Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 03-29-2004, 09:23 PM   #1
rwheelz
Member#: 56697
2008 STI
Default where to get stereo installed in houston, and where to put amps in wagon?
Can anyone recommend a good local installer?
Or which speakers I should put in the doors?
Or where to mount amps in a wagon? I have one amp and 2 subs, that are slim so I plan to mount them right on top of the spare basically. I am going to cut out that bottom tray to fit them in. But amps..? I dunno where they will go.
rwheelz is offline   Reply With Quote
Old 03-29-2004, 10:19 PM   #2
LiquidIQ
Member#: 6408
2014 FiST 2004 MSM
Race Red & Velocity Red
I put my amps underneath the driver and passenger seats.
LiquidIQ is offline   Reply With Quote
Old 03-29-2004, 10:24 PM   #3
XXeR1979
Member#: 9813
2008 sierra denali
1986 951
i mounted my amp on the back of the rear seat.
-Marty
XXeR1979 is offline   Reply With Quote
Old 03-29-2004, 10:48 PM   #4
metoo
Member#: 4764
2004 STi sold :(
forizzle
what size subs?
Are they free-air?
The spare well does not make a good enclose. You can however make a nice enclosure that fits in your spare tire. If you have free-air subs (or subs with smallish magnets and are shallow), you can get away with no enclosure, but I suggest a stiffer baffle (part you actually screw the subs to) than just the wheel well door alone.
metoo is offline   Reply With Quote
Old 03-29-2004, 10:50 PM   #5
Member#: 11441
2002 austin, tx
fishy
to make a free air (infinite baffle) setup work you need to totally separate the front of the woofer from the back. for all practical matters you'd need to have a trunk of some type, just throwing it in the spare tirewell attached to a baffle wouldnt work very well. youll need to make some sort of sealed enclosure for your subs.
m@stro is offline   Reply With Quote
Old 03-30-2004, 09:07 AM   #6
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
i can install it
put the amps under the seats
as far as the speakers go, two will shake your insides. i have one in a band pass style box and it will give you a headache. the wagons are set up nice for the sound.
Wheeler Bement is offline   Reply With Quote
Old 03-30-2004, 10:33 AM   #7
BlkTS02
Member#: 50142
2002 2.5TS
MBP
I've got my amp mounted to the underside of the spare tire cover, running two 8" subs in slim boxes on long wires so I can move them around depending on what I'm carrying. Good luck
BlkTS02 is offline   Reply With Quote
Old 03-30-2004, 11:16 AM   #8
Prairie Dawg
Member#: 16598
'09 Civic Si
Redline Orange
"Or which speakers I should put in the doors?"
You can mount 6-1/2" speakers in the front doors...5-1/4" in the rears. I used spacers from www.iaperformance.com to install the front speakers, and dremeled the rear cutouts to accept the 5-1/4" speakers. Pretty easy, really...
" mounted my amp on the back of the rear seat."
I'm going to mount mine on the back of the driver's side back seat, myself. I have a 400W amp to drive the door speakers, and a 240W mono amp for a sub. I'm hoping they'll both fit on one seatback. I'm thinking of using some 1" spacers to keep the amps off the seat itself. I figure that'll give me some room to hide the wiring, too. I also need to figure out a good place to mount a 10-disk CD changer.
I want a small sub...like an 8", perhaps. I mostly listen to Jazz...so, I'm not looking for a "thumper" sub. I've been entertaining the idea of buying an 8" Bazooka Bass Tube, and hanging it off my rear strut brace. I can have a couple of aluminum clamps made to secure it solidly. Any comments? Suggestions?
Prairie Dawg is offline   Reply With Quote
Old 03-30-2004, 11:27 AM   #9
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
You might want to consider what I did.
http://forums.nasioc.com/forums/show...hreadid=175558
I still like it a lot. Bass guitars and kettle drums come alive, without whumpa, whumpa, whump.
Sam2 is offline   Reply With Quote
Old 03-30-2004, 11:28 AM   #10
LiquidIQ
Member#: 6408
2014 FiST 2004 MSM
I would recommend not getting the Bazooka tube, I find them boomy, which is not good for the precise drums of Jazz music.
