Old 03-31-2004, 06:05 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default oil lines
yo can i run my oil return line under the xmember? i dont wanna have it next to the header
it should be touching the cross member when done, not dragging on the ground and its a stainless braided 1/2" heater/oil hose
alex
Old 03-31-2004, 06:20 PM   #2
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
You do not want your oil return line going 'up' at all. It should return to the pan right above the top of the oil level. If you need it to stay away from the uppipe/dowpipe, attach a 45* fitting on the outlet of the turbo and point it away from your exhaust piping.
-Charlie
phattyduck is offline   Reply With Quote
Old 03-31-2004, 06:33 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
uh it shouldnt be angled up at all, maybe a SLIGHT bit uphill but if people can run their return into the pan drain and not have their turbos blow i should be fine w/ a slight uphillness
Old 03-31-2004, 06:52 PM   #4
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
if you're going to ask the question, and then not want to hear a educated answer...why ask the question?
akcel is offline   Reply With Quote
Old 03-31-2004, 07:26 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
if i wanted to know about angles, i would have asked, what i said was is it ok to run it under the cross member, thanks for the educated response
love
alex
Old 03-31-2004, 07:47 PM   #6
akcel
Member#: 10268
gc8 I ride ride 24s
love
alex
well if its going under the xmember its going lower than the oil pan tap. you can run it over the xmember right next to the valve cover. it would be a better option than running it under a car, but you dont have to listen to us, we only have the experience
Old 04-01-2004, 08:44 AM   #7
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
Anyone have pictures of how this all hooks up to the oil pan? This is one place where i'm pretty confused still.
-Eli
squirrelmasta is offline   Reply With Quote
Old 04-01-2004, 09:36 AM   #8
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
why don't you just tap your passenger valve cover and return the oil there?
latinskllz is offline   Reply With Quote
Old 04-01-2004, 10:29 AM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
i thought i remember hearing bad things about that
Old 04-01-2004, 02:30 PM   #10
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
so you're concerned about doing the return line from the valve cover cuz you hear bad things about it, but it's okay to ignore the fact that the oil return will be gravity-fed and it's not okay to have an up-slope?
cRayZee is offline   Reply With Quote
Old 04-01-2004, 02:34 PM   #11
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
jesus christ
itd be like a 10 degree upslope for like 3 inches not uphill 90 degrees for 20 feet then a u fitting back down and into the turbo
Old 04-01-2004, 02:35 PM   #12
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
unless i find a different way, the first damned question i asked was about whether or not it was ok to have it under the xmember, but im not going to because incase i bottom out it wont rip the line off
mods plz close this thread
Old 04-01-2004, 07:36 PM   #13
Aphex
Member#: 146
'16 WRX Limited
it's "gravity fed", going uphill, for any degree, for any lenght will cause it to stop flow.
going uphill defeats the purpose of "gravity" there's no pressure to make it go uphill and into the oil pan, then it will backup into the turbo and blow out the seals and probably burn up the bearings. just a few hundred peoples opinion on that, but you can try if you want.
the FAT kits go into the valve cover and I've never heard anything bad about it. Also, doesn't the n00b turbo go into the valve cover as well?
Aphex is offline   Reply With Quote
Old 04-01-2004, 07:55 PM   #14
Lo0mis
Member#: 12469
2000 2.5 RS
BRP
I ran mine between the crossmember and the oilpan, and up the back of the head. A -8 line would be good, I used -10 and it was very tight. Like everyone has been saying, you don't want the oil to have to travel up hill at all.
Lo0mis is offline   Reply With Quote
Old 04-02-2004, 01:41 AM   #15
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
.....sigh
mine is uphill at...id say...POSSIBLY 2 degrees from level for 2 inches, with all the oil pushing down on it, its not going to matter
Old 04-02-2004, 02:02 AM   #16
Aphex
Member#: 146
'16 WRX Limited
it _could_ work, but I just don't understand the point of re-inventing the wheel. could always pick up a used ludespeed oil pan, it runs the line outside of the engine mount.
