Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 11-03-2008, 07:51 PM   #76
Dstretch33
Member#: 157211
2k4 stg. 2 WRX sti
This is great information, since the next upgrade on my car will be the tmic.
Dstretch33 is offline   Reply With Quote
Old 11-07-2008, 09:18 PM   #77
WRXPRE55
Member#: 193481
2004 WRX PSM
Catless, SRI, Inlet
Correct me if I'm wrong anyone, but I bought a TMIC off ebay with the same dimensions and cfm as the CSS. And unabomber's psi drop is accurate it is under 1 psi@14.5, but the company I bought it from (CX Racing) rated it at .02-.04 @15psi and 3-5 at 38psi(like any subaru will ever see 38psi)... hope this is accurate if not ffree shot to the balls is welcome.....
WRXPRE55 is offline   Reply With Quote
Old 01-24-2009, 02:31 PM   #78
OneBadPig
Member#: 181858
04 WRX
SRR
Originally Posted by Audiosavvy View Post
Yes, as long as you get the Y-pipe that comes with it. It will not benefit you by itself, especially on the stock turbo.
I have searched but am unable i figure out if an STi tmic would a performance loss if paired with the stock turbo.
For example, i am shopping for a turbo/injector/tmic upgrade. If i find a cooler first and go ahead and install it before i get the turbo, will there be a pressure loss?
OneBadPig is offline   Reply With Quote
Old 04-07-2009, 06:00 AM   #79
Bpipp
Member#: 205671
2007 wrx
i have a 07 wrx tr and the tmic is not what it states for an 02-07. it is more like 19"x4"x2.5" core dimensions without endtanks. i think this is the same for the 06's as well, correct me if i am wrong.
Bpipp is offline   Reply With Quote
Old 04-07-2009, 06:00 PM   #80
dimswits
Member#: 160342
02 E46 Coupe
Pressure drops are created by restrictions. The STI TMIC has more flow area than the stocker, not less (think of it like a larger diameter pipe). Thus, no increased pressure drop.
dimswits is offline   Reply With Quote
Old 04-15-2009, 11:13 PM   #81
Nor-Cal'N
Member#: 192190
I am wondering about the small tank thing in the engine bay (here circled in red). It looks like it connects to the TMIC and you put fluids inside it.
I dont have an owners manual but what kind of fluids do you put in it, and how much? Do you top it off or fill it half way?
Nor-Cal'N is offline   Reply With Quote
Old 04-15-2009, 11:30 PM   #82
saab-on-the-cobb
Member#: 116330
2005 Ram SRT-10
Sex Silver
No. The STi intercooler will be fine until you complete your upgrade path.
Anything bigger, though, and you'd really want to tune for it (i.e. - an eBay TMIC or APS, etc.).
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 04-15-2009, 11:31 PM   #83
saab-on-the-cobb
Member#: 116330
2005 Ram SRT-10
Sex Silver
Sorry. I HAD to lol at this one.
I'll take it easy on you.
That's coolant. It does not touch the IC.
SOTC
Old 04-15-2009, 11:37 PM   #84
Nor-Cal'N
Member#: 192190
Thats what I thought haha but my dad was 100% confident that it was connectd to the TMIC. Thanks haha.
Old 05-21-2009, 10:56 PM   #85
sleepyfu
Member#: 124219
2004 W(agon)RX
Thought the 06/07 wrx had a different shape of TMIC, not sure if the total volume is different but it uses the outer mounting hole on the passenger side.
sleepyfu is offline   Reply With Quote
Old 06-18-2009, 04:25 PM   #86
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Here is response from TurboXS regarding their TMIC.
"When we test them at our facility there is about 1 psi of pressure drop
Jermaine Riddick
Director of Sales & Marketing
www.turboxs.com
301-977-4727"
txl146 is online now   Reply With Quote
Old 06-18-2009, 08:10 PM   #87
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
when upgrading to aftermarket topmounts where/what do you do to mod the vacuum hose line that usually attaches to the front of the stock i/c setups. turboxs rep said that with their i/c (topmount) the hose is relocated to run under the throttle body intake and does not attach to the i/c? anyone have a pic of this? or anyother after market application w/ modification of this line
thanks
Mark
krambte79 is offline   Reply With Quote
Old 06-18-2009, 11:36 PM   #88
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
thanks
Mark
I would like to see the picture also...
