Old 02-06-2012, 04:50 PM   #126
Po12no
Member#: 302281
2012 STI
Anyone got spec on the Godspeed top mount?
Po12no is offline   Reply With Quote
Old 02-26-2012, 11:21 AM   #127
davidmount
Member#: 173026
2003 WRX
Okay from page one the V7 STI intercooler is 15% larger volumetrically - how does it compare physically in size to the USDM STI intercooler. I read the USDM intercooler is smaller. I ask because I have the V7 STI hood scoop and splitter. Waiting to install, but want to know if I need to but a V7 intercooler from Japan or if a USDM STI intercooler will fit correctly with the V7 splitter.
davidmount is offline   Reply With Quote
Old 02-26-2012, 03:06 PM   #128
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
V7 splitter won't work with USDM intercooler, you must match components.
Old 04-03-2012, 10:25 PM   #129
11wrx_dude
Member#: 311747
2011 wrx
white
I understand that you won't see the full potential of a tmic without engine management. But is it bad for the car In any way ?
11wrx_dude is offline   Reply With Quote
Old 04-20-2012, 12:42 PM   #130
DaveC113
Member#: 126901
2010 WRX 5 Door
Are any STi TMICs drop-in replacements for the '09+ WRX?
DaveC113 is offline   Reply With Quote
Old 04-20-2012, 02:00 PM   #131
bad mutha
Member#: 106747
04 forester xt
crp
^^^ no!!!
bad mutha is offline   Reply With Quote
Old 04-20-2012, 02:32 PM   #132
DaveC113
Member#: 126901
2010 WRX 5 Door
Originally Posted by bad mutha View Post
^^^ no!!!
Cool, thanks!
Old 05-16-2012, 08:21 AM   #133
wayward167
Member#: 253998
13 BRZ
I think the advise for 08+ owners should be revised in light of end tank issues at or slightly over stock boost levels and the pathetic cooling capacity as compared to previous versions....
From my experience as well as several others with the newer wrx's I think a tmic should be part of any plans past stg1...
My $.02
wayward167 is offline   Reply With Quote
Old 01-12-2013, 11:09 PM   #134
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
Is there an aftermarket TMIC that is about the size of the stock one? (2002 WRX)
Daddy_Digital is offline   Reply With Quote
Old 01-13-2013, 12:39 AM   #135
AllAWD
Member#: 17079
The old Hyperflow core built and sold by M2 and TXS (old version) was a thicker intercooler with the same length/width dimensions at the stock TMIC. Both have been out of production for a long time.
The 02 has mounting points to fit the larger STI size TMIC so there's no reason to limit yourself to something that will be very hard to find.
AllAWD is offline   Reply With Quote
Old 11-04-2013, 11:22 PM   #136
ezil71
Member#: 207118
2003 Wrx Wagon
Does anyone know if the grimmspeed splitter will work with a turboxs tmic on a bugeye?
Or any other splitter that fits?
Grimmspeed gave the 'we can only confirm it fits our tmic' and turboxs claims 'you don't need a splitter' but I don't see how running without one would work well.
ezil71 is offline   Reply With Quote
Old 11-05-2013, 12:38 AM   #137
golfsierra
Member#: 342917
Platinum Silver Metallic
I'm not running anything other than stock, with the rubber "shielding" removed on my scoop assembly dealy, seemed to work just fine with my TurboXS top mount.
golfsierra is offline   Reply With Quote
Old 12-09-2013, 01:46 PM   #138
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
Anyone have any experience with the cxracing tmic off ebay? seems to be one of the better 'brands'. And also, what splitter should I use, I'm guessing my stock WRX splitter won't work with it or be as optimal as an STi splitter? or will it need some modification to fit?
Bak3rSkat3r is offline   Reply With Quote
Old 11-16-2014, 08:59 AM   #139
imjohn_subaru
Member#: 399228
Can I run a short ram intake and sti tmic with no problem
imjohn_subaru is offline   Reply With Quote
Old 07-30-2015, 11:14 PM   #140
Mugs
Member#: 422865
2005 Turbo Baja
Yes , I have an SPT intake along with an STI TMIC on my 05 Baja turbo (EJ255) When I ran the silicone intake boot I had to bolt the intake directly to it. Which shortened it even more by about 4 inches because the SPT intake boot would not fit over the inlet ring....Hope that all makes sense.
Point is NO CEL, and it works fine.
Mugs is offline   Reply With Quote
Old 02-23-2016, 08:54 PM   #141
CNC_Geek
Member#: 417990
2001 Legacy - GTB
red
Default Mid engine air flow through the IC
My build is somewhat unique. I have an STI drive train mounted mid engine style. Getting air flow through the stock intercooler is a challenge.
I'm wanting to know how much air needs to flow through the cold side for the IC to work properly. Of course more is better but how much CFM is adequate? I'm thinking about using a blower to force cold air through the IC. Will I need 200CFM, 500CFM, 1000CFM? I'm just driving around town and once in a while I put my foot to the floor. No sustained racing. Ever see any numbers on this?
CNC_Geek is offline   Reply With Quote
Old 02-24-2016, 09:49 AM   #142
DearDiaryJackpot
Member#: 343041
2013 sti
white
Everything is on the first page:
http://web.archive.org/web/200312022...er_sizing.html
DearDiaryJackpot is offline   Reply With Quote
Old 03-18-2016, 10:39 PM   #143
UrdnotWrexSTi
Member#: 411357
2008 STi
Default TMIC FAQ: Read if you are thinking of buying one!
Has anyone fitted a Spearco TMIC on the GR STi with a 20g turbo? The compressor housing is larger and the boost reference point is on top of the housing... This TMIC is freaking huge, so I just want to see if anyone had fitment issues before I buy one!
UrdnotWrexSTi is offline   Reply With Quote
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 10:03 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 111 06-11-2016 09:28 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
