Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 01-12-2013, 08:22 PM   #1
bucata206
Member#: 333333
2004 WRX
Java black
Default VF22 question
So I bought this turbo a couple months back from a guy in Wisconsin. He had a turbo blanket on it so that explains the exterior rust. Is there anything that I should do to clean it up before looking to install it? This is my first turbo swap and the car has a current tune for a VF22 that was done before I bought the car and the previous owner took the VF22 out before I bought it. Thoughts?
bucata206 is offline   Reply With Quote
Old 01-12-2013, 08:31 PM   #2
hillsboro
Member#: 84823
11 STI
05 Outback XT
He took the vf22 off and left the tune on? Did he put another turbo on or sell you the car with no turbo. Don't worry about the rust on the outside. Maybe take some CLR and clean the rust off the flange. It kinda looks like the turbo leaked and water ran in..
hillsboro is offline   Reply With Quote
Old 01-12-2013, 08:37 PM   #3
bucata206
Member#: 333333
2004 WRX
Java black
He put the stock TD04 back on. What about the small spots on the inside? There anything I should do to clean it up inside?
Old 01-12-2013, 08:41 PM   #4
hillsboro
Member#: 84823
11 STI
05 Outback XT
Cleaning the inside may be tricky. Try not to knock stuff into the turbine. If you were comfortable taking the hot side off it would be way easier to clean.
Old 01-12-2013, 08:46 PM   #5
bucata206
Member#: 333333
2004 WRX
Java black
Ya I'm not really sure how to go about doing that so if wont cause any issues I may just leave it how it is. I just didn't want to install it as is and have it cause a bunch of issues
Old 01-12-2013, 09:16 PM   #6
hillsboro
Member#: 84823
11 STI
05 Outback XT
If your not comfortable taking it apart them just run it. I am just anal about stuff but cleaning it probably isn't necessary.
Old 01-12-2013, 09:19 PM   #7
bucata206
Member#: 333333
2004 WRX
Java black
haha ok. I'm unfortunately anal about having things clean before installing but I don't want to mess it up because I got crap in the turbine...
Message Board Statistics All times are GMT -4. The time now is 03:39 AM.
