Old 03-31-2004, 06:19 PM   #1
intec
Member#: 43593
Default nitrous question
would i be able to run a wet 50 shot on a cobb stage two reflash safley. if so should i inform cobb of what i plan to do or would i be ok either way
intec is offline   Reply With Quote
Old 03-31-2004, 06:22 PM   #2
mordy_2v
Member#: 3381
2011 Sah nah tah
dark
I'd be more worried about your engine components than the ecu. The ecu will probably make it through the ordeal fine
mordy_2v is offline   Reply With Quote
Old 03-31-2004, 06:35 PM   #3
intec
Member#: 43593
i only plan on spraying from second gear on. i just want to know that with the turbo spooling about 16 pounds of boost would the motor be ok with a 50 shot
Old 03-31-2004, 07:52 PM   #4
mixup52
Member#: 39691
2002 WRX Wagon
If you have the ECU tuned for the event, you will be ok. Let them know what you are planning to do. Also make sure you have bigger injectors. You WILL run out of fuel with N20 without bigger injectors.
mixup52 is offline   Reply With Quote
Old 03-31-2004, 11:04 PM   #5
abqkid
Member#: 52295
2003 WRX Wagon
i would consider going with cobbs stg 2.5 (uses bigger turbo and bigger injectors) and then try running your 50 shot.
abqkid is offline   Reply With Quote
Old 04-01-2004, 08:26 AM   #6
guesstimator
Member#: 57908
With a wet kit and a larger fuel pump (255lph) wouldnít that take care of fuel starvation? The wet kit adds the extra fuel needed via the fuel jet and there would only be a loss in pressure/volume. The fuel pump should take care of this, correct?
I am only speaking from experience from spraying NA cars though. Iím not as familiar with turbo/nitrous combos.
guesstimator is offline   Reply With Quote
Old 04-01-2004, 06:04 PM   #7
intec
Member#: 43593
i thought i would be ok with just a fuel pump if anyone is 100 percent sure what i can and cant do let me know
Old 03-10-2005, 12:09 AM   #8
Max Umbarger
Member#: 1112
2006 FXT
RBP
how did it go? I wonder also...
Max Umbarger is offline   Reply With Quote
Old 03-10-2005, 01:47 AM   #9
rustyzipper
Member#: 79175
2004 FXT
Red
remember that the fuel pump is not nessesary with the cobb stage 2 or 2.5 , and dont forget that the FPR will adjust accordingly to what the ECU tells it to , not what the FP is sending. i think that the wet system is risky without the proper "flexible" tuning. get the StreetTuner and make yourself a map that is needed.
rustyzipper is offline   Reply With Quote
Old 03-10-2005, 08:46 AM   #10
grkwrx2002
Member#: 54897
SILVER
Cool
you could use a boost activated switch to turn the nitrous off once you reached a a certain boost level and the once you change gears it would give shots untill that pressure is reached again.the switch is like 50 bucks.
grkwrx2002 is offline   Reply With Quote
Old 03-10-2005, 09:57 AM   #11
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
There is a hose going directly from the intake manifold to the FPR. How can the ECU control that?
wcbjr is offline   Reply With Quote
Old 03-10-2005, 12:30 PM   #12
codean
Member#: 10186
The simple rule to nitrous is to reduce timing and boost. You most definitely should use an upgraded fuel pump when running a nitrous setup. You want to make sure you have more then enough pressure to cover the fuel solenoid and your injectors.
I donít think that throwing a 50 shot on a map not tuned for it would be a good idea. You should call Cobb and see what they say.
codean is offline   Reply With Quote
Old 03-10-2005, 10:50 PM   #13
rustyzipper
Member#: 79175
2004 FXT
Red
wbcjr- i agree, but what about from the FPR to the injectors? cant the FPR still limit the amount, hence the FPR "tap" mod?
Old 03-11-2005, 01:19 AM   #14
fatray
Member#: 18150
2002 WRX Wagon EJ207
Velocity Red, Liberal kit
Just use a larger jet for the fuel then recomended so you get a low 10.0 to 1 AFR, maybe even lower to be safe. Make sure you have an upgraded fuel pump. I am running a 40 shot of nitrous that gave me an additional 67hp on my wrx. Had to special order the jets from NX.
fatray is offline   Reply With Quote
Old 03-11-2005, 08:07 PM   #15
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Yes, kinda. But the ECU has nothing to do with it.
Nitrous questions DeusExMachina Normally Aspirated Powertrain 4 03-17-2002 12:56 AM
more nitrous questions..... NateDogg Normally Aspirated with bolt-on Forced Induction Powertrain 0 10-01-2001 11:13 PM
('93-'01) Nitrous Questions ... MBX Motorsports Impreza Forum 13 04-23-2001 09:21 AM
Kevin Thomas Got a Nitrous Question??? Xscreamer Normally Aspirated Powertrain 14 03-01-2001 06:27 PM
Nitrous question... (Trey?) JC Normally Aspirated Powertrain 7 01-23-2001 09:06 AM
