Old 03-29-2004, 12:05 PM   #1
Kevin67
Member#: 58088
2004 WRX STI
Default Door Panel Removal on an 04 STI
Does anyone know of a link that describes how to remove the door panles on an STI? I was trying to get an idea to view the process before I went and ripped it apart.
Kevin67 is offline   Reply With Quote
Old 03-29-2004, 12:15 PM   #2
vf39hipsi
Member#: 55794
it's pretty easy
Fronts:
1. Remove plastic ring that goes around the latch handle.
2. flip up cap on grab handle and remove that screw.
3. Pull out grab handle
4. Remove panel with window controls and disconnect wiring.
5. Remove screw that is underneath the grab handle and window controls.
6. Starting from the bottom, carefully pop out the plastic pins by pulling on the door panel (Carefully is important).
7. Once those are popped out lift the panel upwards and it will release from up near the window.
8. Do all that backwards to put it back on.
Rear:
- rears are the same except you need to remove the screw at the rear top of the door (where it meets the door jam), take out the screw and remove the plasticit screws into. Also, there is no need to remove the window controls in the back, just unplug them once the panel is free and you can get your hand back there.
vf39hipsi is offline   Reply With Quote
Old 03-29-2004, 12:18 PM   #3
Kevin67
Member#: 58088
2004 WRX STI
thanks
Old 03-29-2004, 12:28 PM   #4
jlitch
Member#: 38566
2006 sti
aspen white
i've got detailed instuctions with pictures if you need em.
jlitch is offline   Reply With Quote
Old 03-29-2004, 12:48 PM   #5
Kevin67
Member#: 58088
2004 WRX STI
That would be great, the pics are what I really wanted to get the visual of where things were on the backside of the panel
Old 03-29-2004, 02:02 PM   #6
Kevin67
Member#: 58088
2004 WRX STI
Old 03-29-2004, 02:11 PM   #7
brunetmj
Member#: 8023
2004 2.5 RS
This is actually the most difficult part of the task. I mean to do so without breaking them. There was a thread recently in the audio section which gave suggestions of how that is done without breakage. The manual says Pull it toward you to get the upper clips and pull it downward to get the lower clips. However it is pretty tricky.
brunetmj is offline   Reply With Quote
Old 03-29-2004, 06:04 PM   #8
wannaSTi
Member#: 45021
2004 WRX STi
Java Black / Silver
Check out this gallery, I used it to do my install.
IA Performance
wannaSTi is offline   Reply With Quote
Will 06+ Door panels fit on an 04? roybfr Interior & Exterior Modification 2 05-27-2007 01:24 PM
Replacing Door Lock Cylinders on an 04 WRX Wagon mzdrati Interior & Exterior Modification 0 12-26-2006 03:46 PM
Exterio door panel removal on '02-'05 Impreza? Nikko Interior & Exterior Modification 19 03-23-2005 12:38 AM
Passenger Door lock switch on an '04 STI TheMutineer Electrical & Lighting 0 06-01-2004 08:55 PM
Door Panel Removal on an 04 STI Kevin67 Car Audio, Video & Security 10 04-04-2004 10:11 PM
