Welcome to the North American Subaru Impreza Owners Club Thursday August 28, 2014
Old 04-01-2004, 03:40 PM   #1
h2o
Member#: 7946
94/9 MX-5/Fit
ZoomZoom/VTEC Kick'in Y0!
Question How to change S T i trans and front diff fluid?
I need to change my transmission and front diff fluid but there're couple drain plugs, I don't know which one is the right one. Can anyone help? Thank you.
h2o is offline   Reply With Quote
Old 04-02-2004, 02:07 AM   #2
ToddStratton
Member#: 8351
2002 WRX Wagon
Drain both sides, the clutch side and the oil pan side.
Here is the text from the FSM:
1. MANUAL TRANSMISSION
1) Drain the gear oil by removing drain plug.
NOTE:
Before starting work, cool off the transmission
gear oil well.
If transmission gear oil adheres to the exhaust
pipe, wipe it off completely.
2) Replace the gasket with new one, and then tighten
it to the specified torque.
Tightening torque:
5MT
70 Nm (7.1 kgf-m, 51.6 ft-lb)
6MT (Oil pan side):
44 Nm (4.5 kgf-m, 32.5ft-lb)
6MT (Clutch housing side):
3) Fill transmission gear oil through the oil level
gauge hole up to the upper point of level gauge.
NOTE:
Each oil manufacturer has its base oil and additives.
Thus, do not mix two or more brands.
Gear oil capacity:
5MT model
3.5 L (3.7 US qt, 3.1 Imp qt)
6MT model
4.1 L (4.3 US qt, 3.6 Imp qt)
TRS
ToddStratton is offline   Reply With Quote
Old 04-02-2004, 01:27 PM   #3
h2o
Member#: 7946
94/9 MX-5/Fit
Thank you very much, I will try it out
Old 04-02-2004, 02:16 PM   #4
jpimienta
Member#: 7457
Default Trans Fluid
Another question related to this?
When I had a WRX I replaced the trans and diff fluid to Redline 75w90 NS.
Will this work also for the STI. I don't remember where I heard that the stock STI fluid is better than the Redline one.
JP
jpimienta is offline   Reply With Quote
Old 04-02-2004, 11:30 PM   #5
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
also drive around a little and re-check the fluid a few times....it takes a while circulate and stabilize.
mr2guru is offline   Reply With Quote
Old 04-12-2004, 11:04 PM   #6
kinger
Member#: 49328
2004 WRB/Gold STI
What did you end up using for fluid? I keep hearing about about the 5MT trans fluids but nothing relating to the STI with the front LSD.
Also from the above instructions it has two seperate drains but fills through the same hole? Is that correct?
kinger is offline   Reply With Quote
Old 04-13-2004, 02:28 AM   #7
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
NEO RHD
Fills through dipstick
Old 04-13-2004, 02:37 AM   #8
Rev1
Member#: 51240
08 Lexus IS350
Use a long neck flexible funnel and be careful not to spill oil.
I dripped some on the downpipe and I'm having a hard time getting rid of the rotten onion smell...
4.1 quarts of Motul Gear 300 75W-90 here.
Rev1 is offline   Reply With Quote
Old 04-13-2004, 09:14 AM   #9
kinger
Member#: 49328
2004 WRB/Gold STI
How do you like it? On the stock fluid I notice that my synchro's sometimes block me on the 1-2 or 2-1 shift and I'm thinking its because of the lack of friction modifiers?
Old 04-13-2004, 09:19 AM   #10
kinger
Member#: 49328
2004 WRB/Gold STI
Originally posted by mr2guru
NEO RHD
Do you run this in your rear diff as well?
Old 04-13-2004, 12:49 PM   #11
Rev1
Member#: 51240
08 Lexus IS350
1-2 shifts are much smoother when cold (coldest in the last 2 weeks has been 27F) and shifting all other gears as well.
2-1 as well.
Old 04-26-2004, 02:42 AM   #12
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
I run Mobil synthetic gear oil and change about every 10,000. Don't forget to wipe off the drain plugs real good. There will be clumps of metal shavings stuck to the magnets.
jikhead is offline   Reply With Quote
Old 05-04-2004, 07:34 PM   #13
1WRX2NV
Member#: 17110
02 wrx sedan
midnight black pearl
Hey guys, so take out both plugs? then when you fill it throught the dipstick hole...it will fill everything...right?
I have changed my 6 speed fluid once before...but only opened the smaller plug...so I want to do it right this time.
Please advise.
thanks
-freddie
1WRX2NV is offline   Reply With Quote
Will to pay someone to change my tranny and rear diff fluid JeffyLube SCIC Private Classifieds 33 09-10-2009 06:57 AM
Willing to pay someone to change my tranny and rear diff fluid JeffyLube Service & Maintenance 5 09-05-2009 06:23 PM
How do I know when to change the tranny and rear diff fluids? Malasubidude Newbies & FAQs 7 08-20-2008 05:34 PM
Getting ready for trans and rear diff fluid change, need recommendations BGPKR Transmission (AT/MT) & Driveline 8 03-11-2008 02:29 AM
How to change rear and front diff. fluids? skyredrex Service & Maintenance 1 01-05-2004 04:30 PM
