Old 03-28-2004, 10:19 PM   #1
ClimbinNBouldern
Member#: 50108
2000 2.5RS
BRP
Default dead spot?
after installing my exhaust (stromung cat back) about 2 weeks ago i seem to have a dead spot in my acceleration.
this only is noticeably to me in 2nd and 3rd gears, the engine seems to rev slower from approximatley 3500rpm - 4500 rpm and then pulls hard again. Only noticebale under 1/2 throttle to WOT. Any ideas?
Thanks,
Tom
p.s. i plan to install an underdrive pulley soon along with my CAI whenever they are off backorder. will this help at all?
ClimbinNBouldern is offline   Reply With Quote
Old 03-28-2004, 11:00 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the dead spot is common. Just more amplified with mods.
You can try doing a grounding mod to see if it helps to clear it up.
Did you reset the ECU when you put the exhaust on?
Jay
Old 03-28-2004, 11:25 PM   #3
ClimbinNBouldern
Member#: 50108
2000 2.5RS
BRP
I already have a Grounding mod (just forgot to mention)
I though ti reset my ECU (stepped on brakes), but am not sure now
Old 03-29-2004, 02:53 PM   #4
obyone
Member#: 16523
Jay
If I'm not mistaken, it's an issue with the design of the intake manifold. Supposedly, at those RPM range, the manifold has some kind of funky reverberation that causes the dip in torque.
obyone is offline   Reply With Quote
Old 03-29-2004, 04:37 PM   #5
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I think it's the exhaust, as I don't notice it with the mrt headers + high flo cat.
AO
m750 is offline   Reply With Quote
Old 03-29-2004, 09:57 PM   #6
obyone
Member#: 16523
AO
Not that my friend as I have the MRT header with high flow cat and I still get it in the midrange. It almost feels like my car mis-fired in 1-2 cylinders. Thats how noticable the power loss is.
Old 03-30-2004, 12:02 AM   #7
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Yeah - I have it too. WRX cat-back, Borla headers......I've just accepted it by now!!
Garret
Ghomer1 is offline   Reply With Quote
Mid-Range Dead Spot FUNKED1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-30-2004 04:26 AM
Dead spot or resistance in the STi power steering rack KoneKiller Brakes, Steering & Suspension 2 11-19-2003 10:12 AM
'96 Legacy Outback Accelerator dead spot Geoffman72 Outback Forum 0 09-22-2003 02:31 PM
Boost control dead spot pilam96 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-15-2002 05:31 PM
Dead spot at 4,000 RPM? The Wraith Normally Aspirated Powertrain 14 07-17-2001 10:38 PM
