Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 03-24-2008, 02:27 AM   #51
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Default css tmic
I'm getting a css tmic and I'm wondering if tuning is going to be absolutly necessary or if cobb stg2 will work safely. Thank you.
D-Rodman is offline   Reply With Quote
Old 03-24-2008, 02:42 AM   #52
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
try checking the EM forum - Cobb
pearljam11 is offline   Reply With Quote
Old 04-05-2008, 12:53 AM   #53
lotekDBA
Member#: 163669
Good TMIC FAQ.
I have 07 STi and have access to buy JDM V7 STi TMIC, are there any fitment issues? Do I have to buy anything to make this JDM TMIC work? hows my shroud and splitters?
lotekDBA is offline   Reply With Quote
Old 04-08-2008, 03:47 PM   #54
WRXerist
Member#: 20235
2006 FX45
Subscribed+
WRXerist is offline   Reply With Quote
Old 05-08-2008, 02:26 AM   #55
zuzu89
Member#: 179489
2004 WRX
World Rally Blue
will a 04 wrx sti tmic fit on a 04 wrx with no problems
zuzu89 is offline   Reply With Quote
Old 05-08-2008, 02:42 AM   #56
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Yes, as long as you get the Y-pipe that comes with it. It will not benefit you by itself, especially on the stock turbo.
Audiosavvy is offline   Reply With Quote
Old 05-08-2008, 02:46 AM   #57
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
be prepared to fabricate y-pipe (coupler) and you also need a longer throttle hose if you want to mount it correctly...
Old 05-08-2008, 11:20 AM   #58
rayzer
Member#: 46340
Good Info. I just dropped in a USDM STi tmic in my wrx 2002. I had to get some longer hoses in order to get it to fit properly.
rayzer is offline   Reply With Quote
Old 05-12-2008, 10:50 PM   #59
snovvbrdr
Member#: 121063
2006 WRX Stg. II
Steel Gray
Did you need anything else for the swap i was thinking of doing the same swap on my 06 and do a new intercooler hose kit (http://www.rallysportdirect.com/shop...it-p-3674.html) ? or does it mount right up
Originally Posted by Rippen Griffen View Post
Swapping a stock TMIC for a STi TMIC is a popular mod, BUT....
2007 STi & WRX BPV gaskets are different!
I swapped a '07 stock TMIC for a '07 STi TMIC this past week-end, and the stock gasket has changed. A thin "rubber" gasket is used instead of the wide "paper" gasket. Also, the stock BPV flange has been routed to hold the new thin gasket in place.
Solution: go to an auto parts store and buy some "paper" gasket, and cut out the pattern for a new gasket!
snovvbrdr is offline   Reply With Quote
Old 05-13-2008, 02:51 PM   #60
elit3nemesis
Member#: 163173
2004 WRX
Stage II
Subscribed
elit3nemesis is offline   Reply With Quote
Old 05-14-2008, 11:09 AM   #61
spunAWD
Member#: 159175
02 WRX
Sticky!!!!
spunAWD is offline   Reply With Quote
Old 06-09-2008, 10:38 PM   #62
Madmike05STi
Member#: 182012
Would have made this a new post but I haven't posted my 3 legit replies yet...
I've searched all over these forums as well as the general web and I can't seem to find a straightforward answer about what to do with the IC water tank in the winter time. Three questions come to mind:
Should the water be drained from the tank to avoid possible ice expansion damage to the tank, or can the tank be left half full to compensate for the expansion?
Should the tank be drained completely during winter months?
Should antifreeze be added to the tank (is it safe to do this)?
Advice appreciated!
Madmike05STi is offline   Reply With Quote
Old 06-09-2008, 10:52 PM   #63
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
I would consider using something to drop the freezing point of the water (such as antifreeze, but wouldn't use antifreeze)
And don't use anything combustible. But seriously wintertime, there shouldn't be need for I/C spraying, so in all reality I would probably drain it or use er up and not fill it until temps warrant the need for it.....
JSarv is offline   Reply With Quote
Old 06-10-2008, 09:20 AM   #64
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Your owner's manual has your answer on the IC water spray. It says 1/2 full tank = good times. Using your IC water spray in the winter is lunacy. Adding anitfreeze is lunacy.
