Welcome to the North American Subaru Impreza Owners Club Sunday December 28, 2014
Old 03-29-2004, 09:50 PM   #1
bhamwrxman
Member#: 43111
2008 Impreza 2.5i
Default Help needed from the Scooby Guru's
OK Here is the rundown. Sotck clutch just replaced under TSB for clutch shudder. I has Subaru use the parts I bought instead of the ones listed on the TSB. The parts used were and Exedy Organic Clutch Kit paired with an Exedy Lightweight Flywheel.
Got the car back, and the clutch feels light as air. I also notice that it isn't grabbing very hard, almost softer than my stock clutch. The engagement points are the same too. The clutch grabs when the pedal is about 1 inch from all the way out. I figure, ok, it just needs ot break in and seat against everything and it will be ok.
500 miles of city driving later, I put my new uppipe and downpipe on. It pulls harder and I like the new feel. Well, I decide to get on it from a dead stop and watch the RPM's shoot up and bounce off the rev limiter a few times. The inside of my car is instantly filled with a burnt clutch smell.
Now for my question. Could the guys at Subaru forgot to bleed to clutch and that is causing the long engagement? Or could it be a slave cylinder or something like that? And if it is the slave cylinder, wouldn't they notice it when they put the new clutch in? And, is there a quick fix for any of this? Motors I can do, but I am clueless with transmissions. Any info would be appreciated. I would just like some input before I go back to Subaru and chew some butt.
bhamwrxman is offline   Reply With Quote
Old 03-29-2004, 10:43 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Hydraulic clutches are self-adjusting, and replacing the clutch does not require cracking open even the clutch MC, let alone bleeding the system.
Brian
Old 03-29-2004, 11:44 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Besides which, a hydraulic system failure would produce the opposite symptoms. There would be less pressure in the system resulting in a lower clutch engagement, not higher, and possibly difficulty getting into gear and shifting. It would not cause clutch slippage.
Old 03-30-2004, 09:11 AM   #4
bhamwrxman
Member#: 43111
2008 Impreza 2.5i
So did I just get a bad batch of parts?
Did Exedy change their parts? I had the flywheel for about 6 months before I got the clutch.
Help needed from the RMIC overlord Rocky Mountains Impreza Club Forum -- RMIC 7 11-05-2009 09:47 PM
Need help from the vin guru's scrappydoo Subaru Conversions 28 04-28-2007 06:57 PM
I need help moding from the local calgary suby community. Canadian 2.5RS Canada Region Forum 10 07-10-2005 05:39 PM
Help from the 4EAT Guru's. vitaminwrx Transmission (AT/MT) & Driveline 4 11-16-2004 01:16 PM
Emergency Help maybe needed from the Las Vegas folks. Dorkfish South West Impreza Club Forum -- SWIC 2 08-06-2003 01:01 PM
