Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 04-01-2004, 10:07 AM   #1
ghrays
Member#: 50816
2015 WRX Limited
Lightning Red
Default A/C not cold enough 2004 XT
I have had my XT since Dec 03. The automatic AC controls have always been a little erratic in operation, so I usually use the manual. Lately, as it is becoming warmer and sunnier, I don't think the AC is cold enough, even with the temp knob on 65 degrees. It is having trouble keeping up with sunny days and 77 degree outside temperatures (San Diego). Should I have it checked by the dealer or is the AC sysytem just not very robust?
ghrays is offline   Reply With Quote
Old 04-01-2004, 01:56 PM   #2
brett s
Member#: 44606
2016 Forester XT
Mine has had no trouble with 90 degree weather...
brett s is offline   Reply With Quote
Old 04-01-2004, 02:22 PM   #3
irmiger
Member#: 54241
2004 Forester XT
Java Black
I read on another thread that it's fairly common to find your a/c refrigerant not topped off. It seems that the cars usually come with a partial charge. You should get your refrigerant checked out by someone reputable. I wouldn't go to the dealer though...they're more than likely to tell you nothing's wrong when there is.
irmiger is offline   Reply With Quote
Old 04-01-2004, 02:22 PM   #4
Black Blur
Member#: 47253
2004 Forester XT
Java Black
Have it checked out.
Mine is like an Eskimo's freezer.
Black Blur is offline   Reply With Quote
Old 04-01-2004, 03:42 PM   #5
jimqpublic
Member#: 38155
2004 ForesterXT Auto
The system is supposed to have 20 to 23 ounces of refrigerant. Mine had 16 last month (built in July '03, purchased September).
The AC tech said it was quite common for new vehicles to be underfilled.
I would expect the recharge should be covered by the warranty.
jimqpublic is offline   Reply With Quote
Old 04-01-2004, 05:42 PM   #6
SASniper
Member#: 57913
How do you check how much refrigerant is in your system?
SASniper is offline   Reply With Quote
Old 04-01-2004, 06:44 PM   #7
jimqpublic
Member#: 38155
Take it to an AC shop if it's not under warranty. They charge about $30 to do a "diagnostic" where they do a pressure test and pump out all the refrigerant, then measure it. If you have no leaks or other problems they put it back plus any extra needed for the full spec' amount. Price is about $10 per pound, so you're talking under $40 total.
Of course it should be covered by warranty so just go in to your Subaru dealer and tell them your AC isn't cold.
Old 04-01-2004, 07:33 PM   #8
008
Member#: 55317
2004 Forester XT AT
Damn, I was just noticing that my A/C is not cold enough! I was afraid that this was as cold as it gets and totally bummed about the upcoming summer in L.A... My car only has 1300 miles on it... I better take it back to the dealer to have the fluids checked.
008 is offline   Reply With Quote
Old 04-02-2004, 12:00 PM   #9
Bobshere
Member#: 49835
2004 Forester 2.5 XT
Mine gets so cold I have to turn it down.
Bob
(It's gotten up near 80 degrees F a few times already in March)
Bobshere is offline   Reply With Quote
STi exhaust not loud enough digidelia Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-28-2003 10:55 PM
HID lights not 'blue' enough? netZ Interior & Exterior Modification 9 02-27-2002 01:44 PM
Not fast enough... FastRedWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 11-07-2001 09:11 PM
RS not fast enough? Turbo4me South West Impreza Club Forum -- SWIC 2 12-12-2000 02:12 PM
20mm may not be enough if you can drive well jdchmiel General Forum Archive 16 07-22-2000 08:19 AM
