Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 02-06-2001, 05:41 AM   #1
comcop
Member#: 1378
2005 Subaru WRX STi
Unhappy Check Engien light on?? After heave mods...
Hi, guys, my check engien light lighted up this morning while I was driving to school.
I had APEXi N1 Cat-Back Exhaust,APEXi Super AFC, and Weapon-R Air Intake installed. recently I have Unorthodox Racing Underdrive Pulley installed to my car. and 3 days ago I reset the ECU. and I'm pretty sure my S-AFC setting are all correct.
my car now is getting hiccups, and this morning the check engien light went on.
what could possibaly went wrong??
I do not have my S-AFC settings with me. but I will post it as soon as I get off work.
Comcop
[This message has been edited by comcop (edited February 06, 2001).]
comcop is offline
Old 02-06-2001, 06:32 AM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
I would take the S-AFC out, reset the ECU and see what happens. You can't bring the car to the dealer because S-AFC most likely kills the warranty.
What year is your car? If not MY00 or 01, maybe the intake killed your MAF sensor.
tmat3 is offline
Old 02-06-2001, 06:34 AM   #3
MBX Motorsports
Member#: 3726
2001 2.5RS
Blue Ridge Pearl
Post
Best way to tune an AFC properly ... goto the dyno and do it. That'll guarantee you the best results.
If your check engine light is on ... it may be telling you that 1) You're running too lean or 2) You're running way too rich. Both of those cituations will trip the 02 sensor, thus tripping your engine light. Pull the engine codes from the car and see what you come up with. If you pull the 02 sensor, then your AFC is not setup correctly. If you don't know how to set it up, find someone around your area who does.
At least that's my .02 - or you can start putting back on your OEM parts and see which part turns the engine light back off again =)
Dave
2001 2.5RS
1977 Fiancee - Will trade.
MBX Motorsports is offline
Old 02-06-2001, 06:57 AM   #4
comcop
Member#: 1378
2005 Subaru WRX STi
Post
My car is 99.
thanks for the help, guys!!
comcop is offline
HTML code is On
ABS, Airbag, and Rear Diff light on after washing engine Acejam2k Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-02-2010 12:32 PM
HIGH+LOW on after Foglight mod, no fog lights (HELP?) segfau|t Electrical & Lighting 6 06-10-2008 11:03 AM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 2 08-26-2003 08:59 PM
Check engine light on after intake install The1one4ever Normally Aspirated Powertrain 7 06-01-2002 02:25 AM
Tell me why my Check Engien light "ON"???? Help!!!!! comcop General Forum Archive 3 02-06-2001 06:58 AM
