Old 03-30-2004, 11:31 PM   #1
Racer5
Member#: 57339
Have a Nice Day? Another ej18 query, how many valves?
Yes I searched the forum to no answer. I'm new to these boxer engines but it seams to me that a SOHC like the ej18 would be an 8 valve engine just like any other SOHC right? I have people telling me that they are 16 valve engines. Is that the truth?
How many valves does the ej18 have hmmmm?
Racer5 is offline   Reply With Quote
Old 03-30-2004, 11:36 PM   #2
marioej18
Member#: 31115
2004 saab 9-3 aero
black
well, my impreza says 16 and it has an EJ18
marioej18 is offline   Reply With Quote
Old 03-30-2004, 11:43 PM   #3
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
Yes, EJ18 is SOHC and has 16 valves.
4 valves per cyl...
Hawk296 is online now   Reply With Quote
Old 03-30-2004, 11:46 PM   #4
Racer5
Member#: 57339
Okay, so what does the DOHC setup on some of the ej25s do? I mean, if all of the ej engines are 16 valves why go to the more complex setup?
Old 03-31-2004, 07:43 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
DOHC motors allow for more precise opening and closing of valves since the intake and exhaust valves are controlled inpedently, this helps to improve mid range torque.
Among other things.
Jay
Old 04-01-2004, 12:16 AM   #6
redwagon
Member#: 2181
2008 SpecB
Among other things.
Jay
Except that unless you have adjustable pullies, timing shifts between intake and exhaust cams as the belt stretches, which doesn't happen on a sohc motor.
OTOH, dohc does allow direct valve operation, adjustment by shim, less reciprocating mass. All of which in theory allows operation at higher speeds, or with higher valve acceleration, or with lighter springs. If you have adjustable pullies, a dohc setup can have intake and exhaust timing advanced or retarded independantly. Direct valve operation also reduces side thrust on the valve stems which increases life on the valves, guides and seats. On the downside you have extra weight, complexity and expense.
redwagon is offline   Reply With Quote
Another Cat thread: How many do you have, and which is your favorite? shinsain Off-Topic 87 10-30-2012 12:48 PM
How many different valve guides are there? reddevil Built Motor Discussion 2 03-26-2007 01:30 PM
Another WBM thread: How many miles will you be travelling? DJ 9iron Off-Topic 17 03-30-2006 10:17 PM
How many valves in a 1.8L? Rovah New England Impreza Club Forum -- NESIC 7 09-23-2001 10:27 AM
('93-'01) ANOTHER 22b spotted!!! How many 22b is ther world wide!?!?! limited ? gerardchau Impreza Forum 23 08-07-2001 02:27 AM
Message Board Statistics All times are GMT -4. The time now is 06:28 PM.
