Old 03-12-2005, 01:14 AM   #26
rich22
Member#: 34662
2004 WRX Wagon
thx for faq
rich22 is offline   Reply With Quote
Old 04-15-2005, 02:19 AM   #27
wadejg
Member#: 41649
2004 Forester XTi
Does anybody remember the article in Sports Compact Car where the WRX had minimal gain/minor loss of power with JUST a bigger TMIC? I know I'm not crazy.
Thanks,
Justin Wade
2004 FXT
wadejg is offline   Reply With Quote
Old 04-15-2005, 04:23 AM   #28
ronf
Member#: 51034
03 WRX, 02Forester
Thanks,
Justin Wade
2004 FXT
I remember that in that article that bigger TMIC shift the torque/power curve to the right. Yes, more turbo lag.
ronf is offline   Reply With Quote
Old 05-01-2005, 09:21 PM   #29
EVOBOXR
Member#: 73648
It also took longer for the big intercooler to "cool" back down after heat soak...
EVOBOXR is offline   Reply With Quote
Old 08-11-2005, 02:40 AM   #30
Shavenyak
Member#: 7156
1999 Jeep Cherokee
Thanks for an excellent FAQ once again Unabomber!
Quick question: Is it reasonable (in most cases) to just multiply the dimensions of the intercoolers as listed in the FAQ to get the in^3 for each intercooler and assume that the one with the biggest volume would exchange the most heat?
--Roman
Shavenyak is offline   Reply With Quote
Old 10-28-2005, 01:11 PM   #31
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Based on all the given dimensions. I can't verify if these are "core" measurements
Code:
Volume in
%overSti (in3)	Brand	             Type
77%	716	X02 Racing	TMIC
67%	675	APS		TMIC
67%	675	SpeedFactor	TMIC
60%	650	MRT		TMIC
57%	635	TurboXS		TMIC
55%	627	Hyperflow	TMIC
50%	608	Helix		TMIC
38%	560	Perrin		TMIC
34%	541	Buschur		TMIC
34%	541	Vishnu		TMIC
34%	541	Worx		TMIC
30%	526	Spearco		TMIC
19%	483	AVO		TMIC
17%	475	PWR		TMIC
2%	414	Cartech		TMIC
0%	405	Sti		TMIC
-6%	382	ARC		TMIC
If you have verfied core dimensions post them up. According to this the e-bay special has the most volume. There's a lot more to a TMIC than volume as we all know.
crystalhelix is offline   Reply With Quote
Old 11-27-2005, 12:50 AM   #32
Alvin
Member#: 101554
2005 WRX
very helpful
Alvin is offline   Reply With Quote
Old 11-27-2005, 01:44 AM   #33
richde
Member#: 79498
2013 XV
Correct me if I'm wrong here, but there's more to how good an I/C works than just the size.
It also has to do with the ducting, if you don't have a well fitted splitter/shroud the air is going to take the path of least resistance and go around the I/C instead of through it, or through a smaller area of the I/C if you're using a smaller splitter and a huge I/C. Which would of course negate any benefits of a bigger I/C. It's not as simple as core size like an FMIC, with the top mount, we're trying to make the air make a 90 degree turn and then force it through a restricted area (the I/C) and the shroud is the crucial part of forcing the air through the restricted area.
So you can't rate an intercooler's raw effeciency, only the effeciency of an intercooler as part of a certain setup.
richde is online now   Reply With Quote
Old 11-27-2005, 10:04 AM   #34
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
Which is why he said that in his last sentence, there is more to cores than just volume.
J-Rex2004 is offline   Reply With Quote
Old 12-01-2005, 02:56 PM   #35
AUTOwrXER
Member#: 5817
2005 STi
AVO lists different dimensions on their website: http://www.avoturboworld.com/avoshop...roducts_id=124
There it is listed as 18.3 x 7.25 x 3.5 (464 in^3). It also shows two different designs in the two pictures; one with a larger bottom endtank (with the AVO logo), the other with a very small bottom endtank and the logo up top.
AUTOwrXER is offline   Reply With Quote
Old 12-01-2005, 11:02 PM   #36
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Man, I just updated this yesterday too! I'll take care of it sometime soon, thanks.
Old 12-01-2005, 11:33 PM   #37
WxMan
Member#: 22188
2003 WRX Wagon
'72 510 2dr sedan
Your two "TMIC Dyno Test" links appear to no longer work as well.
