Old 02-07-2001, 10:35 AM   #1
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Post New gas pumps at the gas station?ripoff?
The other day I was getting gas, and reacently the local Texico got new pumps, the kind with only one nossel for all three types of gas. Usually when I'm getting gas I'm just in a daze watching cars pass, but for some reason yesterday I was actually thinking.That hose is pritty long, so it probably holds at least a gallon of gas. If the person befor me used the lowest grade gas, and I put in the Highest grade that means, the left over cheep gas in the hose is the first thing that went in my tank. So that's one gallon of gas that I'm paying the high price and getting the low grade gas, and the gallon of high grade that I paid for is in the hose for the next person. I'm not a worried about the extra money I just don't want that low grade in my gas tank.
Does this sound logical to anyone or am I just wierd?
Anthony C.
Bobalouy is offline
Old 02-07-2001, 10:38 AM   #2
bratmantlz
Member#: 3231
88 626 Turbo
white
Have a Nice Day?
hey that does sound like what would happen.. *** that makes me want to go to stations with three hoses one for each grade hmmm got me thinking. the monkey speeks for me gas costs an arm and a leg anyways.
bratmantlz is offline
Old 02-07-2001, 10:47 AM   #3
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Post
I'm not sure about your theory, although it sounds very sound....
I do know that those types of pumps mix low grade and high grade together to make mid grade....
That way the gas stations only have to buy 2 grades instead of 3 (and have only 2 underground tanks instead of 3) Also, calling those things pumps is not really accurate anymore, the pumps are now in the ground, and the "dispensers" just spit it out and track how much you've gotten.
The pumps are the ones that are mechanical and make that humming sound when you flip the on switch....
(I have a friend that used to service pumps and dispensers at gas stations)
-Nate
crash is offline
Old 02-07-2001, 10:48 AM   #4
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Post
unless you have a turbo you want the low octane gas anyways. We dont need high octane. but i do see your point.
Josh
scoobiejosh is offline
Old 02-07-2001, 10:49 AM   #5
enuttage
Member#: 3490
Post
How 'bout this?
You stop on the way home from work/school 'cause you're low on gas. You don't have a lot of flow, but you've got a five spot in your pocket. You pump that 3 gallons of gas into your car, one gallon of which is 87 octane (fill in lowest grade in your location).
Not good for the brand new WRX requiring at least 91 octane. I know it's not gonna fry your car right then and there, but long term, it sure isn't good for it.
-Eric B.
enuttage is offline
Old 02-07-2001, 11:22 AM   #6
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
Post
sorry my last post was for a non-turbo 2.5. Or any other normaly aspirated car with compression as low as a 2.5. just clairfying. If you got a WRX or other turbo go to the next gas station, should be one on the oposite corner. Exxon and Mobile are the only ones i got to and they dont do the single "dispencer" stuff.
Josh
Old 02-07-2001, 11:30 AM   #7
Lix
Member#: 1560
Post
I don't think it's that big a deal...the pump probably only pumps when it is in use. When the pump is not in use gravity (edit: whoops...not gravity, but through principals used in Bernolli's equation. Since the pressure in the atmosphere is higher than in the tank, which is a vacuum, the fluid will go back into the tank)will be acting on the fluid in the fuel lines and pull them back into the tank. I doubt the gas station is going to pay for a pump that holds fluid inside the hose when it doesn't need to. At most you'll probably be getting some 87 Octane residules.
[This message has been edited by Lix (edited February 07, 2001).]
Lix is offline
Old 02-07-2001, 11:41 AM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Actually gravity would cause most of that to fall to even out with the level of the filler. At 7.48gal/cu.ft. let's say 48" of the hose is below the filler and the hose is 3/4" ID... thats 21.21cu.in. (.0122 cu.ft.). .0122 of 7.48gal is .091 gallons.
Looks like you're only getting about .1gal or so from that hose. I'm sure most/all of it that is pumped up to the top of the unit (station pump) is drained back into the tank by gravity or at least it may be split at the top of the unit in which case there is probably less then a foot of hose between the junction and the hose leading to the filler which may still have gas in it.
All in all, you aren't getting much low-grade fuel there. Feel better now?
