Old 03-30-2004, 08:10 AM   #1
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Default emanage install question
ok on the main harness what wires go to what side of the map wire, when u cut the map wire on the ecu?
thanks
Greg
GregBolby is offline   Reply With Quote
Old 03-30-2004, 08:11 AM   #2
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
whoops and also how do i set the voltage aka voltage clamp, i have a split second but am having to remove it to put on the emanage, how do i set this with emanage
thanks
Greg
Old 03-30-2004, 09:02 AM   #3
Safir
Member#: 3873
. Paradise is
like Disney with hookers
according to my diagram, white goes to the MAP sensor and green goes to the ECU.
sorry I can't help with how to set the voltage clamp.
Safir is offline   Reply With Quote
Old 03-30-2004, 09:40 AM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
The voltage clamp is set under the "boost limiter cut" function. Enable that under the main unit settings, then click the "BC" icon to open the map.
lotusTT is offline   Reply With Quote
Old 03-30-2004, 09:56 AM   #5
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
I have an EManage question for you guys running it on their RS-Ts. Do you have any issue with the factory ECU learning and compensating for the EManage? I am thinking of going this route. Thanks.
Also, if / when I go this route, I will wanna go with bigger injectors and get rid of the Vortech FMU RRFPR. I am currently running a WRX fuel pump. If I use the 440cc injectors that come stock on a WRX, will this be sufficient @ 5-6 psi? Thanks.
ForesterPerformance is offline   Reply With Quote
Old 03-30-2004, 12:19 PM   #6
Joncas
Member#: 5349
I haven't had any learning problems - it just works. WRX injectors should be fine for 5-6psi.
Joncas is offline   Reply With Quote
Old 03-30-2004, 05:07 PM   #7
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
stockers should actually be ok for 5-6psi
Hitokiri is offline   Reply With Quote
EJ22 emanage blue question HELP DILL_JDA_RALLY Other Engine Management 9 06-01-2009 10:37 PM
emanage blue question hock3ysniper Other Engine Management 1 03-12-2008 12:22 AM
Got P0120 CEL after emanage install & other issues mxpunk Normally Aspirated with bolt-on Forced Induction Powertrain 27 07-27-2007 12:27 PM
Emanage install questions srs14 Engine Management & Tuning 5 12-20-2006 12:32 AM
Emanage Installed and working writeup subachad Engine Management & Tuning 0 07-25-2004 03:52 PM