WxMan is offline   Reply With Quote
Old 02-02-2006, 04:47 PM   #38
drwrx
Member#: 50891
I can help set the record straight on the core size of the AVO TMIC as measured from mine. (this is the version that comes with the factory blow-off valve flange) 16.25 x 7 x 4.5 = 511.875 cu.
drwrx is offline   Reply With Quote
Old 04-11-2006, 04:16 AM   #39
Okita Souji
Member#: 41097
2005 WRX
FYI: JDM ver8 and 9 are both the same size as the ver7. USDM is the only STi TMIC that is smaller. I'm in Japan right now and I was able to stop by a Subaru dealership and I was able to check out one of the new STIs there.
Okita Souji is offline   Reply With Quote
Old 05-09-2006, 11:03 PM   #40
Roamin'Coyote
Member#: 24562
05 9-2X Aero black
Ron,
I think you should add something about AC line rubbage and fixes in this FAQ. Something like bending the lines out of the way, putting foam pads/zipties. Even your MAIC peeps are having issues:
http://forums.nasioc.com/forums/showthread.php?t=999829
-wYlie
Roamin'Coyote is offline   Reply With Quote
Old 05-09-2006, 11:46 PM   #41
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Originally Posted by Roamin'Coyote
Ron,
-wYlie
add one more to the list. after intallin a jdm sti ic i thought i had pushed the a/c lines back far enough. i even went as far as putting some foam insulator stuff from home depot. yeah it still cracked. entirely my fault though. so anyways i ended up installin the sti ac line($150 iirc) and rechargin the system($116). ***! i coulda spent that money on somethin else.
Bishop is offline   Reply With Quote
Old 07-27-2006, 09:41 PM   #42
The Deliverator
Member#: 42376
2006 92x Aero
Here's a tidbit you might want to include in the FAQ-
STI splitters from 02-03 seem to fit the stock scoop on 04's and 05's.
The Deliverator is offline   Reply With Quote
Old 12-31-2006, 04:10 PM   #43
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
Default tmic
i have a question for some of you people i hope that you guys can help me. I installed my tmic and now i think that there might be a pipe loose because when the turbo spools up it is just really loud and when i first put it on it didn't do it. now it is coming from the right side of the car and i hope that someone may be able to help me out. and i also want to know what i should do with the diverter valve piping back to the intake? or atleast how to plug it up. i need help this is really loud and i need to know how to fix it.
thanks
breezeby is offline   Reply With Quote
Old 12-31-2006, 05:18 PM   #44
lowranger
Member#: 124370
03 wrx stg 2.34159
Pro tuned by Cobb Tooning
thanks
might wanna start your own thread. get more response
lowranger is offline   Reply With Quote
Old 01-20-2007, 01:06 AM   #45
Mucas2K6STi
Member#: 128917
2006 WRX STi
Is there a chance of having leaner air/fuel on a stock sti, due to a bigger TMIC? I hope this wasnt covered already.
Mucas2K6STi is offline   Reply With Quote
Old 01-20-2007, 03:30 AM   #46
flukewrx
Member#: 75081
2003 WRX
If Vishnu is using a Spearco Core, wouldn't they both be the same design (Both Bar and Plate OR Both Tube and Fin)?
flukewrx is offline   Reply With Quote
Old 01-20-2007, 12:41 PM   #47
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well, I'm going to be having some fun with the stock tmic...doing a for the hell of it water to air setup using the stock tmic...I'll share what I find.
Old 01-31-2007, 01:21 PM   #48
Rippen Griffen
Member#: 91708
AD Motorsports FTW
06 OBP - Cobb AP Stg 2
Swapping a stock TMIC for a STi TMIC is a popular mod, BUT....
2007 STi & WRX BPV gaskets are different!
I swapped a '07 stock TMIC for a '07 STi TMIC this past week-end, and the stock gasket has changed. A thin "rubber" gasket is used instead of the wide "paper" gasket. Also, the stock BPV flange has been routed to hold the new thin gasket in place.
Solution: go to an auto parts store and buy some "paper" gasket, and cut out the pattern for a new gasket!
Rippen Griffen is offline   Reply With Quote
Old 07-11-2007, 12:48 PM   #49
torquemada
Member#: 128484
2006 EDM WRX STI
Old 12-25-2007, 12:14 PM   #50
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
you can add this tmic to the faq. http://forums.nasioc.com/forums/show....php?t=1273436
I'll be getting one when I go with my fp green setup.
silverwrx666 is offline   Reply With Quote
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 10:03 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 111 06-11-2016 09:28 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