Old 12-11-2009, 10:45 PM   #89
toofast4urass2
Member#: 185337
great info
toofast4urass2 is offline   Reply With Quote
Old 01-09-2010, 06:02 PM   #90
beedee
Member#: 124727
i recently put an STi tmic on my wrx, and swapped hood scoop splitter/bellows as well.
here is a brief write up i did, showing the differences in the scoop splitters/bellows...
this first pic shows the STi tmic (duh):
once i removed the wrx hoodscoop splitter/bellow, i placed it on top of the STi tmic so you can see how much smaller it is, and how much of the STi tmic is not being utilized due to the smaller wrx splitter/bellow:
here is the STi hoodscoop splitter/bellow resting on top, as you can see, a perfect seal:
now here are the two splitters side by side; STi on the left, wrx on the right. you notice that the STi one has a piece in the middle to deflect air to the lower part of the tmic:
install was a breeze, simply remove the 7 (seven) 8mm bolts, and the one plastic clip and gently pop the splitter piece off. align your new one to the holes, insert the two little tabs at the bottom and install the bolts, then plastic clip. it took me about 10 minutes.
beedee is offline   Reply With Quote
Old 01-25-2010, 06:20 PM   #91
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Bump, will a GD intercooler (or GD specific for aftermarket) fit on a GC?
This will be on a Version 4 STi.
Smoke is offline   Reply With Quote
Old 01-26-2010, 10:02 AM   #92
devilbones
Member#: 235057
2006 M3 ZCP
Carbon Black
Thanks for the great writeup.
devilbones is offline   Reply With Quote
Old 01-26-2010, 02:39 PM   #93
neko
Member#: 46500
Now with 100% more
room 4 girl-on-girl fun.
I believe would will encounter issues with the fitment where the IC connects to the throttle body. The newer WRX/STi used a different shaped intake manifold than the older GC WRX/STi setups. Now, if that is the case, i think this could be remedied by using a newer manifold, or positioning your IC differently. (different brackets/longer hose from turbo...)
While i have no personal experience with the issue (never did get that newer sti IC put on my old V5 car before i sold it), the current owner of my V5 STi is having to deal with the issue and we've talked a bit about it.
So, in the end, take it with a bit of salt, i could be wrong.
neko is offline   Reply With Quote
Old 05-15-2010, 07:41 AM   #94
Rich#
Member#: 200062
great info.
but anyone know if i install mount the aps tmic , the original spec c strut bar mounts yet ?
Rich# is offline   Reply With Quote
Old 06-05-2010, 12:00 AM   #95
summers
Member#: 223344
05 Forester Xt 5sp
CGM
are there any photos of the passanger side bracket from an 08-09 STI TMIC used for a 08-09 TMIC swap.
summers is offline   Reply With Quote
Old 07-04-2010, 10:23 PM   #96
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Is this type of mislocation of the mounting tabs common for aftermarket TMIC?
Passenger side comparison stock on top, Spearco on bottom.
Driver side comparison stock on top, Spearco on bottom.
The TMIC I had from vishnu on my 2004 fit properly.
turboICE is offline   Reply With Quote
Old 07-22-2010, 01:56 PM   #97
balls2dawalls
Member#: 248432
06 VF39 WRX TR
San Remo Red
Great write up! But I am still fuzzy on what I'll need for installation in my WRX. I have an STI TMIC and a vf39... I am told that the factory sti piping from the intercooler should reach just fine if pairing with the vf39. Is this right?
balls2dawalls is offline   Reply With Quote
Old 08-21-2010, 03:38 AM   #98
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
I have the exact same fitment problem with my Spearco's. I actually have both versions. The STI and WRX and they both suck when it comes to fitment. One is too far forward, the other is too far back. Even if you try to fit the STI version on an WRX (and vice versa) it doesn't fit properly.
I don't know what test car Spearco used to measured their Subaru TMIC's fitment for, but it wasn't any production model.
Fierysun is offline   Reply With Quote
Old 08-22-2010, 10:49 PM   #99
toph
Member#: 78640
08 STi 3.5XT-R
15 STi CWP | 02 STi Wagon
Ok, so I searched this but couldn't find anything. I may start my own thread if I don't get many answers. I am looking to upgrade to an STi top mount on my 04 WRX and was wondering if the stock BPV from my WRX will bolt right up to the STi top mount? Any help/opinions will be greatly appreciated.
toph is offline   Reply With Quote
Old 08-22-2010, 10:50 PM   #100
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Yes. If by BPV you mean recirculating valve.
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 310 01-06-2015 08:27 AM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 290 12-20-2014 03:11 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 370 11-11-2014 05:51 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 108 01-25-2014 02:28 AM