I think a nice 10" sub with a .88 ft3 box would do nice in your situation.
I would recommend the Polk/Momo 10", but that's just because I have the 12" and absolutely love it. Accurate, tight, hits hard, no boom.
Old 03-30-2004, 11:59 AM   #11
Prairie Dawg
Member#: 16598
'09 Civic Si
Redline Orange
Thanks for the info, guys...and sorry for hijacking your thread, wheelz.
I like your setup, Sam...but, what about my dual rear cupholder?
Old 03-30-2004, 12:07 PM   #12
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
I have a basslink
http://www.epinions.com/Infinity_10_...m__Subwoofers_
it is a 10" sub, 10" passive radiator with a 200W amp, for someone like myself who wanted good quality, good value and to not have to do a lot of cutting and gluing, it is an excelent value.
I mounted it on the back of the passenger back seat so I have full trunk space, and can access my spare tire with ease.
if you are considering an all included type thing, like a bazooka, or other options, this is probably the best solution, it is a bit bigger than most, but the quality of the product and the quality of the sound cannot be rivaled by competing products.
if you are happy with getting speakers, an amp and building an enclosure, you will probably not consider this, but for someone like myself who just wants good quality for a good price and a small footprint. I couldn't pass it up
Old 03-30-2004, 12:59 PM   #13
Prairie Dawg
Member#: 16598
'09 Civic Si
Redline Orange
I've heard good things about the Basslink. I'll check it out...
Old 03-30-2004, 01:26 PM   #14
BlkTS02
Member#: 50142
2002 2.5TS
MBP
I've got a 10disc changer mounted under the passenger seat. It's facing the rear seats so changing the cassette is easy.
Old 03-30-2004, 03:13 PM   #15
Member#: 11441
2002 austin, tx
fishy
we've had a lot of luck with the jbl BassPro.
Old 03-30-2004, 03:26 PM   #16
Prairie Dawg
Member#: 16598
'09 Civic Si
Redline Orange
I wasn't sure it would fit there. But, that sounds like the most logical place. Thanks...
Cool...I'll check it out, too.
Thanks for all the good info, guys...
Old 03-30-2004, 06:14 PM   #17
rwheelz
Member#: 56697
2008 STI
hahahaa my thread WAS hijacked. Seriously though good info anyway.
So I can mount the amps on the seats and heat is not a problem??
Right now I have 2 JL audio 8" subs in slim enclosures, and a 360 watt amp to power them. I am basically going to cut out room for them in the rear "tray" as I call it and lay them flat. This will be enough bass for me!!
So I am going to buy front components and rear speakers and a 4 ch amp to drive them. Just wasn't sure where to put the amps. Under the front seats would be hidden, will it be a noticeable loss in quality due to the longer speaker wire to the subs?
Any recommendations on brand of door speakers that are a good cross between price and quality? I want it to sound clear. I have a set of pioneer 5 1/4" how important are the rear speakers anyway do they even do much for the sound? If these are amped I think they may be good enough. But I want nice front components.
I am also considering just throwing in a deck with a screen so I can do it all at once!! Damn are they ever expensive though.
Old 03-30-2004, 06:42 PM   #18
metoo
Member#: 4764
2004 STi sold :(
forizzle
What type of head unit do you have?
I believe a great head unit powering the in cab speakers sound better than the Subaru factory head unit with aftermarket amp powering the in cab speakers. Plus hook-up and control can be made very convienient with the right head unit.
As I posted in another thread ...
"See my post here
http://forums.nasioc.com/forums/sho...mp;pagenumber=2
Here's one on ebay now.
http://cgi.ebay.com/ws/eBayISAPI.dl...;category=50558
My system includes this unit with stock WRX rear speaker and Poineer 6.5" components in front, all run by the head unit. In the trunk is a sealed box 12" sub with an old Rockford Fosgate amp mounted on the side. It's not very heavy. And I can remove it in less than 5 minutes for Auto-X.
