI
GP Moto: Unknown PSI
Helix: .2 PSI PSI
Hyperflow: .27 PSI
M2: Unknown PSI
MRT: Unknown PSI
PWR: .8 PSI
Perrin: Unknown PSI
Process West: Unknown PSI
Spearco: Unknown PSI
Speed Factor: .81 PSI
TurboXS: Unknown PSI
Vishnu: Unknown PSI
Worx: .5 PSI
XO2 Racing: 0.2 PSI at 15 PSI
2002-2007 WRX: 2-3 PSI
2008-2009 WRX: Unknown PSI
STI (all versions): Unknown PSI
JDM STI (all versions): Unknown PSI
Flow Rate
APS: Unknown CFM
ARC: Unknown CFM
AVO: 60 lbs/min
BPM: Unknown CFM
Buschur Racing: Unknown CFM
CSS: 800 CFM
Cartech: Unknown CFM
Daddy's SCP: Unknown CFM
GP Moto: Unknown CFM
Helix: Unknown CFM
Hyperflow: Unknown CFM
M2: Unknown CFM
MRT: 650 CFM
PWR: 975 CFM
Perrin: Unknown CFM
Process West: Unknown CFM
Spearco: 1000 CFM
Speed Factor: Unknown CFM
TurboXS: 635 CFM
Vishnu: Unknown CFM
Worx: 678 CFM
XO2 Racing: Unknown CFM
2002-2007 WRX: 390 CFM
2008-2009 WRX: Unknown CFM
STI (all versions): Unknown CFM
JDM STI (all versions): Unknown CFM
Core Construction
APS: bar and plate
ARC: tube and fin
AVO: bar and plate
BPM: bar and plate
Buschur Racing: bar and plate
Cartech: bar and plate
CSS: bar and plate
Daddy's SCP: bar and plate
GP Moto: bar and plate
Helix: bar and plate
Hyperflow: bar and plate
M2: bar and plate
MRT: bar and plate
PWR: tube and fin
Perrin: bar and plate
Process West: bar and plate
Spearco: bar and plate
Speed Factor: bar and plate
TurboXS: bar and plate
Vishnu: tube and fin
Worx: bar and plate
XO2 Racing: bar and plate
WRX/STI/JDM STI (all versions): tube and fin
Physical size
APS: 20" x 7.5" x 4.5"
ARC: 18.5" X 7.5" X 2.75"
AVO: 18.3" x 7.23" x 3.5"
BPM: Unknown 20.125” x 7.625” x 4.5”
Buschur Racing: 6.5" x 18.5" x 4.5"
CSS: 20" x 11.5" x 4.5"
Cartech: 23" x 6" x 3"
Daddy's SCP: 19 7/8 " x 8" x 4.5"
GP Moto: 20.125” x 7.625” x 4.5”
Helix: 19” x 8” x 4”
Hyperflow: 19.1" x 7.3" x 4.5" (based on metric conversion)
M2: Unknown
MRT: 15.25 " x 6 " x 4.5" 19.25" x 7.5" x 4.5"
PWR: 16 x 6 1/4" x 4 3/4"
Perrin: 20" x 7" x 4"
Process West: 19.3" x 7.5" x 3.5"
Spearco: 18" x 10" x 4.5"
Speed Factor: 20" x 7.5" x 4.5"
TurboXS: 19 1/8" x 7 3/8" x 4.5"
Vishnu: 18.5" x 6.5" x 4.5"
Worx: 18.5" x 8" x 3.5"
XO2 Racing: 19 7/8" x 8" x 4.5"
2002-2007 WRX: 16.5" x 6" x 3"
2008-2009 WRX: 11" x 9.5" x 2.5"
2004-2007 STI: 20.5" x 7.3 x 4"
2008 STI: 21 5/8" x 7.5" x 3" or 3.6% more volume than older STI models
JDM STI (ver 7): 15% dimensionally larger core size than the 2004-2007 USDM STI IC
Do I need engine management/tuning with a TMIC? No. Tuning is highly encourage though as you won't see the full benefit without tuning.
