Old 03-29-2004, 02:19 PM   #1
Kevin67
Member#: 58088
2004 WRX STI
Subaru Stars Door Panel Removal on an 04 STI
Does anyone know of a link that describes how to remove the door panles on an STI with pictures? I was trying to get an idea to view the process before I went and ripped it apart.
Kevin67 is offline   Reply With Quote
Old 03-29-2004, 02:31 PM   #2
Tacoboy
Member#: 56866
2004 WRX STI
http://www.iaperformance.com/gallery...olderNumber=19
I just installed some speakers yesterday using these instructions and they seemed to work just fine.
Tacoboy is offline   Reply With Quote
Old 03-29-2004, 02:57 PM   #3
Kevin67
Member#: 58088
2004 WRX STI
Sweet thanks.
Just what I was looking for so between that
http://www.iaperformance.com/galler...folderNumber=19
and this noone myself and noone else should have any prob
it's pretty easy
Fronts:
1. Remove plastic ring that goes around the latch handle.
2. flip up cap on grab handle and remove that screw.
3. Pull out grab handle
4. Remove panel with window controls and disconnect wiring.
5. Remove screw that is underneath the grab handle and window controls.
6. Starting from the bottom, carefully pop out the plastic pins by pulling on the door panel (Carefully is important).
7. Once those are popped out lift the panel upwards and it will release from up near the window.
8. Do all that backwards to put it back on.
Rear:
- rears are the same except you need to remove the screw at the rear top of the door (where it meets the door jam), take out the screw and remove the plasticit screws into. Also, there is no need to remove the window controls in the back, just unplug them once the panel is free and you can get your hand back there.
Old 03-29-2004, 03:09 PM   #4
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
We'll be adding the rear door removal instructions later on today. Only amendment from the fronts is that there is a small plastic phillips gromet on the back edge that needs to be removed.
Stephen
www.IAPERFORMANCE.com
Subaru Audio Upgrades, click the radio
IA Performance is offline   Reply With Quote
Old 03-29-2004, 07:41 PM   #5
krayge
Member#: 55651
2004 Impreza WRX
Platinum Silver
holy ****....ok, dude you have got some business comin your way from me soon. :P and just to make sure....you say the large-thick mount rings will work with type-r door speakers, right? i'm prolly gonna go with a full alpine setup, and have been very curious about the fitment in the door speakers, since i have heard horror stories about how little room the stock gives you.
krayge is offline   Reply With Quote
Old 03-29-2004, 07:56 PM   #6
IA Performance
Member#: 25194
Dark Gray
The type Rs are a bit tight in there IMO. Customers have spaced out the door panel a bit to allow for their added size. If possible I would go smaller than the Type R for ease of install.
Stephen
Subaru Audio Upgrades, Click the Subaru
Old 03-29-2004, 08:02 PM   #7
krayge
Member#: 55651
2004 Impreza WRX
Platinum Silver
grr...do the type-s fit ok? kinda wanted to stick with a single setup on my whole system and i'm puttingin 2 type-r 10s (still gotta figure out the box design...ugh) and wanted to stick with the type-r's in the door, but i guess since you can't actually see the darn things without doin some custom door panels (HATE HATE HATE that slanted cut on the mesh in the doors) i guess it doesn;t specifically matter the type in the door as long as they sound decent.
Old 03-30-2004, 10:08 AM   #8
RedBean
Member#: 23132
2004 Impreza WRX STi
World Rally Blue Pearl
So the proper way of removing the door handle bezel is to pull off the door skin first? And it will just pop out without breaking?
RedBean is offline   Reply With Quote
Old 03-30-2004, 11:07 AM   #9
IA Performance
Member#: 25194
Dark Gray
It pops off without breaking about 9 times out of 10. 10 out of 10 if you are slow. You'll know you pulled off the door panel to quickly if the bezels shoots off. It should pop up and then be removed by hand. We now offer replacement bezels at very affordable prices for those who were the 1 in 10 person
Simply click on the photo below that you would like and you'll be directed to our 'Specials' page. Items will be shipped via USPS mail and will take 4-6 business days to arrive. Prices include shipping.
Driver side
Pass side
Stephen
Old 03-30-2004, 01:22 PM   #10
WHTSTirex
Member#: 48270
2003 CBR600RR
i just got my alpine type S installed yesterday in my STi. had to directly bolt the 1/2 inch spacers to the door to get the speakers to clear the door panel. not too mention barely missing the windows. but they do work. and they do fit.
WHTSTirex is offline   Reply With Quote
Old 04-04-2004, 10:11 PM   #11
terrorofvalhalla
Member#: 58239
2003 Imprezza Wrx
In a wagon, how about the inner lining of the tail gate and the lining of the rear cargo area?
terrorofvalhalla is offline   Reply With Quote
Will 06+ Door panels fit on an 04? roybfr Interior & Exterior Modification 2 05-27-2007 01:24 PM
Replacing Door Lock Cylinders on an 04 WRX Wagon mzdrati Interior & Exterior Modification 0 12-26-2006 03:46 PM
Exterio door panel removal on '02-'05 Impreza? Nikko Interior & Exterior Modification 19 03-23-2005 12:38 AM
Passenger Door lock switch on an '04 STI TheMutineer Electrical & Lighting 0 06-01-2004 08:55 PM
Door Panel Removal on an 04 STI Kevin67 Interior & Exterior Modification 7 03-29-2004 06:04 PM
