Old 04-02-2004, 04:11 PM   #1
carpetsloth
Member#: 17863
2002 Impreza WRX
Default Clunk in front suspension...
Hey guys/gals,
I have an 02 WRX with 68,000 kms on it (only major componeny warranty remains) and I have a clunk in the front end when I over any kind of uneven pavement. I have had it at the dealers 3 times to get the clunk repaired and they have tightened every bolt they can see, checked all the motor mounts/bushings and replaced the swaybar endlinks. Nothing has helped. They can't seem to find the problem and now they are saying drive it like that till it gets worse or something breaks, then we'll fix it.
The noise happenes when I hit uneven pavement, maybe a pothole or a manhole cover. The sound happens when either wheel hits a bump but not when both hit the same bump (like a speedbump). That's why they thought it was swaybar related.
There are no broken coils on the springs and everything appears to be fine to the mechanics. The noise is a solid noise, kinda like if you were banging on a plastic jerry can with a wrench and I can feel the noise through my feet very slightly. Like if someone were tapping on the car with something.
I'm kinda loosing my patience with this issue, it's been in 3 times and I've been dealing with the noise for almost 2 months now. It's a loud noise and I don't feel like waiting for "it to get worse or break". I mean, it's a 2002 I spent 43K canadian on (taxes suck) and it clunks like an 84 chevette!
I know it's quite hard to diagnose suspension noise online but any advice you might have on what I should check would be great.
carpetsloth is offline   Reply With Quote
Old 04-02-2004, 04:23 PM   #2
poison
Member#: 37678
Are you sure it is not when you turn at low speed into, say, a driveway or over some other bump?
Lots of subies do that, mine included, and no one has an explaination.
It feels like a rattle in the floor pan and steering column.
It doesn't happen to me when I go straight, ever, but maybe it could.
poison is offline   Reply With Quote
Old 04-02-2004, 04:32 PM   #3
carpetsloth
Member#: 17863
2002 Impreza WRX
I had that noise since day one, turning up into my driveway over the sidewalk there was a slight clunk, but this is in any direction, regardless of accel/decel or braking and about 5x as loud. You can actually hear it from the street when I drive by. It's really got me stumped.
Old 04-02-2004, 11:35 PM   #4
fourdegrees
Member#: 49662
2005 FEALing fine
I'm having a clunk fixed. The service guy said it is the strut top mount. Didn't see you mention that at all. I always get it turning in to park.
fourdegrees is offline   Reply With Quote
Old 04-03-2004, 06:04 PM   #5
carpetsloth
Member#: 17863
2002 Impreza WRX
Thanks, I'll look into that. It's so hard to track these sounds down.
Old 05-16-2004, 08:12 PM   #6
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
I too suffer from the ever elusive noise, went over everything and still cant find it.
Big-Sexy907 is offline   Reply With Quote
Old 01-31-2006, 12:35 PM   #7
lexmurphy
Member#: 54780
1998 Impreza RS
I have this same clunk when I go over uneven payment. It seems like it happens when the wheel drops. I know this is an old thread, but did anyone ever get to the root cuase of the problem?
98 Impreza RS2.5
lexmurphy is offline   Reply With Quote
Old 01-31-2006, 02:46 PM   #8
GHK
Member#: 103886
2005 WRX
check you sway bar bushing brackets. if they are too tight, they make that clunk noise. maybe it's a time for you to replace the sway bar bushings or need some lubrication on them.
GHK is offline   Reply With Quote
Old 02-02-2006, 12:22 PM   #9
lexmurphy
Member#: 54780
1998 Impreza RS
thanks, I'll look into it
Old 02-02-2006, 04:21 PM   #10
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
I have had this noise for over 70,000miles.... Any help? (Ive just lubed the swabar bushings-- no change)
(Ive checked all the other bolts and such.
LyveWRX is offline   Reply With Quote
Old 02-02-2006, 11:51 PM   #11
ase05scooby
Member#: 103710
05 impreza wrx
red
the bearing plates on the front strut mounts wear out over time and end up with free play when you hit bumps or go over uneven pavement making a clunking noise just replace the mounts should be fine happens alot on japanese cars to
ase05scooby is offline   Reply With Quote
Old 02-03-2006, 12:09 AM   #12
meebs
Member#: 3251
2009 WRX Hatch
I have the noise too but have 103k miles on my 01 rs.
What exactly are bearing plates?
Probably time for new struts for me as well.
meebs is offline   Reply With Quote
Old 02-03-2006, 12:20 PM   #13
rasiter
Member#: 70407
sedona red
I had a really bad clunking noise in the front of my 02 wrx. it took me about 3 months to figure out. turns out it wasn't anything in the suspention. It was my cold air intake. the bracket that hold it to the fender broke due to engine torque. causing it to bounce around making the clunking noise I heard
rasiter is offline   Reply With Quote
Old 02-03-2006, 01:16 PM   #14
LyveWRX
Member#: 19057
Is that an after market CAI?
what is a bearing plate? do you mean Tophat?
If so mine are relatively new. I replaced all the struts last may, there was no change in the clunking after the replacement. W/in the next month or so I'm going to buy an STi set of struts and springs, we'll see if there's a change then.
clunking from front suspension EstoMax Tribeca Forum 9 11-01-2009 09:04 PM
clunking, creaking front suspension timmah Brakes, Steering & Suspension 3 04-22-2008 05:54 PM
Clunk in rear suspension. Dm0n3y002 Brakes, Steering & Suspension 2 11-18-2004 02:26 PM
Clunk in the suspension... heres what I found. Agent_50 Brakes, Steering & Suspension 1 11-07-2004 10:16 AM
light clunk in rear suspension after lowering car??? anybody?? k2snow Brakes, Steering & Suspension 4 07-02-2003 07:35 AM