Editors Note
This post was created because I wasn't able to find a good TMIC FAQ. I came up with the text based on LOTS of searching here. Upon reading this you should have an idea of whether a TMIC best suits your needs or not. The manufacturer is up to you.
If you find an error in this FAQ, please PM me with factual details and I will update this post. Responses such as, "I have XXX's TMIC and it's great!" or "XXX's TMIC broke after 1 month" are not appreciated here, that is what the Car Parts Review Forum is for.
Old 03-28-2004, 08:32 PM   #2
Bolster
Member#: 22290
2002 WRB WRX Wagon
Great informative post. I'm sure that took a while to compile.
You might fix your post with regard to the APS TMIC- its design is bar and plate.
Bolster is offline   Reply With Quote
Old 03-28-2004, 08:36 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
Nice write up. . .great job.
Calvin
cnk is offline   Reply With Quote
Old 03-28-2004, 08:42 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Thanks! You have no idea..........
Are you sure about the bar and plate? One their TMIC webpage it looks/sounds like tube and fin to me???
Old 03-28-2004, 09:13 PM   #5
Bolster
Member#: 22290
2002 WRB WRX Wagon
Yeah- it's bar and plate- the only reason I know is the ads you find for APS products in Sport Compact Car show that the TMIC and DR650 are bar and plate, while the DR500 is tube and fin.
Old 03-29-2004, 01:30 AM   #6
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
very good....make it a STICKY!
StarDogChampion is offline   Reply With Quote
Old 03-29-2004, 01:42 AM   #7
collegedropout
Member#: 42569
adds to the douchery
level round' here...
yes STICKY
well written write up, next got to get ppl to actually read
collegedropout is offline   Reply With Quote
Old 03-29-2004, 10:12 AM   #8
vile
Member#: 32371
'02 t-rex wagon
platinum
how to mount the usdm sti ic onto a wrx thread:
http://www.clubwrx.net/forums/showth...threadid=51348
this will come in handy as sti owner will no doubt go bigger
vile is offline   Reply With Quote
Old 03-29-2004, 10:54 AM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Changes have been made and thanks for the good comments. If you see any more information that needs to be added, please feel free to do so here or via PM. This thread isn't about ego, it's about accuracy, so your help is appreciated.
Old 03-29-2004, 11:04 AM   #10
Mikes Dad
Member#: 42528
02 wrx wagon
blk
Thumbs up
I was thinking about changing my tmic but i did not have enough information about the pros an cons of this upgrade.Your research on this topic has been very helpful in making my decision.Thanks for posting this,Iam sure many will learn from this.
Mikes Dad is offline   Reply With Quote
Old 03-29-2004, 07:04 PM   #11
Jon [in CT]
Member#: 2992
02 WRX Sedan
I think an important figure of merit to consider when evaluating an intercooler is its efficiency, which seems to be missing from list of data for each model intercooler. Efficiency, as a percentage, is defined as:
TIN - TOUT
_________ x 100
TIN - TAMB
Where:
TAMB is ambient air temperature,
TIN is the temperature of air entering the intercooler,
TOUT is the temperature of air exiting the intercooler.
So, an intercooler whose efficiency is 80% removes 80% of the heat added by the turbocharger and would generally be preferred over an intercooler whose efficiency is 75%.
Jon [in CT] is offline   Reply With Quote
Old 03-29-2004, 09:54 PM   #12
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Thank you for your insightful input! I did take that fact into consideration, but the only limiting factor is there is not efficiency data for TMICs that I found. You are 100% correct that this data would allow a comparative decision, but there is none that I can find on TMICs. APS does post results for their front mounts, but that doesn't help this article.
