Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 04-02-2004, 01:08 PM   #1
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
Default We've got the goods, More specials than ever before
NinosAutoAccesories is offline
Old 04-03-2004, 06:53 PM   #2
scrmblr2
Member Sales Rating: (5)
Member#: 24631
2005 STI
Question Stoptech Stage 2 Brake kit
Will this kit work on 03 wrx?
scrmblr2 is offline
Old 04-04-2004, 12:47 PM   #3
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
Everything except for the Brake pads.
Old 04-04-2004, 03:36 PM   #4
2fast4uWRX
Member#: 25001
02 Wrx Sedan
MBP
How do I make payment? I want the Progress rear sway bar w/ mounts.
2fast4uWRX is offline
Old 04-04-2004, 08:43 PM   #5
pittkid333
Member Sales Rating: (12)
Member#: 21328
2007 STi limited UGM
1995 GF wagon project
Default Re: We've got the goods, More specials than ever before
Originally posted by NinosAutoAccesories
Progress rear sway bar for 93-04 Impreza AND STi
Includes extra heavy duty sway bar mounts, bushings and all nessesary hardware for installation.[/color]
174.99 shipped
Nino
732-557-0491[/color]
I have a 93 FWD without a rear bar. What size does the bar come in, 18mm? I know I also need endlinks and new lateral links. Is there anything else would I need to get this on the car? And the major question is how good a deal can you make me for the kit and the additional parts. Slightly used may be ok if you have them too (esp. for the lateral links- Maybe off project car #1)
Thanks
pittkid333 is offline
Old 04-04-2004, 10:04 PM   #6
Rebellion
Member#: 8069
2016 Fiesta ST
Kona Blue
the progress is a 22mm adjustable bar (20-24 IIRC). That should be all that you need.
Rebellion is offline
Old 04-07-2004, 08:52 PM   #8
kbcr3
Member Sales Rating: (3)
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
Bump for one hell of a vendor!
kbcr3 is offline
Old 04-08-2004, 09:57 AM   #9
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
Old 04-08-2004, 12:58 PM   #10
aidrock
Member Sales Rating: (1)
Member#: 21028
2002 WRX Sedan WRB
02 Triumph Sprint RS
"Progress springs for 93-03 Impreza As well as 04 Impreza and STi springs are all in stock.
1.8" front drop and 1.5" rear drop with 210lb front klinear rate spring and 150lb rear progressive rate springs.
179.99 shipped FREE REAR CAMBER BOLTS!!"
-Do these work on my stock wagon, just take out my springs and slip these in?
"Akebono Ceramic pads for all 4 corners 98-02 2.5rs and WRX 105.00 shipped"
-I have DBA rotors, blanks. Will these work on them?
thanks,
aidan
aidrock is offline
Old 04-08-2004, 01:44 PM   #11
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
aidrock : I do have wagon springs available...and the pads will work
Old 04-08-2004, 04:23 PM   #12
o4 wrx
Member#: 35322
check your PM's Nino
o4 wrx is offline
Old 04-08-2004, 05:32 PM   #13
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
I need a set of engine/tranny mounts.
or
Cusco lower arm bar Ver 1 and front sway bar.
same deal as before?
Leonardo is offline
Old 04-08-2004, 11:46 PM   #14
wrx_honey
Member#: 55280
03 WRB WRX Sedan
Hi!! Do you have ground controls for a 03 WRX??? PM me!!Thanks!!!
wrx_honey is offline
Old 04-12-2004, 07:59 AM   #15
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Scratch the Ver. 1 bar. not compatible with my Ver. 2 as I thought.
So just the front sway bar please!
Leonardo is offline
Old 04-12-2004, 08:22 AM   #16
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
wrx_honey : Yes
Leonardo : OK, its all yours. What about the mounts?
Old 04-12-2004, 06:23 PM   #17
BobbyD
Member#: 27262
02 WRX
check your email..
--bobby
BobbyD is offline
Old 04-14-2004, 12:09 PM   #18
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
Old 04-15-2004, 03:41 PM   #19
ScoobyRSRallier
Member#: 9686
00RS 05 lgt
Silverthorn, Silver
Wondered if you had sti stuts and lowering spring for a gc8 in stock? Looking for options of suspension, want to stay away from coilovers, and heard that was a good package. Pm if you have any idea/deals.
-Ben
ScoobyRSRallier is offline
Old 04-15-2004, 04:34 PM   #20
structureboy
Member#: 7343
2000 2.5rs Silver
silverthorn....pealing
Looking for a set of swaybars for my RS. I want a adjustable rear, and also a front. Do you have a combo? thanks
Sean
structureboy is offline
Old 04-17-2004, 11:35 PM   #21
ttenneb
Member#: 30013
2003 wrx wagon
Will the progress front and rear sway bars work for a WRX wagon? Are there any fitmant issues?
ttenneb is offline
Old 04-18-2004, 10:40 AM   #22
darioc
Member Sales Rating: (10)
Member#: 35695
02 RST
98 Outback 92 Wrangler
will the front sway bar work on an 02 2.5rs? how much if so?
darioc is offline
Old 04-18-2004, 06:32 PM   #23
thetikler1
Member#: 24096
2011 Outback/WRX
On the Stoptech Stage 2 brake package, can you swap out those pads for something elsE? like carbotech. and how much bigger are the rotors than stock? or are they simply slotted.
thanks,
christian
thetikler1 is offline
Old 04-19-2004, 02:18 AM   #24
hockeyguy
Member#: 49451
1997 Outback Sport
Green
I've read conflicting information on the Progress Springs. Are they designed to work with the stock struts or will they kill the stockers in a few months?
Thanks!
Mike
hockeyguy is offline
Old 04-19-2004, 10:56 AM   #25
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
ScoobyRSRallier : Not in stock, special order
structureboy : I've got some cusco stuff heading my way right now.Shuld be here by friday.
ttenneb : Progress says no, but I've done a few installs with no problems so they seem wto work.The only issue is if you try to use aftermarket links on the front.
Closed Thread
Porn on the Ipad? More likely than you think. psychoskip Off-Topic 19 04-27-2010 01:39 PM
WBM 2007: Bigger and more Wicked than ever.... TmT NASIOC Official News, Articles and Polls 15 09-05-2007 12:15 PM
Ultimate Racing GT35R Turbo Kits! Now more affordable than ever! Ultimate Racing Engine/Power/Exhaust 102 05-01-2006 09:37 PM
Bitch stole your $3200? We've got the solution for you! Asinine Off-Topic 15 04-19-2006 04:15 PM
I got the bested X-mas gift ever! 03 Silver Bullet Southern California Impreza Club Forum -- SCIC 8 12-24-2005 10:27 PM