8Complex is offline
Old 02-07-2001, 11:53 AM   #9
enuttage
Member#: 3490
Post
Ahhh, the unaccounted for miracle of the siphon.
-Eric B.
enuttage is offline
Old 02-07-2001, 01:36 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Ahhhhh... I forgot about the driving valve in the handle. Well even if there is 12 feet of hose, that is still only .3 gallons of gas to the top of the hose, though.
8Complex is offline
Old 02-07-2001, 01:51 PM   #11
Steve Theodore
Member#: 3737
2007 WRX STi
Crystal Gray Metallic
Cool
Don't worry because your ECU will adjust for the lower grade gas. Just don't crank up the boost on the WRX if you have crummy gas in the tank. For normal driving, it won't be a big deal.
Steve
Steve Theodore is offline
Old 02-07-2001, 01:58 PM   #12
Gambit
Member#: 102
Post
talk about paranoia.
i use regular. therefore i don't have the worries.
Gambit is offline
Old 02-07-2001, 03:58 PM   #13
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
I find that I like to go to gas stations with the old non-vapor recovery nozzles. They spill a lot less. I can stick my ear (and nose too!) by the filler and listen for the gurgles. I also shut the pump off and keep squeazing the handle to get the last drops. Once I had a good steady stream of gas for 30 seconds after the pump stopped... all that would have been left in the hose. So the guy behind me got to pay to fill the hose back up!
CosmoTheCat is offline
Old 02-08-2001, 12:00 AM   #14
micah
Member#: 3154
Post
I don't think it would be a gallon. Somebody look at the ID of that hose (I think its printed on it) and estimate the length and do the calculation, or post the stuff and I will. Hold on... lets say 12' of 0.75" ID hose, that's about a quart. Say you only get 5 gallons. 1 quart 87 + 4.75 gallons 91= 90.8 octane. Should be fine.
mbs
micah is offline
Old 02-08-2001, 12:07 AM   #15
El Kabong
Member#: 625
2005 STi
WRB/Gold
Post
Ah, very interesting... Never thought about it before... I guess the solution is to just pump that first hose worth onto the ground, then start filling up your car... hehehe... just kidding of course. I'd be curious to know how much is actually in the hose.
El Kabong is offline
Old 02-08-2001, 12:10 AM   #16
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Wink
Or think about it the other way...if the guy before you got premium, and you wanted the regular grade...you would be getting a little premium for the price of regular grade!
Opie is offline
Old 02-08-2001, 12:35 AM   #17
ba_feitl
Member#: 2884
2004 Forester
Post
good call opie...
i bet your glass is always half full !
Brad
ba_feitl is offline
Old 02-08-2001, 12:38 AM   #18
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
Ok i will put my thought into this one since i worked at a gas station. Ok i do agree that there is at least a half gal of fuel in the line since it is in a U shape conected to the very top of the pumps. but emough of that this is where the truth shows through. Ok have you ever seen someone drive off with the nozzle still in the car, well if you have the hose usually breaks and fuel goes everwhere well that fuel is what was in the hose as there are two vavles on the hose, one inside the pump and one on the nozzle so when you turn off the valve on the nozzle it stops the fuel from going out then after you pay the clerk truns off the vavle before the hose you can't get any gas till they authorizes it(thats why it take so long sometime for the pump to come on) so when its not in use both valves would be closed so fuel would still be inside the hose.
ImprezedRS is offline
Old 02-08-2001, 12:53 AM   #19
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Post
Well I guess its not that big of a deal but at least I got some people thinking.
Anthony C.
Bobalouy is offline
Old 02-08-2001, 12:59 AM   #20
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Post
just squirt a gallon er so into the window washer deal
Jaxx is offline
HTML code is On
Driving off at the gas station with the nozzle still in the car :-( xknowonex Off-Topic 51 04-30-2006 08:34 PM
Retardation at The Gas Station WagonMonster Off-Topic 49 01-13-2005 07:20 PM
Exchange I had at the gas station last night (long and boring) beachbum Off-Topic 13 05-21-2004 12:23 PM
Met a cool dude at the gas station DarkShadow Texas Impreza Club Forum -- TXIC 0 08-13-2002 02:13 PM
Odd Problem At The Gas Station North Ursalia New England Impreza Club Forum -- NESIC 17 01-18-2002 10:10 AM
