Old 03-30-2004, 09:42 PM   #1
Pedestrian
Member#: 52410
05 LGT
Default VF22/VF34: Safe without tune/intercooler?
How safe would I be putting on a vf22, with supporting fuel mods, and a UTEC left on the regular untuned stage four map be without an aftermarket intercooler. In my quest to save money, I would put those on first, and get a bigger intercooler later on. Will I make more power with a vf22 on an untuned stage four than a vf34 on the untuned stage four?
Thanks in advance,
Ben
Pedestrian is offline   Reply With Quote
Old 03-30-2004, 10:22 PM   #2
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
the stock intercooler doesn't make it unsafe, the base stage 4 map is for that stock TMIC, the bigger TMIC adds power to it, and the FMIC map is different.. all these maps are designed to be rich (ie safe)... the bigger turbo will make more power but you hsould know the stage 4 map is not made for a VF22 so I would not recommend running it for long w/ out a tune as it may not be safe at all on that map.
MustGoFast is offline   Reply With Quote
Old 03-30-2004, 11:57 PM   #3
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
At least get some sort of boost conrol, even a manual cheapie for insurance.
Bryan
wrxpeed is offline   Reply With Quote
Old 03-31-2004, 10:19 AM   #4
Eli
Member#: 22135
World Ralley Road Rash
Unless TXS have changed it the base stage 4 map was designed for an aftermarket TMIC. THe stage 3 was also designed for a larger TMIC. You will probably need to keep your boost settings relatively low because the intercooler will not be able to keep up with the heat the turbo is making as it runs out on its efficiencey map. I wouldnt reccomend running much more then 14 psi or so (remember its all about flow not psi) and you will be flowing more then the stock turbo but not overwelhming the intercooler. Youll know when you are because you'll have a hard time tuning out the knock.
Eli
Eli is offline   Reply With Quote
Old 03-31-2004, 10:33 AM   #5
WRXMikeH
Member#: 30577
2003 WRX
Wrong... http://www.turboxs.com/utecstg4.htm
The base Stg4 has always been with the stock IC as long as I can remember. But...it is configured to use the VF30/34, not the 22, so be careful.
WRXMikeH is offline   Reply With Quote
Old 03-31-2004, 10:57 AM   #6
Eli
Member#: 22135
My bad. But could someone explain to me why when you go from a stage 3 to a stage 4 you lose the TXS TMIC??? The stage 3 is definitely designed for the larger IC. Oh well...shows you what happens when you assume things.
Eli
Old 03-31-2004, 11:01 AM   #7
WRXMikeH
Member#: 30577
2003 WRX
I believe that's because there once was only Stage 1, 2, and 4. Stage 3 was added in there at the same time as Stage 4 + TMI.
Old 03-31-2004, 12:19 PM   #8
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
I've been running with stock TMIC for a couple of months without any problems on stage IV (vf34).
SupaSizeFries is offline   Reply With Quote
2.0L with VF34: Mach V Tuned Tut4u2 Proven Power Bragging 33 06-17-2010 05:52 PM
safe to run dp, up, and cbe without tuning? wrxproject Engine Management & Tuning 24 01-20-2006 01:30 PM
running utec without tuning is it safe??? 05suby Engine Management & Tuning 2 08-26-2005 12:36 AM
How safe without EM or tuning? scooby-stu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 04-16-2005 11:50 AM
('93-'01) can you just buy cobb CAI and use it safely without the unichip? S-WRX Impreza Forum 2 09-03-2001 11:30 AM
