Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 03-31-2004, 01:13 AM   #1
wildbill99
Member#: 58493
2000 impreza 2.5 rs
silverthorn
Default have ? on true duals
coming from a v8 background im figureing i could put true duals on the h4 and see gains and probably have a totally different sound. be fore anyone can ask the reason i want duals is that im wanting to build my little jap car with some american muscle flavor and nothing say that like chrome sidepipes. but i dont want to spend the money to do this and then not be happy or worse have it negatively affect my performance.
i know i could loose some low end umph but i dont spend much time down there. i have looked over previous posts and they were all pretty old. they speculated it would sounded like some strange two stroke hybred. there was also some talk about there being no scavenging effect on the first ignition per bank.
when i slaped the straight duals on my blazers 5.7 in conjunctin with big heades there was a big hp gain. shouldnt the same thing work on the subie engine or does does it work alot more different than the V8s than i thought. im really looking for someone who has or nows someone who has already done this.
thanks scott
wildbill99 is offline   Reply With Quote
Old 03-31-2004, 01:22 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Well, depending on your muffler selection, it may sound like two v-twins next to each other, or it may sound like 4 lawnmowers next to each other. Not much displacement going through each pr of exhausts. Hi end will improve, but at what cost?
Try it with the cheapest tubing you can find, and see how it goes. If it seems okay to you, build a set in nice SS and roll on.
Jay Storm
www.sourcemotorsports.com
Old 03-31-2004, 04:30 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
If you want to sound more like a v8 shoot for borla headers first.
Old 03-31-2004, 08:37 AM   #4
pdlindor
Member#: 7446
2002 Impreza RS
2009 Forester Limited
Indeed. Check out the video clip in this thread:
http://forums.nasioc.com/forums/show...hreadid=516712
Borla headers + custom mid-pipe + ScoobySport muffler.
I played it for my Mustang owner friend and he LOVED the sound!
~Paul
pdlindor is offline   Reply With Quote
Old 03-31-2004, 02:12 PM   #5
Julian
Member#: 1182
MY00 RS
BRP
Is this a looks quest, or a performance quest? Looks - you're on your own. Performance - dual exhaust is an unlikely avenue to gains. The header is the main bottleneck, in any case. Adding the weight of the extra pipe, plus the weight of another muffler, and you'll probably lose performance. Aside from that, there's no place to fit a muffler on the right rear, and not much room to tuck twin pipes through the center of the car.
No 4 cylinder runs true duals, they aren't necessary and don't work. Honda S2000 has dual mufflers, but they branch off a single pipe, Camaro style.
Julian is offline   Reply With Quote
Old 04-02-2004, 01:06 PM   #6
wildbill99
Member#: 58493
2000 impreza 2.5 rs
silverthorn
why dont true duals work? if i run both pipes through a 2in 2out muffler say a gibson with 2 in pipes it should eliminate the v twin or lawm mower sound.
scott
Old 04-02-2004, 01:34 PM   #7
00RScoupe
Member#: 57535
2004 FXT
Maroon
Please don't think of this as a flame. I completely respect people who do thier own thing and try to be different. But true Duallys seems way to impractical to me.
Have you even looked under your car yet? Take a gander and look at the your differentials and all the AWD stuff under the car. Then look at the channel subaru put there for the exhaust. Now try to imagine putting two pipes there instead of one, simply because that channel is the only place to put the exhaust unless you want it dragging the ground.
The more I think about it, it just seems like alot of work and expermentation. You actually have lots of choices on aftermarket exhaust. Most are proven to perform well, unlike a homemade dual setup which is questionable at this point.
When you were messing with 8 cylinders did you hook up an complete exhaust pipe from engine back for every two cylinders?
Have you thought about engine management and the rear O2 sensor and how you will handle that? The same fixes for aftermarket exhaust and teh P0420 CEL might not work on a true dually setup, because the rear 02 will only be able to see half of the "pulses".
Like I said, this post isn't a flame, just some things to really think about before you put alot of effort into it.
00RScoupe is offline   Reply With Quote
Old 04-02-2004, 11:24 PM   #8
piker28
Member#: 22664
duals = R1C3
it wont help at all and prob kill low end with all the extra piping.
and take a look under the car there is no room to run a second pipe
piker28 is offline   Reply With Quote
Old 04-03-2004, 02:41 PM   #9
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
If it made sense to use duel exhaust for 4 cylinders, then don't you think there whould be quad exhausts for an 8? Really, think about it, the 2.5L H4 is going to have the exact same displacement as one cylinder bank of a 5.0L Ford V8. If a single header and exhaust is so great for the V8, then shouldn't a single header and exhaust be good enough for the H4?
HondaH8er is offline   Reply With Quote
Old 04-03-2004, 04:53 PM   #10
wny97outback
Member#: 58217
if you want duals, do like i'm going to do this spring. i have a 2.2 with 1 exhaust port per head. take a pipe and just run it staight out the side. i've looked at it and i think that they will fit nicely in front of the front wheels, maybe bent upward (warthog style).
wny97outback is offline   Reply With Quote
Old 04-03-2004, 05:53 PM   #11
wildbill99
Member#: 58493
2000 impreza 2.5 rs
silverthorn
i think i found a solution. talk to a gut who can make me custom headers and then im going to bolton a high flow cat to each side and then run it to a X or H pipe and i should eliminate exhaust pulse and firing order pressure differences then run them into either smithy mufflers or glass packs . and run them down the sides implace of the factory side skirts. since im in ga loudness doesnt matter. what ya all think.
scott
Old 04-03-2004, 06:08 PM   #12
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
I think the idea is cool, dunno why no one else likes it.
b_tapper is offline   Reply With Quote
Old 04-03-2004, 06:37 PM   #13
piker28
Member#: 22664
we all arent ricer rednecks
Old 04-03-2004, 06:43 PM   #14
b_tapper
Member#: 5291
'08 Scion xB
what's ricer about it?