I understand you want to keep it away from the header, but if it's all downhill it isn't going to have time to heat up the oil that much, as it's a pretty limited amount of oil returning there compared to the amount that is returned from the rest of the engine.
Old 04-02-2004, 02:05 AM   #17
akcel
Member#: 10268
gc8 I ride ride 24s
.....sigh
my return line is about 4 inches in full length to the valve cover, think about it like this, if you had a ball and put it on a 2 degree slope will it stay in the same place or will it roll away?
Old 04-02-2004, 02:44 AM   #18
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
think if the ball had a continuous supply of balls behind it, had no raduis change of the tube so that it could flow fine, and was liquid
Old 04-02-2004, 03:15 AM   #19
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
my oil return is a straight shot down into the pan. your idea sounds alrite since its a really subtile and short uphill but you have to remember that oil is viscous and its not like water so it wont exactly flow really easily, it will thin out at high temps but it still wont flow like water so the uphill part might be a problem.
i think the people had problems returning to the valve cover when they're turbo wasnt high enough above the valve cover.
good luck
Derk1127 is offline   Reply With Quote
Old 04-02-2004, 03:47 AM   #20
kaos200
Member#: 2692
Just when I thought you were learning how to deal with people you post replies like this.
White 2.5RS, Learn to listen or take a hike.
Dont ask the question if the answer you hear isnt what you want to hear, and you think nomatter what you are right.
kaos200 is offline   Reply With Quote
Old 04-02-2004, 03:52 AM   #21
Aphex
Member#: 146
'16 WRX Limited
I recall a number of people having problems with the Minnam kits because the return line had a very short/very slight uphill section. they shortened the line so that it went straight downhill, and no problems anymore.......coincidence?
the problems they had were oil blowing past the turbo seals etc.
ok, lets think about it like this, if you have a downhill tube, that takes a slight upturn at the end but is lower than the first part of the tube.
now pour something down the top part, when it hits the bottom it will stop and begin to pool and build up in the first section of tube, granted once that level reaches the heigth of the upturned part of the tube, it _should_ equal out (assuming water) but for the backing up of the liquid in the first tube, the air that the liquid is displacing has to go somewhere, it won't go out the bottom so it has to come out the top, burping it so to speak.
now take the same scenario, with an all downhill slope tube, as fast as liquid goes in, it goes out, there is never any backup, and no 'burping' of the tube.
my $0.02
Old 04-02-2004, 04:25 AM   #22
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Unless you want a James Bond smokescreen you should make every attempt to have NO uphill sections.
Drac9 is offline   Reply With Quote
Old 04-02-2004, 09:21 AM   #23
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
i didnt ask crap about angles man, i told the mods to lock this thread because it was going nowhere, yeah i know what youre all saying, im choosing to do my own thing, which i didnt even ask about in the first place
alex
Old 04-02-2004, 10:51 AM   #24
akcel
Member#: 10268
gc8 I ride ride 24s
cant wait to see how your car turns out ;x
Old 04-02-2004, 01:53 PM   #25
Aphex
Member#: 146
'16 WRX Limited
your question was "yo can i run my oil return line under the xmember?"
the answer was NO
just because we gave you a reason as to why it was no, doesn't mean we were getting off topic, just giving a reason for the unanamous NO that was given.
go ahead and do your own thing, it's cool, but don't get all upset when down the road you post a message about your car blowing smoke and somebody throws this thread in your face.
WTB: cheap tmic, oil filter sandwich with lines, oil lines, boost controller slava from goshen Private 'Wanted' Classifieds 7 11-04-2008 12:56 PM
oil line/water line + fittings for gt35r ImprezaRSfan! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-22-2006 09:07 PM
WTT: My T3/T4 Oil Line for your Stock Oil Line dubluv17 Private 'For Sale' Classifieds 2 07-05-2005 10:51 AM
Turbo oil line leak. Hotrod, you have info on the SS line? Tex-WReX Texas Impreza Club Forum -- TXIC 0 05-16-2005 09:28 PM
