Old 03-29-2004, 10:38 PM   #1
Jejunum
Member#: 15773
2011 Impreza WRX
Default loosing some coolant - hg issue?
Hey:
I am loosing about .75 cm of coolant from my coolant resevoir every month. Should I be worried? Havent yet got the bandaid fix from the dealership. Ways on to check if im on my way to HG failure?
btw this is a list i stole from someone on
Ways to tell if your HG is gone
(car does NOT have to show any more than ONE of these):
1. You are loosing coolant somewhere and there are no visible leaks at the hoses.
2. You are loosing an excessive amount of oil and it is not leaking out on the ground (also a sign of bad rings and many other things).
3. Your car gets really hot (not neccessarily overheating) when run. (This was my first sign for those that remember... but it was because my coolant was low).
4. You have water [coolant] mixed in with your oil.
5. You have exhaust gases coming out of your cooling system (overflow bottle or radiator).
6. You have condensed coolant at your exhaust tip (mine had it... weird to see green back there).
Jejunum is offline   Reply With Quote
Old 03-29-2004, 11:21 PM   #2
ERaab212
Member#: 18466
2003 GT35r Evo VIII
[email protected]
Probably a good idea to just get the recall done. its not gonna hurt.
ERIK
ERaab212 is offline   Reply With Quote
Old 03-30-2004, 03:19 PM   #3
obyone
Member#: 16523
Get the recall done. My car is leaking pretty bad from the driver side bank and dripping out from the pass. side.
I'm getting mine replaced as soon as my TWE cams come in the mail.
obyone is online now   Reply With Quote
What to do... 2003 Outback w/ HG issues Chi_San Normally Aspirated Powertrain 0 05-13-2010 07:15 PM
Some blown HG questions CKxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-01-2009 07:09 PM
Brothers Closed Deck ej20g HG issue. my3awds Pre-2002 Factory Turbo Powertrain 11 05-02-2008 04:28 PM
so a heater hose clamp came loose yesterday, lost some coolant... Big_Hitter Texas Impreza Club Forum -- TXIC 7 07-20-2004 11:12 AM
You win some you loose some WRXMaster Texas Impreza Club Forum -- TXIC 6 07-04-2002 04:31 PM
