Notices
Old 04-01-2004, 03:14 PM   #1
BoostdBoxer
Member#: 53163
Default How in the devil do you get the DEFI EGT probe to stay attached to the NPT fitting?
How in the devil do you get the DEFI EGT probe to stay attached to the NPT fitting? that is included with the kit ????? anyone out ther ehave any freeakdinasdkinfaskidnfasd IDEA ??
BoostdBoxer is offline   Reply With Quote
Old 04-02-2004, 12:15 AM   #2
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
http://www.defi-shop.com/product/met...er_inst.html#9
there is a fitting and a sleeve thing that goes in there. not sure of the correct names, but mine came with it and works perfectly.
see above link
cnstman
cnstman is offline   Reply With Quote
Old 04-02-2004, 10:49 AM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The sleeve thing is a crush washer. When you tighten the upper flange to the lower flange it crushes said washer and holds the probe tight. DO NOT tighten the fitting before the install. Otherwise you will need to get a new crush washer.
mbiker97 is offline   Reply With Quote
Old 04-02-2004, 12:29 PM   #4
cnstman
Member#: 9548
2004 WRX STi
you can however remove the entire assembly once crushed if need be. just make sure you wrench the fitting that is threaded into the manifold. my mechanic did this successfully when switching from my wrx to sti.
So how the frack do you get all the water out of Tofu? Hazdaz Off-Topic 30 03-17-2008 08:35 AM
How the heck do you get an ebay TMIC to fit? Mr Nice Guy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 07-14-2007 10:19 AM
How in the hell do you get bolts off?!? JayD707 Newbies & FAQs 29 10-04-2004 10:11 AM
How the hell do you get the header bolts off linux>windows Normally Aspirated Powertrain 17 09-22-2004 11:37 AM
How in the Heck do you get the perrin BOV hose on? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-16-2004 07:53 PM
