Old 03-31-2004, 12:05 AM   #1
psychobooe
Member#: 34045
2002 Impreza WRX
Unhappy Autometer Oil Pressure Gauge
Has anyone out there ever installed an Autometer oil pressure gauge in a 2002 WRX? I attempted it today, but with the metric-to-english adapter, the sender was too high. Now I have to run some extension pipe to mount the sender remote. Please help me!!!!!
psycho
psychobooe is offline   Reply With Quote
Old 03-31-2004, 12:38 PM   #2
awdman
Member#: 27962
2003 WRX Sedan
Blue, with more dings!
Default Where?
Did you mount under the alternator or intercooler? Mine is under the intercooler and the only trouble I had was the CCV hoses and "tee". Close but it's in there, adapter and all...
awdman is offline   Reply With Quote
Old 03-31-2004, 01:13 PM   #3
psychobooe
Member#: 34045
2002 Impreza WRX
I mounted under the intercooler. I tightened the plug and adapter down as much as possible, but it was still too high for the intercooler hose to fit back on.
Old 03-31-2004, 11:26 PM   #4
abqkid
Member#: 52295
2003 WRX Wagon
here is where i put mine. I have the same gauge. The red thing is the sender and then just follow the black wire loom down under the IC. I just had a custom steel braided hose made that had one male and one female 1/8 npt fitting. hope this helps!
abqkid is offline   Reply With Quote
Old 03-31-2004, 11:27 PM   #5
abqkid
Member#: 52295
2003 WRX Wagon
sorry about the massive pic
Old 04-01-2004, 01:13 AM   #6
psychobooe
Member#: 34045
2002 Impreza WRX
Well, I didn't get the pic, but I was able to make it work tonight. I just put a 90 degree bend after the adapter towards the driver's sid right on top of the transmission. Everything screwed in just fine with no problems. I have to finish the wiring tomorrow, but it should work. Hopefully.
Old 04-01-2004, 01:55 AM   #7
abqkid
Member#: 52295
2003 WRX Wagon
It sounds like you got it but i will try this again anyway. maybe this will work
Old 04-01-2004, 10:27 AM   #8
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Hey abqkid, that is probably the best way to mount that. Very well done, I do not mount those autometer sending units direct to the engine anymore, as I have had two incidents that the sending unit broke off, and left a little bit of the adapter in the engine block. And also shot oil over everything, and made it almost impossible to get that little piece out. Not to mention that it ruined my engine. (Nothing like hearing bearings run dry)
Remote mounting the sending unit is the best way to do it.
Shane
www.paranoidfabrications.com
PARANOID56 is offline   Reply With Quote
Old 04-01-2004, 12:36 PM   #9
psychobooe
Member#: 34045
2002 Impreza WRX
PARANOID,
How did you have the sender mounted when it blew off? That just sounds like a pretty strange thing to have happened. Has anyone else had this problem?
Old 04-01-2004, 02:37 PM   #10
PARANOID56
Member#: 22035
2003 Brocoma DCab
i had it mounded with an adapter from autometer. it was just bolted into the block. it was just becasue of the weight of the sending unit, that it broke. i was going over a speed bump when it happend.
Shane
FS: autometer gauge pod, autometer oil pressure gauge, maddad EGT gauge schiarelli Interior/Dressup/Audio & Security 2 10-29-2009 11:26 AM
Autometer oil pressure gauge install question sethb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-08-2005 07:59 PM
Adapter for autometer oil pressure gauge. Hey_its_Cole Texas Impreza Club Forum -- TXIC 11 04-16-2004 04:21 PM
Autometer Oil Pressure Gauge psychobooe Electrical & Lighting 3 03-09-2004 03:27 PM
Autometer oil pressure gauge...is it dead? Turbo9000 Electrical & Lighting 5 12-02-2003 07:36 PM
