Old 08-10-2006, 10:05 PM   #101
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
That image is on your computer. Host it on imageshack or something then put that link inside the image tags.
www.imageshack.us
btw I did the v5 conversion on my 93 with an 05 swap and it all bolted right up. Bought the whole kit from www.get-primitive.com
sheepdog is offline   Reply With Quote
Old 08-11-2006, 04:17 PM   #102
alexey2001
Member#: 122478
Default turn signals
I was browing the web and I think I found what I need,
this is the Model number for the turn signals that should fit CGC01B-CWL.
the problem is that they cost over $100 - damn it, pricy.
alexey2001 is offline   Reply With Quote
Old 08-11-2006, 04:18 PM   #103
alexey2001
Member#: 122478
ignor this one, just trying to get my 5 postings so I can post a link
Old 08-11-2006, 04:20 PM   #104
alexey2001
Member#: 122478
.... ignor this one, just trying to get my 5 postings so I can post a link
Old 08-11-2006, 04:22 PM   #105
alexey2001
Member#: 122478
I hope this will show up.
here is the link for the blinkers
http://ravspeconline.com/ecommerce/p...roducts_id=868
if any one knows where I can get these for a bit less then $120, I would appreciate.
Thank you
Old 09-17-2006, 02:06 AM   #106
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
LET IT BE KNOWN
Modifying a L bumper beam to fit on a V4 bumper skin is NOT I repeat NOT an easy task!!!
Unless you have a plasma cutter, or one of those giant power cutting wheels, these bitches are a pain in the ass to modify properly!
Yes, I just spent what, 3 or 4 hours cutting and hammering to get that sucker appart...
OMG I should have bought a JDM bumper beam instead, and so should you if you are planning on doing this.
I should take a photo of my hands too, all chewed up like I was in a fight...
At least everything else on this install is going relativly easy...
Old 09-17-2006, 02:12 PM   #107
Subaruski
Member#: 39905
LET IT BE KNOWN
I suck at stuff like this and all it took me was a dremel and a sawza and about 2 hours. It does suck because its tedious.
Subaruski is offline   Reply With Quote
Old 09-17-2006, 02:23 PM   #108
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
My 93-01 conversion went easy as pie. I got the full kit from Primitive racing (www.get-primitive.com), and it came with the jdm bumper beam.
Old 09-20-2006, 10:55 PM   #109
97 Pimpreza
Member#: 123693
2004 Impreza WRX
Red
Will an 04 sti front bumper fit on my 97 L? i am buying an 04 WRX STI from a junkyard for $700. the rear end is totalled but the interior front end, engine tranny and all thet stuff is fine. which means I will have the bumper beam. considering all this will it be a bolt in affair?
97 Pimpreza is offline   Reply With Quote
Old 09-24-2006, 07:12 PM   #110
Local_Skater
Member#: 117454
96 Impreza L 309
99 Forester L Black
$700?!!!! Are you sure you arn't missing a 0?
Local_Skater is offline   Reply With Quote
Old 09-25-2006, 06:28 PM   #111
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
ZERO body panels are compatible between an 02+ Impreza and a 93-01 Impreza...
And ya, wtf with the $700 STI!?
Old 09-27-2006, 07:07 PM   #112
97 Pimpreza
Member#: 123693
2004 Impreza WRX
Red
no......its $700. it got rear ended by a dump truck.
Old 09-27-2006, 08:10 PM   #113
Subaruski
Member#: 39905
Damn i wish i could find a deal like that. So are you swaping out the whole drive train or is the rear diff and all that damaged?
Old 09-28-2006, 08:40 PM   #114
97 Pimpreza
Member#: 123693
2004 Impreza WRX
Red
ummmmm....I don't know i think i might just swap my tranny to a manual (my 97 and the 04 sti are both automatics) Im prolly gonna sell the engine which has only 50k and turbo my 2.2 and do all the normal power building crap.
Old 09-28-2006, 09:45 PM   #115
AaronB
Worst Mod Ever
Member#: 369
Exclamation
FYI, any USDM STi 04-07 is a 6-speed manual transmission only...
If it is an automatic it is likey a WRX or RS model rather than STi.
AaronB is offline   Reply With Quote
Old 10-02-2006, 10:42 PM   #116
97 Pimpreza
Member#: 123693
2004 Impreza WRX
Red
well i know its an automatic and i think the tranny i have now is dying. how would it swap over (just the tranny)? would it be easy?
