Old 03-29-2004, 05:10 PM   #1
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
Default whine 2 tones loose belt?
When my car idles and revs under 2K I hear a whinning sound. I think it most likely can be the cause of a loose belt because of when installing my UD Pulley the belt slipped once or twice. The noise is very very annoying and I wanna know if it can cause any damage if I leave it on for another week or so because I don't have much time on my hands to get a smaller belt. btw it's been doing this for about 3 days and is progressivly getting worse.
-Matt L
2.5RSMatt is offline   Reply With Quote
Old 03-29-2004, 05:45 PM   #2
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
i had that whining when i installed my udp too. i got it fixed and just lately it started again only when i have my lights on at night though! its a loose belt. it is very annoying!
darioc is offline   Reply With Quote
Old 03-29-2004, 06:20 PM   #3
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
did a new smaller belt fix the issue? I know I need a new one because its fully cranked and tightened and still isn't as tight as it should be.
Old 03-30-2004, 12:03 AM   #4
darioc
Member#: 35695
02 RST
you need smaller belts when you get a udp. it should of listed possible choices in the directions that came with the pulley. yes, they are smaller, significantly. you didn't install different, smaller belts with the pulley?
Old 03-30-2004, 12:06 AM   #5
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
I installed belts from a buddie who has an L. The issue was we couldn't get out to get a new belt and the one he had fit but only to a certain point, but a lot better than any big stock belt. I've only heard it majorly slip twice but otherwise it's just started to do this noise.
Know if it's terribly bad to leave it making to noise for more than a couple days?
Old 03-30-2004, 12:17 AM   #6
darioc
Member#: 35695
02 RST
well i would just get new belts. im sure its not good. i have to get my noise fixed too.
2 tone or no 2 tone that is the questions olsonauwrx North West Impreza Club Forum -- NWIC 28 07-08-2009 12:01 AM
Loose belts jcan0045 Factory 2.5L Turbo Powertrain 0 02-13-2007 11:37 AM
So CAL: Gauging interests Stage 2 02' WRX wagon 2 tone paint, extras. unfadeable wagon Private Vehicle 'For Sale' Classifieds 11 01-16-2006 06:33 AM
Chirp/squeak a loose belt? Chewy-WRX Service & Maintenance 81 08-03-2005 04:37 PM
Loose belt or alternator on last leg? grindMARC Electrical & Lighting 2 01-28-2004 11:05 PM
Message Board Statistics All times are GMT -4. The time now is 04:34 AM.
