Old 03-31-2004, 08:17 PM   #1
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
Default installed oil restrictor on my garrett turbo
now all i have in my exhaust is what looks to be condensation. no oil. although there is a little white smoke i figure its from the left over oil in the exhaust burning off. now my exhaust just smells like good ol' fuel.
akcel is offline   Reply With Quote
Old 03-31-2004, 08:33 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Heh, white smoke and fuel smell probably means you're running really rich. Good deal on the lack of oil smoke though.
Old 03-31-2004, 09:57 PM   #3
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
i'll have to ask you sometime to have a look at my car sometime and see if there's weird smoke comin out of my tailpipe
cRayZee is offline   Reply With Quote
Old 04-01-2004, 01:30 AM   #4
AntonioS
Member#: 23233
2000 2.5RS-T
white
Picture of the oil restrictor????
AntonioS is offline   Reply With Quote
Old 04-01-2004, 02:05 AM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
i have one for sale?~!?!?!?!?
buy mine its cheaper/!?!
Old 04-01-2004, 04:41 AM   #6
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
Autometer P/N 3277
I drilled mine out to 1/32" (0.031"). You can search for the recommended opening size here... (I have a Garrett turbo on my Camry)
-Charlie
phattyduck is offline   Reply With Quote
Old 04-01-2004, 05:07 AM   #7
akcel
Member#: 10268
gc8 I ride ride 24s
I used the one on atpturbo.com it costed a bit more but no drilling required as the hole is already 1/16" of an inch one end is male other is female to put your existing inlet into
Old 04-01-2004, 05:52 PM   #8
omarudy
Member#: 23738
This one?
omarudy is offline   Reply With Quote
Old 04-01-2004, 08:36 PM   #9
phattyduck
Member#: 32955
'03 WRX Wagon
Ahh... Well, I already had a 1/8NPT to -4AN fitting on the top of my turbo (-4AN oil feed line), so I just replaced the inlet w/ that... That other one posted looks good too.
-Charlie
Old 04-01-2004, 09:08 PM   #10
akcel
Member#: 10268
gc8 I ride ride 24s
that's the one
Old 04-02-2004, 12:56 AM   #11
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Guys my turbo has a very odd oil inlet whereby the inlet is actually closed up and there is two threaded holes one for the fitting and the second has a tiny tiny hole in the threads... I tried to take a picture but you can't see any thing... have any of you seen a new cartrigage of the GT series? The AVO 450 has it too... does anyone here know what I'm talking about? Is that the oil restrictor built in for the GT series?
HOK is offline   Reply With Quote
Old 04-02-2004, 01:44 AM   #12
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
According to atpturbo, the GT series oil restrictor looks like this:
Wedge is offline   Reply With Quote
Old 04-02-2004, 02:05 AM   #13
Aphex
Member#: 146
'16 WRX Limited
some turbos have built in oil restricters as well
Aphex is offline   Reply With Quote
Old 04-02-2004, 02:13 AM   #14
akcel
Member#: 10268
gc8 I ride ride 24s
yeah could be that, u may just need a flange that goes onto your turbo instead of the threaded hole that just takes a fitting
Old 04-04-2004, 12:59 PM   #15
Joncas
Member#: 5349
Do IHI turbo's like the vf22 need retricters too or are they "built in".
Joncas is offline   Reply With Quote
Old 04-04-2004, 02:29 PM   #16
akcel
Member#: 10268
gc8 I ride ride 24s
i dont think ihi turbos need em i think its just a t series garrettt issue
Old 04-05-2004, 06:20 AM   #17
phattyduck
Member#: 32955
'03 WRX Wagon
They aren't built in, but you don't need one on VF series turbos. The oil seals are built differently (or something like that). They see over 100psi in the WRX with no problem... It should be fine with 90psi or so max in an RS.
-Charlie
Old 01-31-2005, 11:04 AM   #18
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
Just to revive this old thread. I have a question on this oil restrictor mod. What is the thread size on this part from ATPturbo.
Is it 1/8NPT male/female???... Do I need any additional fittings or will the oil line screw right in?
If it is a 1/8NPT... will this one here work? https://vs01.tvsecure.com/~vs01037/orders/show44.html
Thanks for the help
maxiav is offline   Reply With Quote
Old 01-31-2005, 11:50 AM   #19
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Looks like that should do it, if that is in fact 1/8"NPT male/female. It doesn't list the size on the site, so there is no saying for sure, tho.
Old 01-31-2005, 12:35 PM   #20
maxiav
Member#: 40413
2001 BRP RS-T EJ257
GOOD NEWS!
I just called the place and IT IS a 1/8"NPT male/female adapter. The part is $4 and shipping is about a dollar. Orifice is 1/16. Should be here by Friday, so I'm hoping this will take care of the problem.
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Need a restrictor on my turbo. Need help finding info STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-21-2006 08:39 PM
Oil passing your seals? Garrett turbo? Here's your answer... 8Complex Normally Aspirated with bolt-on Forced Induction Powertrain 26 12-02-2005 10:03 AM
Can blown oil seals on my turbo induce pinging/knock? wall of tvs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-08-2005 12:51 AM
Oil restrictor killed my engine!!!! bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-13-2005 03:08 PM
