Old 03-31-2004, 08:45 AM   #1
Soon2BRex
Member#: 57122
Default Conflicting information about '04 shocks, need help please!
So I'm looking at getting some stiffer AutoX shocks for my '04 WRX sedan(specifically KYB and Koni). I have called several tuner shops around here and both have said that the shocks on the '04 are the same as 02-03, while the springs are different. Koni and KYB don't list shocks available for '04 but the shops said they would fit no problem. One of these shops is supposed to be "good" at what they do.
I called Koni tech support to double check, and they said that the shock on the '04 are a DIFFERENT length(by a small amount) than the 02-03 models, and there will be some fitment issues.
What the heck?!?!?! Which is it? I don't want to put something on the suspension that MIGHT fit the car correctly.
Thanks in advance for any help!
MF
Soon2BRex is offline   Reply With Quote
Old 04-01-2004, 06:38 PM   #2
Soon2BRex
Member#: 57122
Bump. I talked to my dealers part department and they are definitely different from '03 to '04. The top spring perches are different as well.
Old 04-02-2004, 06:46 AM   #3
Davenow
Member#: 23676
Well, the spring rates are higher on all the aftermarket springs for 04, so it stands to reson that the damping rtes are higher. Which is consistant with how the 04's feel IMHO
I have 04 STI struts on my 02, there are NO fitment issues. If you want to use 04 springs, remember, you need to use 04 rear tops. Other than that, they are a direct bolt on part
Conflicting information about cobb springs, can you clarify? Neiliux Newbies & FAQs 21 07-24-2008 11:54 PM
Need shock assembly HELP PLEASE. paul nieto Brakes, Steering & Suspension 6 08-17-2006 09:51 AM
DS shock tuning - help please leecea Motorsports 4 10-04-2004 01:26 PM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
Newbie Buying '04 WRX Need Help... grabbit Newbies & FAQs 8 11-22-2003 04:35 PM