Remember, satisfying sound doesn't have to cost big bucks. It all depends on you goals. Spend good money on your head unit. Depending on how loud you plan to listen to your music when determining the other components of your system. Your rear speakers are the least important. Unless you plan to amplify the rears, stock WRX rear speakers will do well enough."
Old 03-30-2004, 06:50 PM   #19
rwheelz
Member#: 56697
2008 STI
THANKS!
So I will use the pioneer 5 1/4 since they are new and I have them, they must be better than the stockers.
I was debating head unit vs none,I guess I might as well get a new one and do it right though. Maybe I can get away without an amp to drive the 4 in cab speakers, that would certainly save me some cash.
For some reason, I cannot load either of those links!!
Old 03-30-2004, 07:58 PM   #20
sutdawg
Member#: 56670
04 STI
I spent Saturday installing a Pioneer Premier 560 (50w x 4) MP3 player and a set of 6.5 Boston Acoustics NX67 in the front and 5.25 NX67's in the rear. I used the stock wiring and just got a Subaru stereo harness. Also had to get a set of 1" spacers for the front doors $20 (Nobody but Mobile1 had them). 1/2 inches spacers would have worked but 1" worked too and still fit under the door skin no problem. It sounds alot better than my buddies stock Subaru sound system and I get a remote control, MP3 player, and a cool display.
Now I'm just hoping the Easter Bunny brings me an amp and sub(s) but I'm not going to hold my breath.
sutdawg is offline   Reply With Quote
Old 04-01-2004, 12:17 AM   #21
WolfeSTI
Member#: 57112
2004 STI
Java Black
I can agree with the Boston NX67's I put them in the front , and they are awesome...they WILL fit in the front (2004 STI) with a half inch spacer..and some inside dremel work on the door panel which takes 5 mins...should take 30 mins a side to install...they sound great with my Alpine 9815 Head unit...as for the back ..Iput in 5 1/4 discus MB quart ...with NO spacer goes right in NO prob...Also buy the dynamat speaker kit ....
WolfeSTI is offline   Reply With Quote
Old 04-01-2004, 07:59 PM   #22
rwheelz
Member#: 56697
2008 STI
well I ordered some JL audio xr6.5's... anyone know which sized spacer I need for these speakers specifically?
also, will the wiring harness on iaperformance work for basically any deck?
I am going with "matt's" setup, with the LCD in the stock location and the deck in the oem gauge pod.
where do I get a dynamat speaker kit?
Old 04-02-2004, 11:00 AM   #23
Prairie Dawg
Member#: 16598
'09 Civic Si
Redline Orange
Buy the "Brown Bread" from these guys. It's BETTER and CHEAPER than Dynamat...
http://www.b-quiet.com/
Also, e-mail the guys at iaperformance and tell them what speakers you want to mount. They'll tell you which specer to use. They can also answer your question about the wiring harnesses.
Richard
Old 04-02-2004, 12:02 PM   #24
Member#: 11441
2002 austin, tx
fishy
the brown bread is nice stuff. and its cheaper than dynamat. however its not better. its not nearly as dense.
Old 04-02-2004, 12:21 PM   #25
Prairie Dawg
Member#: 16598
'09 Civic Si
Redline Orange
Every comparison article I read on the 'Net showed the Brown Bread to be superior to Dynamat...which is why I made that statement.
Houston - Where to Get Clutch Installed esi7esi7 Texas Impreza Club Forum -- TXIC 11 05-30-2008 07:30 PM
Got my stereo. Now where to get it installed? AWD>FWD North West Impreza Club Forum -- NWIC 11 07-11-2006 11:19 AM
Where to get strut install done in houston? IwantONE Texas Impreza Club Forum -- TXIC 4 08-22-2004 09:46 PM
Good place in Houston to get catback installed? NeoteriX Texas Impreza Club Forum -- TXIC 16 01-23-2004 03:38 PM
where to get stereo installed (city/north bay) littleblue Bay Area Impreza Club Forum -- BAIC 8 11-06-2002 02:47 AM
