Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 03-31-2004, 06:23 AM   #1
Member#: 58528
Have a Nice Day? Code 35 purge control solenoid valve troubles
Need PCSV location on 91 legacy
Need specific troubleshooting.
I believe I know where it's at (under the intake man..2 vacuum lines w/ a blue connector...above the brown connector thermoswitch...But I want to be sure.
This is an intermittent thing... the lights comes on then it goes off. I have read that it's eith on or off...when the engine is cold it's off... when it's hot it is on...with some exceptions... such as idling after warm-up. Also I know how the principal of the purge canister and the need to recycle the vapor works. Both the connectors and the vacuum lines are fine.
I'm wondering if during "warm" idle if this light comes on or on the road cruising it goes off and on...is that specifically the solenoid valve or a leaky gas tank cap?
Any history of a faulty PCSV or gas cap?
Any specific procedures?
theascen is offline   Reply With Quote
Old 03-31-2004, 08:14 AM   #2
Member#: 34670
2013 No gears!
Saltine American
I ran my 90 Legacy with that light for like 50k miles. Dealership wanted too much to fix it, and nobody else seemed to know what it was.
orndog is offline   Reply With Quote
Old 04-02-2004, 04:36 AM   #3
Member#: 25796
1993 Legacy Turbo
You're right that the solenoid is mounted on the underside of the intake manifold between the passenger side runners. It's a little bit of a pain to reach, but just be glad you don't have a turbo.
You probably have an intermittent failure. The solenoid is unfortunately mounted somewhere where it is subjected to a lot of heat and vibration, so the coils develop tiny cracks in them that sometimes fail to conduct.
vrg3 is offline   Reply With Quote
Purge Control Solenoid Valve DELETE! Any Info? guitarmaster1195 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-27-2009 03:15 PM
WTB: Purge control solenoid valve jblaine Private 'Wanted' Classifieds 7 04-21-2009 08:51 PM
Purge Control Solenoid valve? Synx Service & Maintenance 4 07-02-2008 05:40 PM
Broken Nipple on Purge Control Solenoid Valve 48mpg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-24-2008 07:40 PM
Purge Control Solenoid Valve?? abosworth Normally Aspirated Powertrain 3 07-21-2005 04:20 PM
