Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds
Old 03-28-2004, 09:04 PM   #1
silvscorp
Member Sales Rating: (10)
Member#: 28480
Default FS SBC-ID optional harness, ROTA CF wheel cover, OEM springs, shifter, ram intake
stock springs(10k miles) great condition, asking $60 shipped
stock shifter $30 shipped
Intake velocity stack. (the intake piece under the hood that connects to the elbow in the fender) $25shiped
Blitz SBC-ID optional harness (can display 3 extra readings from ecu. Water temp, oil temp, Throttle position, intake air temp, conceptual AF ratio, etc) $30 shipped
thanx
silvscorp is offline   Reply With Quote
Old 03-29-2004, 06:01 PM   #2
silvscorp
Member#: 28480
bump bump
Old 03-29-2004, 06:43 PM   #3
aawen
Member Sales Rating: (3)
Member#: 27167
09 Impreza
Pmed you
aawen is offline   Reply With Quote
Old 03-29-2004, 09:44 PM   #4
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
Do you have to splice into the ECU to get the extra readings to the harness?
SupaSizeFries is offline   Reply With Quote
Old 03-29-2004, 09:53 PM   #5
silvscorp
Member#: 28480
yes, it's basically 3 wires and each one is for a data reading.
You can get any 3 readings of your choice, but make sure the source must have a linear voltage output. For example, -5 volt for the minimum reading and +5volt is the max reading.
Old 03-30-2004, 11:59 PM   #6
silvscorp
Member#: 28480
bump
Old 03-31-2004, 12:50 AM   #7
silvscorp
Member#: 28480
update
Old 04-03-2004, 06:55 AM   #8
silvscorp
Member#: 28480
early morning bump!!
Old 04-05-2004, 12:39 PM   #9
silvscorp
Member#: 28480
tttt
Old 04-05-2004, 10:02 PM   #10
luvmyrs
Member#: 1048
2000 Nothing, thanks
to POS thieves.
where in NJ are you located? If possible, I would like to take a look at the SBC-ID harness before I make any commitment.
Frank
luvmyrs is offline   Reply With Quote
Old 04-08-2004, 11:11 PM   #11
silvscorp
Member#: 28480
need to sell these!!
Blitz SBC iD Optional Harness wiring? WolfDrive Electrical & Lighting 0 12-15-2003 05:33 PM
SBC-ID optional harness question pico Factory 2.0L Turbo Powertrain 3 09-05-2003 07:00 PM
sbc-id optional harness byrdman Electrical & Lighting 5 05-08-2003 11:41 PM
SBC ID optional harness! linus011 Factory 2.0L Turbo Powertrain 7 03-19-2002 10:35 AM
SBC-id Optional Harness q's DreamWalker Factory 2.0L Turbo Powertrain 11 12-16-2001 09:35 AM
Message Board Statistics All times are GMT -4. The time now is 06:03 AM.
