Old 03-30-2004, 11:20 PM   #1
mycarsux
Member#: 32049
2010 sti
Have a Nice Day? why did my car get slower
i just put on borla headers and now have a custom midpiipe with apexi n1 muffler. it doesnt seem to pull hard anymore. it seems like my car got slower. my used to start pulling hard after 3500 rpm. now it doesnt pull hard anymore. or was it that my car just didnt have any power before 3500 rpm and then all of it came after it (on my previous set up. stock headers, stromung muffler.) im really confused. i thought headers was suppose to make it better. i think my fuel mileage got better tho.
mycarsux is offline   Reply With Quote
Old 03-31-2004, 12:47 AM   #2
TexRex8
Member#: 39827
'03 WRX
Stg. 2+
Maybe less b/c of less torque at lower rpms...i dunno. I put my uppipe, catback, and boost controller on and it doesnt feel as jumpy right from the start, but whenever i bring those rpm's up, all hell breaks loose.
TexRex8 is offline   Reply With Quote
Old 03-31-2004, 01:13 AM   #3
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
reset the ecu ??
AustinSTi is offline   Reply With Quote
Old 03-31-2004, 01:15 AM   #4
quest
Member#: 42402
- Finder of Porn
-Bringer of tears...
if you went with 3" piping, you'll lose low end torque in an rs...i think even 2.5" will drop it a bit...best to stick with 2.25" for NA
quest is offline   Reply With Quote
Old 03-31-2004, 07:28 AM   #5
Imprezive2002
Member#: 18872
2002 Impreza
yea man and what is the size of pipeing on the exhaust out, mine use to be 3 inch but that messed me all up so i changed to a hks 2.25 muffler out. Now it runs like its suppose to, i also have borla headers now it just whips it out haha `Nick
Imprezive2002 is offline   Reply With Quote
Old 03-31-2004, 10:08 AM   #6
Pat L.I.
Member#: 20498
2006 WRX TR
MyCarSux - if you just put the headers on recently reset the ECU and give them some time to break in. I noticed this when i first installed my borla headers, they felt slower, i eventually got the power back.
you may also "feel" slower because the power delivery is smoother rather than a surge at 3,500 like before.
Pat L.I. is offline   Reply With Quote
Old 03-31-2004, 02:18 PM   #7
Julian
Member#: 1182
MY00 RS
BRP
What piping did you get after the cat? Mandrel bends? Badly-formed crush bends?
In any case, if the piping is correctly sized for your car and minimal/smooth bends, it may be that your car is more powerful, but not as peaky as it was before. As Pat is saying above, if the power curve is flattened (from additional torque) at lower rpm, there won't be the "kick" at 3500-4000. You'll be at the same power output, or higher, but not as peaky.
Ride the wave - Torque!
Julian is offline   Reply With Quote
Old 03-31-2004, 06:35 PM   #8
poison
Member#: 37678
I think one of your stickers must've fallen off
poison is offline   Reply With Quote
Old 03-31-2004, 07:53 PM   #9
mycarsux
Member#: 32049
2010 sti
well i didnt put my borla sticker on so maybe dats why... i went wi/ 2.5 inch piping. i knew i should of gone to 2.25 but the apex resonator i had was 2.5. o well. the bends are mandrel...but not much bending was needed. if u look under my car, the mippipe runs parrellel with the driveshaft, so its pretty straight. does reseting the ecu help? i thought it only worked for intake or pulley kinda mods. if i dont reset it, will my ecu "learn" or something...i dunno im totally clueless on all the electrical/computer stuff.
Old 03-31-2004, 08:31 PM   #10
DisturbedKayos
Member#: 24612
1999 2.5RS
silverthorn
mycarsux - i had the same problem your describing as well. i have custom made 2.5 inch headers, high flow cat, and 2.5 mandrel cat back into a naxos muffler. give it a week or so and everything will work out. and trust me, after that week has gone by, you will be a happy camper.
DisturbedKayos is offline   Reply With Quote
Old 03-31-2004, 09:59 PM   #11
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Yeah, resetting the ECU probably will help. The ECU needs to "learn" the new parts, especially when it has to do with the air velocity and breathing characteristics. And freeing up the whole exhaust is definitely going to change that. And, no, you don't have to reset it, it will lear eventually, it's just that resetting it forces the issue, and is usually a faster method.
HondaH8er is offline   Reply With Quote
Old 04-01-2004, 01:51 AM   #12
mycarsux
Member#: 32049
2010 sti
oooh...tight. cant wait. by the way, how many miles is it to break in a muffler?
Old 06-02-2004, 03:11 AM   #13
TNT
Member#: 8494
Quick Bump.
I just installed a new midpipe and STI Exhaust.
Will I need to reset the ECU?
TNT is offline   Reply With Quote
Old 06-02-2004, 09:35 AM   #14
Pat L.I.
Member#: 20498
2006 WRX TR
sure go ahead it wont hurt! it will take a few driving cycles to learn, but you can speed up the process if you reset the ecu. Only takes a few minutes anyway.
Old 06-02-2004, 12:29 PM   #15
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Question Sooo
Those of you (if any) that have a 3" exhaust, does the ECU learn and bump up the torque as well? I know that the air velocity may be slowed down some. How about going with a 3" exhaust that narrows down to a 2.25 or 2.5" muffler?
Kevin Thomas is offline   Reply With Quote
Old 06-04-2004, 11:16 AM   #16
Section 8
Member#: 821
The 3" pipe will not aid torque production no matter what the computer does.
A smaller muffler section won't help because the exhaust will slow down through the wide portion, but you will be using exhaust energy to speed up the gas through the narrowed muffler section.
The only place where a norrowing after a wide area helps is the collector of a header. After that for maximum effeciency (minimum loss) you need to have the same cross sectional area to the tail pipe, and choose you sound suppression wisely.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
why did my thread get closed?? [email protected] General Community 12 05-20-2006 05:55 PM
Why did my post get deleted? 92XJET Mid Atlantic Impreza Club -- MAIC 9 10-10-2005 09:27 PM
Loss of power, why does my car feel slower, is it in my head? Hotrodguru Texas Impreza Club Forum -- TXIC 22 03-15-2005 04:04 PM
Why did my post get deleted! ocdpwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-04-2004 10:50 AM