Old 04-04-2004, 10:40 AM   #15
donut
Member#: 9957
Talking GO for it
WildBill
go for it dude i want to see pics if and when its get done and mabey a video. i think its a cool idea rice or not it will be different.just don't have 8 small pipes coming out the back, somebody posted a pic of a black wrx with 4 small pipes on each side of the rear bumper it was pretty lame.
GOOD LUCK dude
Donut
ow ya if you do the X or H pipe you could put the O2 sensor in there
donut is offline   Reply With Quote
Old 04-04-2004, 04:44 PM   #16
wildbill99
Member#: 58493
2000 impreza 2.5 rs
silverthorn
hey donut thinks for the incouragment. i should have it done in about 6 six weeks if i dont come across too many problems. will keep everyone up todate on my progress.
scott
Old 04-04-2004, 06:01 PM   #17
MattDell
Member#: 16803
Sounds interesting..
MattDell is offline   Reply With Quote
Old 04-04-2004, 06:18 PM   #18
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Comparing this to a dual exhaust V8 the way some of you are is apples to oranges. The idea is not to have 1 pipe per 2 cylinders as some people are saying, but to have a seperate header for each side of the engine, like a true dual V8 system. The reason no one does a 1 pipe per 2 cylinders is the space it would take up and why bother if the flow is good with the standard 4 pipe to one set up being used. How are you going to run 4 pipes from the engine back? So why bother trying. If this guy can fit a second pipe all the way back with a glasspack and a cat I say go for it. I'd probably reduce the pipe diameter a bit to make up for excessive loss of back pressure tho. Sounds like a cool project. If it can be done firly inexpensively go for it. If it doesn't work he can always go the traditional route. It would be something new.
Keith99RS is offline   Reply With Quote
Old 04-04-2004, 09:33 PM   #19
redwagon
Member#: 2181
2008 SpecB
If I'm not mistaken, in order to get proper scavenging, you'd want to couple cylinders 1&4, and 2&3 which are 180 degrees apart in terms of firing angle. That's going to be a bit of a spaghetti nightmare under there...
redwagon is offline   Reply With Quote
Old 04-04-2004, 11:46 PM   #20
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
I'm fairly certain that's so, as well. I'm not sure of the extent of the benefit, if any, but if you go through with it, post some pics!
LetItSnow is offline   Reply With Quote
Old 04-05-2004, 12:11 AM   #21
wildbill99
Member#: 58493
2000 impreza 2.5 rs
silverthorn
the army is paying me $1325 per month for school and tuition is only $385 per quarter plus i work. i have nothing better to do with my money. im going through and auto tech corse so i have full access to a top of the line garage and the machine and body shops classes are always more than happy to help out on a project. i really hope it works.
scott
Old 04-05-2004, 03:20 AM   #22
redwagon
Member#: 2181
2008 SpecB
Well, if I had the time and the facilities I would most likely be fabbing a system like MRT's, but have fun, and let us know how it goes!
Old 04-05-2004, 01:55 PM   #23
Storm
Member#: 5218
96L Most Over-
Developed Beater
Aside from the space constraints(look at a BMW for nice routing of duals). There are reasons why the exhaust doesn't flow as duals already. Part of it is our funky firing order, part of it is the boxer design. I think you'll find that whatever you gain up top will be less than what you're going to lose in drivability. If VW and Porsche haven't decided on running duals over the past decades, I can't see where the Subaru is going to be much different.
Like I said before, make a set from cheap tubing and see how it goes. Ya never know......you may find something.
Personally, the MRT is probably as close as you'll ever need for dual exhaust. Though, I have contemplated lopping off our rattlebox of a MRT cat and fitting a Catco dual 2"in/dual 2"out and running some ovalized pipes out the side, just for sheetz&giggles. If I do decide to try this, I'll surely post results, no matter how wrong it ends up being.
Jay Storm
Old 04-06-2004, 02:28 AM   #24
HeyChris
Member#: 2234
2013 F-XT
Obsidian Black Pearl
I say nutts to everyone...
Do it if you want to. And if you do... be sure to document it and give us the photos/video clips of yer car running WOT...
Then again, its not my $$ getting ready to be spent.
HeyChris is offline   Reply With Quote
Old 04-06-2004, 08:47 AM   #25
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
you know, on my hatchback I ran duals. some people run duals on their older 1.8s in the 80s body styles. And it sounds *good*! But, of course, there is no room under the newer soobs, and that's the only problem in my opinion.
JonofScio is offline   Reply With Quote
True Dual Exhaust? Numbchux Normally Aspirated Powertrain 44 10-18-2015 02:59 PM
Anyone running a true dual fuel setup ? bugeyes Water/Methanol Injection, Nitrous & Intercooler Cooling 4 10-21-2008 10:33 AM
True Duals Question 94'325is Normally Aspirated Powertrain 14 07-09-2008 01:47 PM
Mackin industries espelir true dual exhaust hendo2.5 General Community 13 07-05-2005 09:56 PM
('93-'01) True dual exhausts ?? lostsoulmusic Impreza Forum 9 01-14-2005 11:00 AM