While searching for data, I did stumble upon this webpage, which lists hard data on intercooler efficiency enhancement, which I will add above. Raw numbers are:
40C (Temp into throttle body) 84.2% (efficiency) Intercooler by itself
36C (Temp into throttle body) 88.4% (efficiency) Air splitter onto intercooler
35C (Temp into throttle body) 89.4% (efficiency) Water spray onto intercooler
32C (Temp into throttle body) 92.6% (efficiency) Water spray + Air splitter onto intercooler
Also this thread with info by WRX1 provides similar results.
Old 04-01-2004, 06:33 PM   #13
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Bump for two new intercoolers added.
Old 06-25-2004, 11:55 AM   #14
RChampion
Member#: 21481
99 2.5RS
14 Impreza STI
bump for this one....
Just wondering (apologies if I missed it) when the appropriate time to upgrade your intercooler is during your upgrade path.
RChampion is online now   Reply With Quote
Old 06-25-2004, 01:06 PM   #15
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
At least include this writeup in the thread that is stickied...
wcbjr is offline   Reply With Quote
Old 11-17-2004, 02:54 PM   #16
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
another good read, thanks ron
Old 12-05-2004, 05:47 PM   #17
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
"JDM STi Version 7: 15% dimensionally larger core size than the USDM STi IC"
What does it mean? Each dimension is 15%? Volumetrically 15%
Thanks!
verc is offline   Reply With Quote
Old 12-05-2004, 06:13 PM   #18
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Volumetrically.
jblaine is offline   Reply With Quote
Old 02-28-2005, 05:11 AM   #19
mnavarro
Member#: 51537
2004 WRB WRX STI
62 Corvette/11 Cherokee L
The aps the internal core volume is (677 in3), but this does not mean it's 677 cfm....
mnavarro is offline   Reply With Quote
Old 02-28-2005, 07:15 AM   #20
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Thanks for pointing out the error.
Old 03-02-2005, 10:05 AM   #21
mnavarro
Member#: 51537
2004 WRB WRX STI
Quote from Aps on CFM
2. CFM ratings are meaningless. We do have mass flow numbers at a
given pressure drop. CFM numbers are temperature dependant and therefore
deceptive. Any form of flow figure without a corresponding pressure drop
figure, is, as I said meaningless.
3.
Our TMIC flows 37.5 lbs / min at 0.5 PSIG pressure drop. Depending
on which conversion standard you employ (and therefore temperature
assumption you make), this would be around 550 CFM.
Old 03-02-2005, 11:29 AM   #22
mnavarro
Member#: 51537
2004 WRB WRX STI
Also I'm measuring the sti and I'm getting a lot different numbers on what it is, it's core is= 18.5/7.3/3.0. The intercooler has metal flashing on the side (that may make it appear bigger than it is, but the core is only 18.5 inches wide. Most all other TMIC the core is flush with the top/bottom of the ic, where the sti/wrx the core is not. The numbers for APS are just for the core. Maybe just post core sizes?
Old 03-11-2005, 05:58 PM   #23
rewt
Member#: 60794
2007 Solstice GXP
I apologize if I should have created another thread, but I have found a discrepancy between the size you have documented for the Spearco TMIC vs. vendors.
Your FAQ has listed: 18" x 10" x 4.5"
Various vendors have listed: 6.5" x 18.5" x 4.5"
Are there two versions of the Spearco unit?
rewt is offline   Reply With Quote
Old 03-11-2005, 07:13 PM   #24
fliz
Member#: 30342
Spearco makes a TMIC as part of a 2.5RS turbo kit. It is taller and not as wide. Maybe that is the IC Unabomber found the dimensions for?
fliz is offline   Reply With Quote
Old 03-12-2005, 01:00 AM   #25
rewt
Member#: 60794
2007 Solstice GXP
I guess that's a possibility, and it definitely makes quite a difference volumetrically; it's actually pretty small compared to the others if the vendor dimensions are correct.
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 296 02-15-2016 03:16 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 317 09-03-2015 08:56 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-02-2015 11:25 PM