Old 08-20-2008, 08:39 PM   #65
AllAWD
Member#: 17079
I know it's a dead company, but I picked up an M2 TMIC
Finned area dimensions: 16.5" x 6.5" x 4.5"
Overall: 16.5" x 11" x 4.5"
Seems they had a bigger version also:
http://forums.nasioc.com/forums/show...rformance+tmic
Size: 19" x 11" x 4.5"
AllAWD is offline   Reply With Quote
Old 09-30-2008, 06:51 PM   #66
CBELL
Member#: 187424
2003 WRX
midnight black pearl
Post Is it worth it???
Everyone keeps asking about the fit of upgrading their non-sti tmic in their wrx for an sti, but if the user has very little modifications done to their car, is this a worthy upgrade?
I have the opportunity to purchase an sti tmic for cheap, but was wondering the benefits of doing so if I only have upgrade the uppipe and downpipe?
Just a green horn looking for guidance...
CBELL is offline   Reply With Quote
Old 09-30-2008, 07:58 PM   #67
AllAWD
Member#: 17079
Yes, but you need to tune for it. The stock injectors will be the limiting factor after that.
Look at TurboXS stage 3, that's exactly what I have.
Old 10-11-2008, 12:25 AM   #68
unclemat
Member#: 114530
2005 LGT 6MT wagon
Tube & fin is not accurate enough. Apparently there are three types: extruded tube & fin, folded tube & fin and plate tube & fin.
See this article: http://www.are.com.au/feat/techtalk/...e%20and%20Fin?
Bit chaotic, but has a wealth of information.
Based on the pictures I determined that stock LGT tmic (and thus 08+ WRX) is folded fin & tube design. Must be the Subaru's Nissan heritage. Supposedly very efficient in terms of cooling but having significant pressure drop.
unclemat is offline   Reply With Quote
Old 10-16-2008, 02:40 PM   #69
cmiller219
Member#: 187179
Chapter/Region: HIIC
14 STi
Cocain
can i put an sti tmic on with my wrx pipeing and elbows?
cmiller219 is offline   Reply With Quote
Old 10-16-2008, 02:53 PM   #70
skatefather
Member#: 143287
02 Wrx wagon
WRB, stage 2 and a bit
by my understanding...no. you will need new piping , or you can cut and extend samco piping.
skatefather is offline   Reply With Quote
Old 10-16-2008, 03:02 PM   #71
Audiosavvy
Member#: 150794
Qcab dakota 4x4
See post #56
Old 10-18-2008, 03:02 PM   #72
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
You own a turbo car. There is no reason not to cool the air as much as possible after the turbo heats it up. I'm sure with a stock wrx tmic, there's a lot left on the table in the cooling dept. Swapping to a larger STi TMIC along with respective sti scoop/splitter on top can't hurt. And no, you shouldn't need a tune for that. In fact re-tuning just for such a minor mod would be a bit silly.
I've never seen a factory turbo car with a completely efficent intercooler setup. In fact most are very insufficent. Talk about wasting HP.
neko is offline   Reply With Quote
Old 10-18-2008, 04:44 PM   #73
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
whoever said that the idc will go haywire if you add a sti tmic is insane..lol..
mxpunk is offline   Reply With Quote
Old 10-22-2008, 03:15 AM   #74
RankFrank
Member#: 60682
2006 WRX
There is a reason: bigger turbos have a larger pressure drop; you have to balance that against any gains you make, and frankly, if that's all you do, I doubt it's worthwhile.
RankFrank is offline   Reply With Quote
Old 10-22-2008, 03:24 AM   #75
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Cooling is one thing, but especially without tuning (which is vital in my opinion, but definitely not required) the difference in throttle response and some spool may not be worth it for many people. Sure, you'll make a little better peak power and have more consistent IATs, but there ARE side effects.
I know from my own experience the difference on a well-tuned stock turbo of the stock and an aftermarket SSAC TMIC (tuned for the stock TMIC). I lost a few hundred RPMs of spool and there was quite a decrease in throttle response and spool-up (not the RPMs, just how fast it builds boost). In my opinion. Based on my experiences, I'd wait until A. It was tuned for or B. I had a bigger turbo, before adding the larger TMIC.
I'm not saying it's not beneficial, I'm just saying that there IS a downside, and from my experience the pros don't outweigh the cons from my perspective.
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 08:49 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 317 09-03-2015 09:56 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-03-2015 12:25 AM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 291 06-30-2015 06:21 PM
