Old 03-31-2004, 06:16 AM   #1
HubbieScooby
Member#: 7088
Super Slow
Have a Nice Day? spooling slow
hey fellas
i have a ludespeed stage 2 kit running 4.5lbs....i just installed some borla headers and there is a big noticable lag in turbo spool up....when i'm on the gas before the headers i can make the BOV go off while still on vac. but now all i hear is flutter and the BOV only goes off on positive pressure or boost....according to the butt dyno...the top end does feel a little stronger...maybe it's just me in denial ....i'm planning to run an STi short block very soon and retain my stock 2.5L heads...so running higher boost will definitely come later...but i wanted to know if there were anything i can do to reduce this lag?? i was thinking about thermal wrapping the headers and uppipe...and maaaaaaybe getting a different turbo...i have a t3/t4 right now....how are the ball bearing turbos or the VF series?? oh my car is still running pretty rich due to a blown O2 sensor...so that may have something to do with it...sorry for being so long but any suggestions is widely appreciated thanks
hugh
HubbieScooby is offline   Reply With Quote
Old 03-31-2004, 12:33 PM   #2
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
Dirt-01 Forester swapped
I have a borla header and didnt notice any noticable lag. Do you have boost gauge and is it still reading right. Have you checked for exhaust leaks?
smith
25rstautoxr is offline   Reply With Quote
Old 03-31-2004, 05:10 PM   #3
noob w/ a scoob
Member#: 58282
i heard that a lightened flywheel can do the trick to stop or reduce turbo lag.
noob w/ a scoob is offline   Reply With Quote
Old 03-31-2004, 05:15 PM   #4
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
but that won't fix the exhaust leak *if there is one
cRayZee is offline   Reply With Quote
Old 03-31-2004, 09:49 PM   #5
HubbieScooby
Member#: 7088
Super Slow
there shouldn't be a leak because i'm still reading the same amount of boost at WOT as before the headers...
Old 03-31-2004, 09:53 PM   #6
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
This is how things usually go. As soon as you say there *shouldn't* be a <insert description/problem here> . That is the first thing you check.
Yea, you're seeing the same amount of boost @ WOT, but there's a significant increase in lag?
The turbo just isn't getting as much hot gas to spin it as before if there's a leak, but it will eventually get up there. Doesn't hurt to check.
slow spool and vibration!! newgensti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-04-2006 03:28 PM
Finally stage 2.... but spools slow? 4wdwrx AccessPort 7 07-11-2006 04:13 PM
slow spooling gt-30r, HELP! deluxsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 11-10-2005 02:50 PM
Spool up slow with aircon Suberman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-17-2005 03:03 PM
Slow spool when car is warm amelnikov Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-04-2002 01:36 AM
