Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-30-2004, 07:33 PM   #1
afstevie68
Member#: 20733
2015 Impreza WRX
Crystal White Pearl
Default ?'s turboing an 01 RS
im buying a stock wrx turbo and a stock wrx intercooler, im going to buy the rest of the thigns i need in the summer and try to boost up my 2001 2.5 RS
if i run a really small boost, will i cause any damage or stress to my engine at all? would i even need a new clutch, im talking like 5 lbs of boost
afstevie68 is offline   Reply With Quote
Old 03-30-2004, 07:50 PM   #2
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
well, it's been said before and i will say it again. Read the F & Q's. they help alot. and searches help too.
and also here is an anwser that will piss you off too. stock driving your car causes damage, that is why engines burn out and die. so Modifying your car at all is going to cut your engines/drivetrains life shorter, esspecially since our engines aren't made for boost.
One last note too. since you are asking these types of questions i'm assuming you are kinda a n00B and don't know to much about whats going on with the turboing. Make sure you know what you are getting yourself into here. Alot of time, and money. Good luck.
-Eli
squirrelmasta is offline   Reply With Quote
Old 03-31-2004, 03:58 AM   #3
dknc
Member#: 8165
2001 RS 2.5
Asspen White
Default afstevie68
afstevie68
try http://www.spdusa.com/ it has a lot of very very useful information.
All of us GC8 owners already know. Our 2.5 is an open sleeves engine block. Your max boost would probably be optimum and safe at around 5psi. Crazee has installed his recently and so far so good. It's do-able, but that depends on how much you are going to spend. Crayzee has spent quite some $$$.
Engine swap will be expensive and enough to buy a new SCION xA or a Toyota Echo. but Engine swap is a very clean solution, looks nice in the engine bay and pass smog check with ease.
as far as I know, in California, all the engine modification parts has to have that CARP sticker or CARB? California Air Resources Board ? to be legal and pass smog check, I'm not 100 percent sure, my friend asked a smog check place to see if any mod is legal and the guy said as long as the parts have that CARP sticker it's fine. What is CARP sticker? I don't know.
try this site http://www.arb.ca.gov/msprog/aftermkt/aftermkt.htm
dknc is offline   Reply With Quote
Old 03-31-2004, 04:19 AM   #4
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
The car I have now is running between 8 and 10 psi on stock block for about 35k now and seems to be holding up pretty good. I am getting ready to build a 2.2t because I know it could blow at any given second especailly with that much boost. It's fast as hell though. Yes on the clutch. If you do it right 5 psi should have decent relaiablity.
speed_freak27 is offline   Reply With Quote
Old 03-31-2004, 08:59 AM   #5
afstevie68
Member#: 20733
2015 Impreza WRX
Crystal White Pearl
im thinkin of even doing like...i dunno 3 psi, just to have the feel and sound of a turbo, plus...all scoobs deserve turbos they were made for it
Old 03-31-2004, 10:01 PM   #6
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
not our stock motors
cRayZee is offline   Reply With Quote
Old 03-31-2004, 10:32 PM   #7
afstevie68
Member#: 20733
2015 Impreza WRX
Crystal White Pearl
Old 04-01-2004, 03:12 PM   #8
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
sell your scoob please
benjaminetanyahoo is offline   Reply With Quote
Old 04-03-2004, 12:22 AM   #9
afstevie68
Member#: 20733
2015 Impreza WRX
Crystal White Pearl
why would i do such a thing
Old 04-03-2004, 01:29 AM   #10
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Quite a bit of mis-information in here.
speed_freak27 now owns my old RS-t.
I would highly recommend going in this order
Engine management. Link plus is wonderful
Clutch.
Tune,tune,tune
Turbo.
....Profit!!
Tune tune tune
Unique motorsports makes up and downpipes. The stock WRX I/C will fit with modification.
I can't stress this enough. tune tune tune. Not just road tuning, get it on the dyno.
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle Subaru Conversions 15 11-04-2006 01:11 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle South West Impreza Club Forum -- SWIC 2 10-31-2006 04:15 PM
will a custom cat-back off a 04 RS fit an 01 RS? LunaticDriver Normally Aspirated Powertrain 14 01-11-2006 07:52 PM
Will the front bumper skin of a 2002 wrx/rs/ts fit on an 01 RS? Canadian 2.5RS Interior & Exterior Modification 5 11-29-2002 03:45 PM
well... i got it... an 01 RS Subie Gal General Forum Archive 56 01-17-2001 08:31 PM