Old 10-03-2006, 02:54 PM   #117
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
if it's an auto its not an STi
Old 10-03-2006, 08:18 PM   #118
97 Pimpreza
Member#: 123693
2004 Impreza WRX
Red
ok maybe its not an sti. but it is an 04 wrx thats an automatic. would it be hard to put the tranny from it in my 97 impreza L.
Old 10-03-2006, 10:03 PM   #119
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
Just the tranny?
Old 10-04-2006, 07:44 AM   #120
97 Pimpreza
Member#: 123693
2004 Impreza WRX
Red
yah. cuz the tranny i have now is about to die. tromping on the gas and going 110 in an automatic with 120,000 miles on it isnt to good on it. the rest of the drivetrain is fine. can i swap over just the tranny or do i have to swap over other stuff too?
Old 11-01-2006, 09:55 AM   #121
atech_rallyrs
Member#: 116638
00 impreza naSTi
el typico silver
Back on topic! I just did this swap yesterday. It took 4 hours of dismantling, and went back together with no problems. I do have slightly more gap than I wanted between the headlights and bumper, but otherwise completely perfect fit. This was done on a 97 OBS. Please note that the lightweight JDM beam is NOT SAFE in a collision. That thing is so flimsy and not-durable its scary. Also, the under-guards that protect the engine bay dont fit between the obs and the rs bumper; these had to be ziptied together to prevent them from bouncing around. Also, the lightweight beam lacks the extra holes for pushpins to keep the bottom from moving; you will have to bolt and ziptie it directly to the beam/frame wherever you can on the edges. I did find two spots directly under the bumperbeam that I could bind the bottom to. Also, the single biggest pain in my ass was putting on the foglamps. The foglamps alone took like an hour because of the very small area I had to work with getting the bolts in there to screw down to the plates. Well worth the 450$ we spent on the whole thing, the woman is super happy about her new rs-lookalike obs wagon. Next up! rhd conversion and engine drop!
atech_rallyrs is offline   Reply With Quote
Old 11-06-2006, 10:43 AM   #122
bl_easy
Member#: 91407
1997 OBS/93 WRX, RIP
1996 OBS turned RHD GF8
All that and you found the foglamps tp be the difficult part?
I thought that was easy. Hardest part for me was getting the damn bumper off... those scrivets that hold the skin to the fender were not fun.
Why'd you go with the LW beam? I'd go junkyard hunting for a stock RS beam. The cash savings isn't worth the reduction in safety... I had a front end collision and am so glad I didn't get the LW beam.
bl_easy is offline   Reply With Quote
Old 01-30-2007, 08:56 AM   #123
Mechkiller31st
Member#: 38474
1998 Impreza Wagon L
Brilliant Red
Im going to be doing this conversion in just a few weeks. but I need to buy the front bumper beam. I have a 1998 L and am going with the Version V frontend found on Get-Primitive.com I am wondering do I get the LW Front Bumper Beam for the 93-98 or the LW Front Bumper Beam 99-01? I know that my bumper beam that i have on is too big for the new front bumper. Can anyone quickly answer that for me.
Mechkiller31st is offline   Reply With Quote
Old 01-30-2007, 09:20 AM   #124
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
it would be cheeper to buy the factory part they are only ~150 from your dealer and you don't have to pay shipping from oregon
option A get 99-01 beam its heavy
option B get the sawsall out and cut off ~half of you L bumper
option C (bad idea) get lightweight also form local dealer)
option b is my recomendation C provides no support at all
Old 01-30-2007, 09:53 AM   #125
AaronB
Worst Mod Ever
Member#: 369
Another vote for the factory bumper cover, as I can't imagine a fiberglass bumper cover being as durable as stock.
F/S: S201 Black Hood Scoop and white Factory Hood Scoop for 93-01 Impreza GC8 (pic) JunGdb Exterior/Styling 3 01-24-2012 03:54 PM
Cusco Front Strut Brace for 93-01 Impreza GC8 xS2k Suspension/Brakes/Handling 5 10-30-2006 04:02 AM
FS: 93-01 Impreza JDM Sti Tail Lights bolohuu Private 'For Sale' Classifieds 4 07-01-2005 04:14 PM
gauging interest: JDM GC8 STI VERSION 6 GUAGE CLUSTER Rattles Private 'For Sale' Classifieds 2 07-31-2004 08:55 PM
GC8 STi version 6 seats for sale.... E46-Pyellow Private 'For Sale' Classifieds 0 09-27-2003 10:53 PM
Message Board Statistics All times are GMT -4. The time now is 11:23 AM.
